i need help
HEy i need some help in the active icons in the bottom right hand corner of my start menu it usually shows the Wireless connection icon, the one that shows that i am connected and what i am connected to, also i used to have a volume button that i could adujst the volume with. These things disappeared after installing the newest updates for my vista. Anyone know how to get them back?
Windows Forum Admin
Microsoft MVP
Hi, if you right-click on the 'start' button and then properties you will see a dialogue box. Click 'Notification Area' along the top and you will see some boxes which correspond to the icons your looking for. Place a tick in the box for the icon you want and it should appear. :)
