News
Extraordinary Robot
A man at a table works on a HP ZBook Studio while a woman stands on the other side of the table
HP’s newest additions to the HP Create Ecosystem are aimed at all levels of creators – consumers, prosumers and professionals – to help bring digital concepts and ideas to life and share them. This line-up includes the HP ZBook Studio, HP ZBook Create and the HP ENVY 15.
In the past, creators had to choose between heavy workstations or bulky gaming devices to get the power they require for work and play. Now, HP touts the compactness and effectiveness of the HP ZBook Studio, “the world’s most powerful mobile workstation per cubic centimeter” [1]. Nowadays, creators want to multi-task while projects are rendering in the background without slowing down other applications, and in that regard the ZBook Studio is seven times faster than other mobile solutions [2].An HP ZBook Studio on a desk wit hand reaching over to the touchpad
In 2015, HP won a Scientific and Technical Academy Award for the development of the HP DreamColor display. The ZBook Studio and ZBook Create bring the first DreamColor display with all-day battery life to visual effects artists, animators and colorists worldwide, enabling them to accurately represent their content on-screen from anywhere, thanks to DreamColor’s built-in colorimeter for automatic self-calibration, 100% sRGB and Adobe RGB for accuracy. It also has more than a billion colors [3] for smoother shading and more consistent gradients.
With these two devices, creators can design, edit, render and stream from anywhere no matter how complex the workflow, choosing between Quadro or GeForce graphics and next-gen Intel Core and Intel Xeon processors. They each deliver nearly borderless screen experience – a 22% reduction in volume from the previous generation – alongside an up to 17.5-hour long-lasting battery life [4] into a lightweight aluminum exterior.
A new vapor cooling chamber and liquid crystal polymer, gaming-class thermals also help with the ability to run at maximum performance, as needed.
HP ENVY 15 open and facing left
HP ENVY 15
The Link Removed is the first ENVY with a layer of glass on top of the touchpad for a smooth touch experience. Available across all new HP ENVY devices this year is the all-in-one keyboard, which includes easily accessible buttons for power, camera shutter, mute mic, fingerprint reader and HP Command Center.
Digital creations take on a new level of detail and realism with 4K OLED VESA-certified DisplayHDR True Black display. It features 100% DCI-P3 color gamut, 100,000:1 contrast ratio with 400 nits brightness. Fast rendering, seamless playback and smooth multitasking are a breeze with an up to 10th Gen Intel Core i9 (H-series) processor, up to NVIDIA GeForce RTX 2060 with Max-Q design and up to 32GB of DDR4 Memory.
The ENVY 15 is the first HP ENVY device to offer gaming-class thermals – a vapor chamber and two 12-volt fans. Compared with a traditional heat-pipe design, HP’s custom vapor chamber solution provides 33% more processor power to power through intensive workloads.
The device also features HP Dynamic Power, which intelligently allocates power between the CPU and GPU; and, the IR thermal sensor supports Performance Control to fully utilize thermal capacity.
Find out more about these devices and the HP Envy portfolio at the HP.com newsroom.
[1] Based on HP’s internal analysis of thermal design power per/cm3 based on competitor max graphics, max processor and max power delivery from CPU and GPU on non-gaming mobile workstations with a minimum three ISV certs, configurable professional graphics and a dedicated workstation brand.
[2] Based on Arnold GPU benchmarks comparing ZBook Studio G (Intel Core i7-10850H 6C, NVIDIA Quadro RTX 4000 Driver: 442.52, 32GB, 1TB NVMe- Windows 10 Professional 1909 and Apple MacBook Pro 16-inch (Intel Core i9-9980HK 8C, AMD Radeon Pro 5500M, 32GB, 1TB NVMe – macOS version 10.15.3) as of April 2020.
[3] Number of colors through A-FRC technology.
[4] Windows 10 MM14 battery life will vary depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery will naturally decrease with time and usage. See www.bapco.com for additional details.
The post HP Create Ecosystem adds HP ZBook Studio, HP ZBook Create and the HP ENVY 15 appeared first on Windows Blog.
Continue reading...
