VIDEO Igor's Lab figured out why NVIDIA adapters are melting!
Igor's Lab figured out why NVIDIA adapters are melting! In a recent YouTube video, the host dives into a concerning issue regarding NVIDIA's 12VHPWR adapters, which have been reported to melt under certain conditions. The video references research conducted by Igor from Igor's Lab, who has provided substantial insight into why these failures are occurring .
Key Findings on 12VHPWR Adapters​
The crux of the problem lies in the design of the adapter itself. Each 12VHPWR connector consists of 12 power pins (six for power and six for ground), but surprisingly, only eight wires connect to these pins. Igor discovered that this arrangement forces power to be distributed across fewer wires than necessary, significantly increasing the resistance and, by extension, the heat generated during operation. In Igor's analysis, he noted that the melting predominantly occurs at the outer pins of the connector. This peculiar failure pattern indicates that it isn't just the bending of cables that causes these failures; rather, the main issue arises from lateral bending stresses, which can worsen solder joint conditions and lead to electrical disconnections. When wires break or become poorly connected, the remaining wires must carry more current, leading to overheating and eventual melting .
Construction of the Adapter​
A critical element of Igor's findings is the thin “foil metal” used within the adapter. This material, while intended to provide support, actually degrades the overall performance through increased resistance. When users push their GPUs, particularly under heavy load scenarios such as ray tracing, these resistive elements can contribute to dangerous heat levels . Igor compared this design flaw with past NVIDIA cards, noting that the previous adapters had dedicated wiring per pin, which counteracted similar issues. The new design not only introduces complexity in power distribution but also risks overheating due to inadequate current handling.
Recommendations​
Igor recommends using replacement cables that feature one wire per pin, which can stimulate safer electrical connections and mitigate the risks observed with the OEM adapters. Notably, the Corsair replacement cables draw attention as a safer option, as they are built with quality and consistency in mind .
Closing Thoughts​
With these insights, it becomes clear that users who are experiencing melting connectors might be at risk not simply due to their hardware setup but because of fundamental issues in design and manufacturing. It's essential for NVIDIA to take action based on Igor’s findings and provide a more durable solution for 40 series GPU owners. If you're using a custom cable designed correctly, you should be safe from these failures, but caution is advised . Feel free to share your experiences or any additional insights regarding this issue with NVIDIA's adapters! What has your experience been like with 12VHPWR connectors?
