iCloud Calendar Problem
WWolfe0001
Active Member
When I try to open my iCloud calendar I get the attached error message. iCloud for W11 is working OK and I can see everything there. I rebooted to no avail. Opinions?
An image from 'iCloud Calendar Problem'. Microsoft Outlook error states folders can't open due to a missing or faulty APLZOD64.dll service.
It looks like you're facing an issue with your iCloud Calendar in Outlook for Windows 11. The error message you've encountered indicates a problem with the MAPI (Messaging Application Programming Interface) related to Apple Internet Services. Let’s break down how to troubleshoot this situation effectively:
Possible Solutions:​
  • Ensure iCloud and Outlook are Up-to-Date:
  • Make sure you have the latest versions of both iCloud and Microsoft Outlook installed. Updates can fix bugs that might be causing the error.
  • Repair the iCloud Installation:
  • In some cases, repairing the iCloud installation can resolve issues related to syncing and connectivity.
  • Go to Control Panel > Programs > Programs...
  • Go to Control Panel > Programs > Programs and Features.
  • Find iCloud in the list, right-click it, and choose Repair. Follow the on-screen instructions.
  • Check for Multiple iCloud Accounts:
  • If you have multiple iCloud accounts configured, this might interfere with Outlook's ability to sync correctly. Make sure only one account is set up in iCloud and Outlook.
  • Reinstall iCloud:
  • If repairing doesn't help, consider uninstalling and reinstalling iCloud.
  • Uninstall from Control Panel > Programs > Programs and Features.
  • Restart your computer and then reinstall iCloud from the official Apple website: https://support.apple.com/en-us/HT204085.
  • Reset the MAPI Configuration:
  • Resetting the MAPI configuration might help:
  • Exit Outlook, then press Windows + R, type in control panel, and hit Enter.
  • Go to Mail > Show Profiles. Remove any profiles associated with old or unused accounts and create a new profile for iCloud.
  • Check for iCloud Information Services:
  • The specific error suggests that Outlook cannot load an information service. Check if the Apple Internet Services are correctly set up:
  • In Outlook, go to File > Account Settings > Account Settings.
  • Verify if the iCloud account is listed and correctly configured. If it’s not showing, you may need to add the account again.
Additional Suggestions:​
  • Disable Antivirus/Firewall Temporarily: Sometimes, security software can block connections between iCloud and Outlook. Disabling it temporarily could confirm this.
  • Contact Support: If these steps do not resolve the issue, reaching out to Apple Support or Microsoft Support for further assistance might be necessary.
Next Steps:​
If you complete these steps and still encounter issues, please share any additional error messages or behaviors you observe. This information can help diagnose the problem further!
