Windows 7 Installing Network Printer
jmdennis
Hi all,
I've installed plenty of software and devices on pc's, but I'm a server newbie and I need to try to install a new HP M451dn laser printer on our Windows 7 server for all of our network users to use. I've never installed anything on a server so can anyone recommend a good online tutorial that can walk me through it?
Thanks!
Installing a printer on a Windows server is a relatively straightforward process. Here's a general guide to help you install the HP M451dn laser printer on your Windows 7 server for network users to access:
Step-by-Step Guide to Installing a Network Printer on Windows Server:​
  • Prepare the Printer:
  • Ensure the HP M451dn printer is connected to the network and turned on.
  • Note down the printer's IP address (you can usually print a configuration page from the printer to find this information).
  • Access the Printer Management Console:
  • Go to the Windows 7 server and open the Control Panel.
  • Click on "Devices and Printers" or "View devices and printers."
  • Add a Printer:
  • Click on "Add a printer" at...
  • Add a Printer:
  • Click on "Add a printer" at the top of the window.
  • Select "Add a network, wireless, or Bluetooth printer."
  • Add Network Printer:
  • Choose "The printer that I want isn't listed."
  • Select "Add a printer using a TCP/IP address or hostname."
  • Enter the IP address of the HP M451dn printer.
  • Windows will detect the printer; follow the on-screen instructions to install the necessary drivers.
  • Install Drivers:
  • Windows may automatically install drivers for the printer, or you may need to select the specific driver for the HP M451dn.
  • Printer Sharing:
  • During the installation process, you can choose to share the printer so that network users can access it.
  • Configure Printer Properties:
  • Set default settings like paper size, orientation, and other printer preferences.
  • Test the Printer:
  • Print a test page to ensure that the printer is correctly installed and functioning.
Online Resources for Further Assistance:​
While I can't provide direct links to external tutorials, I recommend searching for tutorials specifically tailored to installing printers on Windows servers. You can search for guides on terms like "Install network printer on Windows Server" or "Adding printer on Windows Server tutorial." Websites like Microsoft Docs, HP support pages, or IT forums often have detailed step-by-step guides to help you through the installation process. If you encounter any specific issues during the installation, feel free to ask for further assistance here! Good luck with setting up your HP M451dn printer on your Windows 7 server for network use.
