Indholdsindeksets katalog er beskadiget
Hvad gør man ovennævnte fejl (Windows 7 64 bit)?
Peter
davidhk129
This is English language forum.
If you can read English, please try the following methods..............
Det er engelsk forum.
Hvis du kan læse engelsk, kan du prøve følgende metoder ..............
Method 1:
Follow these steps:
Click “Start.
Type “services.msc” in the Start search box > press “Enter.”
Right-click “System Event Notification Service” > click “Properties.”
In the “Startup type” list, select “Manual.”
Click “Start” to start the service.
Click “Apply” and click “OK.”
Method 2:
Run a System File Checker (SFC) and see if that fixes the issue.
SFC tool scans system files and replaces incorrect versions of the system files by using the correct versions.
See How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
