Microsoft has quietly made one of the most practical security upgrades for Azure virtual infrastructure far easier to adopt: Trusted Launch can now be enabled in-place for many existing VMs and scale sets, reducing the migration friction that has kept foundational boot security from reaching production fleets.
Futuristic data center panel showing Trusted Launch and Secure Boot with green check marks.Background / Overview​
Trusted Launch is Azure’s platform-level suite of boot and platform protections — Secure Boot, virtual Trusted Platform Module (vTPM), and Boot Integrity Monitoring — combined to create a verifiable, cryptographic root of trust for virtual machines. It’s designed to block boot‑kits and other low‑level persistence techniques by ensuring only signed, approved code runs during the VM boot sequence and by giving Microsoft Defender for Cloud the telemetry needed to attest boot health. Microsoft documents Trusted Launch as a foundational security capability that’s available for Generation 2 VMs and for scale sets, and notes that the feature does not add extra VM pricing. Over the past year Microsoft has expanded Trusted Launch from being a default for new Gen2 deployments to offering a supported path to enable Trusted Launch on existing virtual machines and many scale sets. That in-place upgrade path is the news driving this surge in attention: it lets organizations raise the baseline security of existing workloads without full re-deployments, complicated migration tooling, or wholesale image rebuilds. The official guidance shows step-by-step portal, PowerShell, and CLI workflows for Gen2 VMs, and a preview path (with explicit prerequisites) for upgrading Gen1 VMs to Gen2 + Trusted Launch. It also documents enabling Trusted Launch across Uniform scale sets, with Flex scale set support in preview.
Why Trusted Launch matters: the security case​
Trusted Launch combines three guardrails that together provide a high-impact security posture improvement:
  • Secure Boot — cryptographically verifies the bootloader, kernel and signed drivers so unauthorized boot-time code cannot execute.
  • vTPM (virtual TPM 2.0) — a secure vault for keys and measured‑boot artifacts, enabling in-guest and remote attestation workflows.
  • Boot Integrity Monitoring — continuous checks (often surfaced through Microsoft Defender for Cloud) that alert when measured boot values differ from expected values.
Together these controls raise the bar against kernel-level persistence and advanced firmware or boot attacks, and they integrate into Defender for Cloud so central security tooling can detect and flag integrity anomalies. Microsoft explicitly maps these protections into Defender for Cloud recommendations (for example, recommending Secure Boot, vTPM, and the Guest Attestation extension), and Trusted Launch is identified in Azure guidance as a way to strengthen controls referenced by the Azure Security Benchmark and related compliance frameworks. Key operational benefits:
  • Defense-in-depth from first instruction — protection starts the moment the VM powers on.
  • Stronger key/secret protection — vTPM gives a TPM surface inside the VM for BitLocker-like workloads and measured-boot attestation.
  • Improved compliance posture — Trusted Launch supports controls that Azure maps to standards used by regulated sectors (the Azure Security Benchmark and Defender for Cloud recommendations specifically reference measured boot and vTPM patterns).
What Microsoft released — and what’s actually GA vs preview​
There’s nuance in Microsoft’s rollout that matters for planning:
  • Enabling Trusted Launch on existing Generation 2 (Gen2) VMs is documented and supported with portal / CLI / PowerShell paths. Microsoft’s docs for enabling Trusted Launch on existing Gen2 VMs are current and provide portal and scripting options.
  • Upgrade of Gen1 VMs to Gen2 + Trusted Launch is available but documented as a preview with explicit prerequisites and limitations (for example, MBR→GPT conversion, EFI partition creation, OS and backup caveats). Gen1-to-Gen2 conversions carry irreversible steps and additional risk that require careful validation.
  • Uniform Virtual Machine Scale Sets can be upgraded to Trusted Launch with platform guidance in place; however, Flex scale set support is still in preview and has preview registration requirements. Some scale-set configurations (data disks, certain upgrade modes) place constraints on upgrade workflows that you must plan for (rolling upgrades, max surge settings, etc..
  • Microsoft’s broader Trusted Launch program (including Trusted Launch as default for new Gen2 deployments) is moving through preview channels and will affect new VM deployments in the future, but existing VMs remain under customer control until they are explicitly upgraded.
Summary: Gen2 upgrade support is published and operational; Gen1 upgrade and Flex scale set support are preview features that require registration and additional validation. The public documentation should be used as the authoritative planning and execution guide.
Step-by-step (operational) — how organizations will typically adopt Trusted Launch​
Below is a pragmatic rollout pattern derived from Microsoft guidance and real-world enterprise practices.
  • Inventory and eligibility check
  • Identify candidate VMs and scale sets by generation, VM size family, OS version, attached features (e.g., managed images, data disks) and backup policy. The Trusted Launch upgrade requires supported size families and supported guest OS images. Azure Advisor and Defender for Cloud provide recommendations that surface upgrade candidates.
  • Pilot on non-production Gen2 VMs
  • Choose a small pilot ring of Gen2 VMs and Uniform scale sets. Validate guest drivers, third‑party agents, backup/restore, and GPU or kernel module compatibility (some Linux GPU drivers require Secure Boot to be disabled during installation). Run the Defender for Cloud Guest Attestation checks post-upgrade to confirm boot integrity telemetry.
  • Prepare backups and restore points
  • Create full backups or restore points before conversion. Gen1 upgrades include disk layout conversions (MBR→GPT) that can cause irreversible disk layout changes; Microsoft warns that rolling back requires restoring from pre-upgrade backups. Always verify restore across a test VM prior to broad rollout.
  • Apply changes with low-downtime patterns
  • For single VMs, the portal or PowerShell pathways require stopping/deallocating the VM, updating the securityType to TrustedLaunch, and then starting the VM. For Uniform scale sets, prefer rolling upgrades with controlled surge and maximum concurrent instance disruption to avoid service downtime. Flex scale sets currently require preview registration; follow the preview guidance if you plan to test Flex upgrades.
  • Validate and monitor post-upgrade
  • Confirm vTPM and Secure Boot are enabled (vTPM is enabled by default; Secure Boot option must be explicitly enabled), verify sign-in, check Microsoft Defender for Cloud alerts and the Guest Attestation extension, and run application-level smoke tests. Use telemetry to detect any integrity or driver-related issues.
A small example of the PowerShell sequence (conceptual; use the latest Microsoft docs for exact syntax and API versions):
  • Stop / deallocate the VM
  • Update the VM’s security type to TrustedLaunch (and enable Secure Boot and vTPM if desired)
  • Start the VM and validate sign-in
Refer to Microsoft documentation for exact commands and the API versions required for your subscription.
Strengths and practical wins​
  • Lower friction security uplift. The ability to convert existing Gen2 VMs to Trusted Launch without redeploying images is a major operational simplifier. This reduces the “security vs. uptime” tradeoff that often delays adoption of stronger platform protections.
  • No VM price penalty. Microsoft documents that Trusted Launch does not increase the existing VM pricing, removing a billing disincentive for adoption. That makes Trusted Launch a very attractive “security lift” for cost‑sensitive teams.
  • Integration with Defender for Cloud and Advisor. Automated recommendations and attestation telemetry make Trusted Launch more than a platform toggle — it becomes part of a measurable, auditable security posture improvement tied into compliance tooling.
  • Compliance alignment. Trusted Launch provides technical controls that align with elements of the Azure Security Benchmark and the control sets organizations commonly use to demonstrate FedRAMP, HIPAA, and enterprise governance compliance. While Trusted Launch alone won’t produce certification, it materially helps satisfy measured-boot and key protection controls referenced by those frameworks. (azure.microsoft.com)
Risks, caveats and real-world gotchas​
Trusted Launch is powerful, but it is not a “zero-risk” flip. Administrators must plan for practical limitations and failure modes:
  • Gen1→Gen2 upgrade complexity and irreversibility. Converting a Gen1 VM to Gen2 as part of enabling Trusted Launch requires disk layout modifications (MBR→GPT) and changes that are not easily reverted. Microsoft warns that roll‑back requires full recovery from prior backup snapshots; there is no simple “undo” button. This makes thorough testing and pre-upgrade backups mandatory.
  • Driver and OS compatibility. Secure Boot blocks unsigned kernel drivers. Many third‑party kernel modules or older GPU drivers (notably on some Linux GPU stacks) may require Secure Boot to be disabled during installation and special handling after enabling Trusted Launch. Validate drivers and kernel modules in the pilot.
  • Scale set upgrade constraints. If scale-set instances have data disks, enabling Trusted Launch requires specific upgrade modes (rolling upgrade with surge) and may require instance recreation for size changes. Flex scale set support is still preview — don’t assume parity with Uniform scale set behavior without testing.
  • Potential for unexpected boot failures after unrelated updates. Recent real-world incidents have shown how interactions between OS updates, VBS configurations, and Trusted Launch (or the absence of it) can cause boot issues. For example, a 2025 security update triggered VM boot failures in certain configurations where VBS was enabled but Trusted Launch was disabled; Microsoft issued an emergency fix. This illustrates that adding platform-level security changes shifts the interaction surface with Windows kernel and hypervisor updates — a reason to validate update/patch cycles in pilot rings.
  • Managed image limitations. Some image types (managed images, certain Azure Compute Gallery scenarios) may not be eligible for portal-based upgrades; scripted or template-based approaches are necessary. This complicates rollouts for environments that rely heavily on custom managed images.
Internally, operational teams should treat Trusted Launch adoption like any significant platform change: plan for rollback via backups, test patches and drivers, and include security telemetry validation steps in deployment checklists. Guidance and community posts emphasize the operational program mentality required for related features like Virtualization-Based Security and hotpatch readiness — Trusted Launch adoption sits inside that same operational matrix.
Recommended checklist before you upgrade production VMs​
  • Inventory: OS build, VM generation (Gen1/Gen2), VM size family, attached data disks, boot configuration, and backup policy.
  • Backup/Restore: Create full VM backups or platform restore points and test them by rehydrating at least one sample VM to a separate resource group.
  • Pilot: Select representative workloads (Windows Server, Linux, GPU workloads) for initial pilot and compatibility testing.
  • Drivers & Agents: Validate EDR, backup agents, and kernel drivers for Secure Boot compatibility.
  • Scale set planning: For Uniform scale sets, configure rolling upgrade with controlled surge; for Flex scale sets, register for preview only if you intend to test preview features.
  • Automation & Scripts: Prepare PowerShell/CLI/ARM/Bicep templates for batch upgrades and logging.
  • Monitoring: Ensure Defender for Cloud and Azure Monitor have guest attestation and boot integrity telemetry configured post-upgrade.
  • Timeline: Schedule upgrades during maintenance windows and stage in rings (pilot → early adopter → broad rollout).
What to watch next​
  • Trusted Launch as default for new Gen2 deployments is moving through public preview; subscription-level preview flags can enable that behavior for template-driven deployments. Teams that manage infrastructure-as-code should validate their CI/CD and deployment scripts to explicitly set securityProfile fields if they need to preserve “non-Trusted” behavior for backward compatibility.
  • Flex scale set Trusted Launch support remains in preview; enterprises that rely on flexible orchestration or aggressive instance mixing should keep an eye on the preview updates and breaking‑change advisories.
  • Patching interactions: continue to monitor Azure and Windows update advisories because kernel and hypervisor-related patches can surface unexpected interactions with VBS, Secure Boot, and boot integrity monitoring. Real-world incidents have already shown how patch cycles and VBS settings can combine to create boot failures if untested.
Final analysis: who should do this now, and how fast​
Trusted Launch is an immediate, high‑value security upgrade for most organizations running Gen2 Azure VMs and Uniform scale sets. For teams with modern, supported images and automation in place, the path to adoption is practical: pilot quickly, validate, and roll out in waves. The fact that Microsoft does not charge extra for Trusted Launch removes a major administrative barrier, making the decision largely operational rather than financial. However, organizations that run older Gen1 workloads, rely on custom managed images, or use kernel-mode drivers that are unsigned should not rush into mass upgrades without a staged program. The Gen1-to-Gen2 conversion is inherently more invasive and carries irreversible steps; the Flex scale set path is still in preview and should be treated as such. In short: adopt Trusted Launch aggressively where it’s low-friction (Gen2, supported sizes, Uniform scale sets), and plan a deliberate remediation and test program for more complex or legacy cases.
Microsoft’s in-place Trusted Launch upgrade capability materially lowers the operational bar for adopting platform-rooted VM protections in Azure. For many teams the change turns a multi-step migration project into a staged configuration update, enabling immediate security gains without additional licensing costs. But the upgrade is not without its operational tradeoffs: disk format changes, Secure Boot compatibility, scale-set constraints, and patch-interaction risks require disciplined pilot testing and robust backup/restore plans.
For IT and cloud security teams, the practical next steps are clear: identify Gen2 candidates today, run a fast pilot with Defender for Cloud attestation checks, and then expand in rings while tackling Gen1 and Flex scale set scenarios with deliberate planning. Trusted Launch is an important building block in a modern cloud security program — one that finally makes “secure-by-default” more reachable for existing footprints, provided operators respect the documented prerequisites and pitfalls.
Source: Neowin Microsoft simplifies Azure VM security, here's how
Microsoft’s recent push to make Trusted Launch easier to adopt across Azure virtual infrastructure is a practical — and overdue — step toward raising the cloud security baseline for many organizations, but the rollout contains important caveats that IT teams must understand before flipping the switch. The capability to enable Secure Boot, virtual TPM (vTPM), and Boot Integrity Monitoring on existing virtual machines and scale sets without full re-deployments reduces operational friction and removes a major barrier to wider adoption of platform-rooted protections — while simultaneously introducing irreversible changes and upgrade constraints that must be handled with a staged, test-first program.
Glowing blue diagram showing Secure Boot protecting cloud infrastructure and VMs.Background / Overview​
Trusted Launch bundles low-level platform controls — namely Secure Boot, vTPM (virtual Trusted Platform Module), and measured/attested boot — to establish a cryptographic root of trust for Azure virtual machines. These protections harden the boot path against bootkits, rootkits, and other early-stage persistence mechanisms by ensuring only properly signed, expected components can run during boot and by furnishing attestation telemetry to Microsoft Defender for Cloud and other monitoring tools. Microsoft documents Trusted Launch as a foundational capability for Azure Generation 2 (Gen2) VMs and a supported configuration for many scale sets. Until recently, adopting Trusted Launch broadly required rebuilding or re-deploying images as Gen2 Trusted Launch VMs, which created operational overhead and delayed adoption. Microsoft’s in-place upgrade paths change that calculus by allowing many existing VMs and Uniform scale sets to be converted to Trusted Launch with portal, CLI, or PowerShell flows. For Flex scale sets and upgrade paths from Generation 1 (Gen1) BIOS VMs to Gen2 Trusted Launch, the company currently exposes preview programs and feature flags rather than full general availability in all cases. That nuance is crucial for planning and risk assessment.
What Microsoft published — the technical facts​
Core protections delivered by Trusted Launch​
  • Secure Boot — enforces signed bootloaders and kernel components so unsigned or tampered boot code cannot execute. Important: Secure Boot is a key control for blocking boot-time attacks but can break drivers and out-of-tree kernel modules that are unsigned.
  • vTPM (virtual TPM 2.0) — provides an in-guest, standards-compliant TPM interface for key protection, BitLocker-like scenarios, and attestation artifacts. vTPM is enabled by default on Trusted Launch VMs.
  • Boot Integrity Monitoring / Guest Attestation — measured-boot telemetry and attestation checks that surface boot integrity anomalies to Defender for Cloud; recommended as part of validation post-upgrade.
Which upgrade paths are available now​
  • Conversion of existing Generation 2 (Gen2) VMs to Trusted Launch is supported and documented with portal, Azure CLI, and PowerShell options. The documented sequence typically requires stopping (deallocating) the VM, updating the VM securityType to TrustedLaunch, enabling Secure Boot (explicit) and vTPM (default), and restarting the VM.
  • Uniform Virtual Machine Scale Sets can be upgraded to Trusted Launch with platform guidance; the recommended upgrade mode is a rolling upgrade with controlled surge settings for sets with data disks.
  • Gen1 (BIOS) VMs → Gen2 Trusted Launch is available as an upgrade but is currently documented under preview channels and carries significant prerequisites and limitations (MBR→GPT conversion, creation of EFI system partition, OS version constraints, backup requirements). The Gen1-to-Gen2 path is invasive and irreversible without restoring from pre-upgrade backups.
  • Flex scale set support for enabling Trusted Launch on existing instances is currently handled via preview programs / private previews and is not yet as broadly available as Uniform scale set support.
Pricing and compliance notes​
  • Trusted Launch does not increase the listed VM pricing; Microsoft’s documentation states there is no additional VM charge for enabling Trusted Launch. This removes a financial barrier to adoption.
  • Trusted Launch helps organizations meet controls referenced by the Azure Security Benchmark and supports attestation patterns used for compliance with regulations and standards often cited by enterprises, including FedRAMP, HIPAA, and PCI-DSS. It is a technical control that supports compliance posture; it does not automatically confer certifications.
Where the Windows Report summary is accurate — and where it overstates​
The Windows Report summary correctly highlights the operational win: organizations can enable foundational protections such as Secure Boot and vTPM without a full migration, reducing downtime and migration complexity. It’s also correct that Trusted Launch is an important first line of defense in the boot chain and that Microsoft provides step-by-step guidance for Gen2 VMs and Uniform scale sets. However, the original summary blurs the distinction between what is generally available today and what remains in preview:
  • The ability to enable Trusted Launch on existing Gen2 VMs and many Uniform scale sets is broadly available and documented.
  • The Gen1 → Gen2 in-place upgrade path is still published as a preview workflow with explicit prerequisites and important caveats (MBR→GPT conversion, compatibility exclusions such as Windows Server 2016 and some Linux distributions, backup policy constraints). Treat any claim that Gen1 in-place upgrades are fully GA as unverified until Microsoft updates the preview status.
  • Flex scale set support for in-place Trusted Launch enablement remains in preview / private preview and requires registration. Any messaging suggesting full parity across scale set variants today is premature.
These distinctions matter operationally because Gen1 conversion is irreversible without restore and can introduce disk layout changes that break boot behavior if not properly prepared and tested. The short version: Trusted Launch for Gen2 + Uniform scale sets is production-ready; Gen1 conversion and Flex scale set upgrades remain higher-risk preview activities that require careful planning.
Operational benefits and why this matters now​
  • Friction reduction for baseline hardening — Many organizations deferred platform-level protections because image rebuilds and migrations were disruptive. In-place upgrades let teams adopt Secure Boot and vTPM without reimaging, lowering the operational cost of hardening.
  • No pricing penalty — Because Microsoft does not charge extra for Trusted Launch, the decision becomes operational rather than financial. This is especially meaningful for cloud cost-conscious teams.
  • Improved attestation and monitoring — Once enabled, platforms can feed measured-boot telemetry to Defender for Cloud for continuous attestation checks, which helps detect tampering or configuration drift at the earliest stage of the VM lifecycle.
  • Compliance alignment — Trusted Launch provides technical controls that align with measured-boot and key protection controls referenced in common compliance baselines — a practical advantage in regulated industries.
The risks, limitations, and real-world gotchas​
1) Irreversibility and disk conversion risk (Gen1 → Gen2)​
Converting a Gen1 VM to Gen2 as part of the Trusted Launch upgrade commonly requires converting the OS disk from MBR to GPT and adding an EFI system partition. This is an irreversible disk layout change that can render rollback complex and costly unless a tested backup/restore is available. Microsoft explicitly warns that roll-back requires restoring disks and VM from pre-upgrade backups or restore points. Treat Gen1 conversions as high-risk operations.
2) Secure Boot compatibility with third‑party drivers​
Secure Boot enforces signed boot components. Legacy or proprietary kernel modules, EDR/antivirus kernel drivers, and certain GPU drivers (notably some Linux GPU stacks) may require Secure Boot to be disabled during installation or require signed driver artifacts. In practice, teams should inventory kernel-mode modules and vendor drivers for Secure Boot compatibility before enabling Secure Boot.
3) Scale set constraints​
  • For Uniform scale sets with data disks, Microsoft recommends specific upgrade modes (rolling upgrade with surge) and calls out constraints around instance updates and manual update modes. Improper upgrade mode selection can cause availability issues or require instance recreation.
  • Flex scale sets currently require preview registration; enterprises using Flex behavior should not assume full parity yet.
4) Image types and management images​
Some OS image types (for example, certain Managed Images or images created in the Azure Compute Gallery) may require scripted or template-driven upgrades rather than portal-based flows. This complicates automation and means teams must audit their image estate for upgrade eligibility.
5) Patch and update interactions​
There are documented examples where interactions between virtualization-based security features, OS updates, and trusted boot controls have resulted in boot failures in specific configurations. Adding Trusted Launch changes the interaction surface for updates — thorough testing in pilot rings is essential to avoid unexpected outages.
A practical rollout plan — tested, repeatable steps​
Below is a pragmatic, phased plan for operational teams to adopt Trusted Launch with minimal risk.
Phase 0 — Inventory and triage​
  • Catalog all VMs and scale sets by:
  • Generation (Gen1 vs Gen2)
  • VM size family and supported Trusted Launch sizes
  • OS version and build level
  • Attached features (data disks, managed images)
  • Backup policy (Standard vs Enhanced)
  • Use Azure Advisor and Defender for Cloud recommendations to flag low-friction Gen2 candidates.
Phase 1 — Pilot​
  • Select a small, representative pilot group (Windows Server and Linux variants, small stateful apps, and one Uniform scale set).
  • For Gen1 candidates: test the MBR→GPT conversion steps using MBR2GPT in a lab VM to confirm success before any production runs. Microsoft documents the MBR2GPT flow and warns about limitations and validation steps.
  • Create full backups or restore points and exercise the restore process (rehydrate a VM from backup into a separate resource group) to verify rollback feasibility.
Phase 2 — Upgrade and validate​
  • For each pilot VM:
  • Deallocate (Stop) the VM.
  • Update securityType to TrustedLaunch (PowerShell/CLI/Portal per Microsoft guidance).
  • Enable Secure Boot and confirm vTPM settings (vTPM is enabled by default; Secure Boot must be explicitly enabled).
  • Start the VM and validate:
  • Successful sign-in (RDP/SSH)
  • Application smoke tests
  • Defender for Cloud boot integrity and Guest Attestation results
  • Driver/agent health and EDR compatibility.
Phase 3 — Rollout in rings​
  • Expand to early-adopter rings, then to broader production rings using automation templates (ARM/Bicep/PowerShell) and logging.
  • For Uniform scale sets, use rolling upgrades with max surge parameters to preserve availability when instances have data disks. Flexible scale set conversions should remain in preview/test until Microsoft removes preview constraints.
Phase 4 — Continuous monitoring and change control​
  • Add Guest Attestation extension and monitor boot integrity telemetry in Defender for Cloud.
  • Maintain a pre-upgrade snapshot/backup retention strategy for all converted VMs for an agreed period.
  • Update CI/CD and deployment templates to explicitly set the securityProfile if needed, especially if organizations plan to adopt Trusted Launch as the default in preview channels later.
Recommended checklist before upgrading production workloads​
  • Confirm OS versions are in the Trusted Launch supported list and that Windows builds have any required fixes for compatibility.
  • Validate driver signature status and test EDR/backup agents for Secure Boot compatibility.
  • For Gen1: perform MBR2GPT validation and ensure an EFI system partition will be created successfully.
  • Ensure backups are on Enhanced policy if using Azure Backup (some Standard backup policies are not compatible with upgrades).
  • Plan scale set upgrades with rolling modes and surge parameters — avoid manual update modes if heavy data disk attachments exist.
Strategic analysis — strengths and longer-term implications​
  • By making Trusted Launch easier to adopt in-place, Microsoft is shifting the cloud security economics: strong platform protections are now operationally feasible at scale rather than a costly migration project. This is a net positive for cloud security posture management across many sectors.
  • The move supports a broader “secure-by-default” trend in infrastructure-as-code workflows. Microsoft’s public preview for Trusted Launch as a default for new Gen2 VM deployments signals a future where Trusted Launch becomes the de facto configuration for new VMs created from validated images. That change will simplify future compliance and security baselining.
  • The availability of attestation telemetry (Guest Attestation + Defender for Cloud) turns Trusted Launch from a binary configuration into an auditable control point — enabling programmatic enforcement, continuous monitoring, and integration into security operations workflows.
Final verdict and pragmatic guidance​
Trusted Launch as an in-place upgrade for Gen2 VMs and for many Uniform scale sets is a practical, high-value security upgrade: it materially raises the cost and complexity for attackers who target the boot chain while not increasing VM charges. Organizations should prioritize adoption where the upgrade is low-friction — modern Gen2 images, supported VM sizes, and automated scale set upgrade modes. At the same time, treat Gen1 conversions and Flex scale set upgrades as projects, not flip-a-switch actions. Require validated backups, test restores, driver verification, and staged rollouts. Maintain careful change control and pilot rings because the disk layout changes (MBR→GPT), driver signing constraints, and potential patch interactions increase the risk of outage if rushed. Operational teams that follow a disciplined, test-first program — inventory, pilot, validate, and roll out in rings — will gain the security benefits of Trusted Launch without unnecessary disruption. The new in-place upgrade paths remove the most visible operational blocker to adoption, making platform-rooted boot security a realistic priority for cloud infrastructure owners for the first time.
Microsoft’s documentation and published guidance should be treated as the authoritative execution source for any upgrade. Where Microsoft marks features as preview (for example, Gen1-to-Trusted Launch and Flex scale set upgrades), follow the preview registration and feature-flag instructions and run exhaustive tests before applying to production fleets. End of analysis.
Source: Windows Report Microsoft brings Trusted Launch in-place upgrades to Azure VMs
Microsoft has started letting organizations turn on Trusted Launch for many existing Azure virtual machines and scale sets without rebuilding images or redeploying workloads — a move that lowers the operational bar for platform-rooted boot security while introducing a set of important prerequisites, compatibility checks, and rollout processes IT teams must follow.
Futuristic data center with holographic security UI showing Secure Boot and TPM.Background​
Trusted Launch is Azure’s combine‑and‑harden approach to protecting the VM boot chain: Secure Boot, a virtual Trusted Platform Module (vTPM), and boot integrity monitoring / guest attestation work together to ensure a VM starts in an attested, verifiable state. These protections raise the cost for attackers who target the earliest software layers (bootkits, rootkits) and provide telemetry into Microsoft Defender for Cloud and other monitoring systems. Until recently, moving a fleet to Trusted Launch typically meant rebuilding or redeploying images as Generation‑2 (Gen2) Trusted Launch VMs — a large operational effort that slowed adoption. Microsoft’s new in‑place upgrade paths let many existing Gen2 VMs and most Uniform scale sets be converted to Trusted Launch with portal, Azure CLI, PowerShell, or ARM/Bicep automation, eliminating the need for mass reimaging in many common scenarios.
What Trusted Launch actually gives you​
  • Secure Boot — enforces cryptographic signing of bootloaders, kernels and kernel drivers so tampered or unsigned boot code cannot execute.
  • vTPM (TPM 2.0 semantics) — supplies an in‑guest TPM interface for key storage, BitLocker‑style protections and attestation artifacts.
  • Boot integrity monitoring & Guest Attestation — measured‑boot telemetry that can be consumed by Defender for Cloud to detect boot‑chain anomalies.
These components are more than checklist items: together they give a cryptographic root of trust on the VM and enable programmatic attestation workflows that can be used for compliance, automated enforcement, and forensic investigation. Trusted Launch also enables tighter Windows protections such as Hypervisor‑Enforced Code Integrity (HVCI) and Credential Guard where platform/OS combos support them.
What Microsoft announced and what’s GA vs preview​
  • Enabling Trusted Launch in‑place on existing Gen2 VMs is documented and available; the portal, CLI and PowerShell all include upgrade flows.
  • Uniform Virtual Machine Scale Sets (VMSS) have upgrade guidance and supported rolling‑upgrade modes.
  • Gen1 (BIOS) → Gen2 + Trusted Launch conversions exist but remain preview and carry more risk (disk layout changes, MBR→GPT conversion, irreversible steps); treat them as migration projects, not push‑button flips.
  • Flexible (Flex) scale set in‑place Trusted Launch conversions are currently offered via preview/private preview, not full GA.
  • Microsoft is also moving Trusted Launch to be the default for new Gen2 VM and scale set deployments via a Trusted Launch as default preview; templates can still override the default. This is rolling out as a subscription/feature flag preview. (techcommunity.microsoft.com)
The practical implication: for most modern Gen2 fleets the path to Trusted Launch is now operationally straightforward; for older Gen1 workloads, custom managed images, or Flex scale‑set topologies the upgrade remains a nontrivial project requiring thorough testing and backups.
How the in‑place upgrade works (high level)​
For a typical Gen2 VM the upgrade sequence is intentionally simple:
  • Stop / deallocate the VM.
  • Change the VM’s security type to TrustedLaunch (via portal, az cli, PowerShell, or ARM/Bicep). vTPM is enabled by default; Secure Boot must be explicitly enabled.
  • Start the VM and verify sign‑in, driver health, application functionality, and Defender for Cloud attestation telemetry.
For Uniform VM scale sets, Microsoft recommends a rolling upgrade pattern (with controlled max‑surge) to preserve availability for instances with attached data disks. Flex scale set conversions require the preview path and additional planning. Note: when you enable Trusted Launch using the portal you may be blocked for certain image sources (Managed image, Azure Compute Gallery images and some OS disk scenarios require scripted/API upgrades rather than the portal). Plan automation for bulk upgrades.
Key prerequisites and blockers you must verify first​
Before clicking upgrade, confirm the following — these conditions are enforced by Microsoft documentation and will catch many of the typical upgrade failures:
  • VM generation must be Gen2 (unless you plan to run the Gen1→Gen2 preview path and accept its risks).
  • VM size family must be Trusted Launch supported; not all sizes support Gen2/Trusted Launch. If your current size is unsupported you must resize to an equivalent supported family.
  • Guest operating system and build must be on the supported list (Microsoft publishes a detailed OS table). Older OS versions and some Linux distributions are specifically excluded from Gen1→Gen2 preview flows.
  • Azure Backup: if backup protection is enabled, the VM must be protected using the Enhanced Backup policy; Standard backup policies are not compatible with Trusted Launch upgrades without migration to Enhanced. Azure Backup migration guidance exists for moving from Standard → Enhanced.
  • Azure Site Recovery (ASR): VMs that are currently replicated by ASR require special handling — you must disable ASR replication and uninstall the mobility/ASR extension before converting; the portal will block migrations in some cases and other channels (CLI/PowerShell) allow it but only after ASR is disabled. Plan re‑enabling ASR protection after upgrade if needed. (docs.azure.cn)
  • Managed images and certain Azure Compute Gallery scenarios may not be eligible for portal upgrades; scripted/API upgrades will be required.
If any of these prerequisites are unmet, the upgrade will either fail or create a VM that cannot boot without remediation. Microsoft’s guidance is explicit: take backups and create restore points first.
Real operational risks and compatibility gotchas​
Trusted Launch is powerful, but it changes the VM boot surface and interacts with kernel‑mode components. The main risk areas to plan for:
  • Driver and kernel module compatibility — Secure Boot rejects unsigned kernel modules. Legacy or vendor drivers (EDR/antivirus kernel drivers, some GPU drivers) may require re‑signing, special installation steps, or even temporary Secure Boot disablement during driver installation. Linux GPU stacks, in particular, often require driver workarounds.
  • MBR→GPT and EFI partition conversions (Gen1→Gen2) — this is the most invasive upgrade. The conversion can fail, and once converted rollback isn’t a simple toggle; you must restore from pre‑upgrade backup/restore point. Microsoft warns that the Gen1 conversion is essentially irreversible without a restore.
  • Patch interactions — adding Trusted Launch (or leaving VMs in mixed Trusted vs Non‑Trusted states) alters how Windows virtualization‑based security and hypervisor interactions behave. There are real examples of updates that caused boot issues in edge configurations; emergency updates have been published to fix some VM launch bugs. Expect to validate patch cycles during pilot testing.
  • Scale set constraints — Uniform scale sets with attached data disks must use rolling upgrades with max surge; choosing the wrong upgrade mode can cause disruption. Flex scale set behavior is still in preview and lacks parity in some features.
  • Managed images and ACG — some image sources cannot be upgraded through the portal or without extra steps; automation will be required at scale.
  • Backup cost and behavior — Enhanced Backup policy supports Trusted Launch but adds snapshot/restore behavior and potential cost changes; once moved to Enhanced the policy type cannot be changed back to Standard. Test restores, not just backup success.
These caveats mean Trusted Launch adoption must be treated as a program (inventory → pilot → validate → staged rollout), not an overnight checkbox.
Rollback and restore model​
There is no universal “undo” button. Rollback semantics depend on the upgrade path:
  • For Gen2 → Trusted Launch the documented rollback is to set the VM’s securityType back to Standard (API/CLI) or unregister preview flags — but portal rollback may be limited. Microsoft documents a feature flag for rollbacks in preview contexts. Still, the safest rollback is a full restore from a pre‑conversion backup or restore point.
  • For Gen1 → Gen2 conversions the only safe undo is restoration from pre‑upgrade backups because the MBR→GPT disk changes are not trivially reversible. Microsoft explicitly warns operators that this conversion is irreversible by simple configuration change.
  • If ASR was protecting the VM pre‑upgrade, migrating to Trusted Launch will disable ASR protection for that instance; re‑enable ASR only after validating the upgraded VM.
Best practice: take both a full backup and an Azure restore point, verify the ability to rehydrate in a test subscription or resource group, and rehearse the restore steps before advancing to production rings.
Compliance, cost, and telemetry​
  • Pricing: Microsoft documents that Trusted Launch does not add a separate VM price premium — the change is configuration only. That eliminates a financial disincentive for adoption.
  • Compliance: Trusted Launch helps satisfy controls in the Azure Security Benchmark and provides attestation artifacts useful for compliance baselines (FedRAMP, HIPAA, PCI‑DSS), but it’s an enabling control — it does not, by itself, deliver certifications. Use Defender for Cloud’s Guest Attestation telemetry for continuous auditing.
  • Telemetry & SOAR: Measured‑boot telemetry and guest attestation integrate with Defender for Cloud and can feed into security operations workflows, enabling early detection of boot‑chain tampering and automated policy enforcement. Operational teams should wire these signals into monitoring and incident response playbooks.
A pragmatic rollout plan (recommended)​
Follow a disciplined, staged rollout to minimize risk:
  • Inventory and triage
  • Catalog VMs by Generation (Gen1/Gen2), VM size family, OS build, attached data disks, and backup policy.
  • Flag managed images, compute gallery images, and ASR‑protected instances for special handling.
  • Pilot on non‑production Gen2 VMs
  • Include Windows and Linux variants plus one Uniform scale set and a representative stateful app.
  • Validate sign‑in, EDR/backup agents, GPU driver behavior, and Defender for Cloud attestation results.
  • Test Gen1→Gen2 flows in an isolated lab (if required)
  • Use MBR2GPT in lab VMs, exercise full restores and rehydration, and confirm irreversibility of disk changes before any production attempt.
  • Automate and stage the rollout
  • Build ARM / Bicep / PowerShell scripts for bulk changes, use rolling upgrade modes for scale sets, and include post‑upgrade smoke tests.
  • Monitor and audit
  • Enable Guest Attestation, monitor boot integrity telemetry in Defender for Cloud, and maintain a retention window for pre‑upgrade backups.
  • Update IaC and CI/CD pipelines
  • If your subscription registers the “Trusted Launch as default” preview, review and update templates to explicitly set securityProfile.securityType where you need non‑Trusted behavior.
Automation and policy considerations​
  • If you manage infrastructure via IaC, include explicit securityProfile.securityType values in templates to avoid surprises when the Trusted Launch default preview is enabled at subscription level. Microsoft’s TLaD (Trusted Launch as Default) preview will flip the default for templates that omit an explicit securityProfile. (learn.microsoft.com)
  • Use Azure Policy to enforce or deny Trusted Launch deployments according to corporate policy; this is a practical control if you need to prevent default Trusted Launch in some organizational units.
Strategic analysis — strengths and long‑term implications​
  • Operationally feasible security uplift: The in‑place conversion for Gen2 and Uniform scale sets removes the largest barrier to adoption — reimaging and redeployment overhead — making platform‑rooted boot security practical at scale. This is a material win for cloud security posture management.
  • Supply‑chain and signing discipline: Trusted Launch pushes more responsibility to image pipelines, driver vendors, and CI/CD — unsigned or poorly managed drivers will become blockers. Organizations must enforce signing, SBOM hygiene, and secure key management for signing keys.
  • Attestation enables automation: Measured‑boot telemetry lets security teams build automated gating (deny access or escalate on attestation failures), which is a powerful instrument for continuous compliance.
Where to be cautious — realistic limits​
  • Trusted Launch is not a silver bullet: strong attestation depends on trusted image signing and secure CI/CD. If an attacker compromises the signing key or inserts malicious code before signing, Trusted Launch will happily boot the signed, malicious image. Governance around signing keys and release pipelines remains paramount.
  • Don’t rush Gen1 conversions: the irreversible disk layout operations demand backup‑first discipline and ample lab testing. For many estates a pragmatic approach is to reimage critical Gen1 workloads to Trusted Launch–capable Gen2 images during scheduled maintenance windows rather than relying on preview upgrades.
  • Watch for patch interactions: a mixed estate of Trusted and non‑Trusted VMs can create subtle update and hypervisor interaction issues; emergency updates and hotfixes have previously been required to address VM launch problems in edge cases. Plan patch validation in pilot rings.
Quick operational checklist (two‑minute read)​
  • Inventory: Gen, OS, VM size, backup policy, ASR, managed image/ACG status.
  • Backups: take full backups + create restore points; verify restores.
  • Pilot: test on non‑prod Gen2, test driver installs and EDR agents.
  • ASR: disable replication and uninstall ASR extensions before upgrading ASR‑protected VMs; re‑enable after validation if necessary.
  • Scale sets: use rolling upgrades with surge for Uniform VMSS; treat Flex as preview.
  • Automation: update ARM/Bicep and CI/CD to explicitly set securityProfile or adjust to Trusted Launch default as appropriate. (learn.microsoft.com)
Microsoft’s rollout of in‑place Trusted Launch upgrades for Azure VMs and Uniform scale sets is a practical, high‑value security advance: it removes the reimaging barrier that kept many fleets from adopting foundational boot‑chain protections, and it makes Verified Boot + vTPM + attestation a realistic baseline for cloud deployments. However, the operational tradeoffs are real — driver signability, disk layout conversions, backup and restore discipline, ASR interactions, and scale‑set upgrade modes require a methodical, test‑first program.
For most modern Gen2 estates the immediate path forward is clear: run a short non‑production pilot, validate EDR and driver behavior, verify backup/restore procedures, and then roll Trusted Launch out in rings using automation. For Gen1 workloads, managed‑image estates, and Flex scale‑set scenarios treat the upgrade as a controlled migration project and budget time for reversibility testing.
The payoff is meaningful: stronger boot‑time guarantees, improved attestation telemetry, and better alignment to compliance baselines — all without an ongoing per‑VM price premium. The technical and governance work to lock down signing pipelines and patch validation will be the real determinant of long‑term success.
Source: Petri IT Knowledgebase Azure VMs Get Support for Trusted Launch In-Place Upgrade
