- Joined
- Jun 27, 2006
- Messages
- 23,048
- Thread Author
- #1
It's Winter Break for many of us and being the geeks we are, we're looking for something to develop...
When kicking off a new project, many times it can really help starting from an existing Project Template.
We've highlighted the cool UWP templates from FirstFloor before, Go beyond "Blank App" with these Windows 10 VS 2015 Project Templates and they've not been idle. Recently the templates have been rebranded as the Link Removed...
Once you've created your UWP app, one of the drudgery steps can be dealing with all the logo you'll need.
That's where this Project will come in VERY handy...
This is a Visual Studio extension that allows for easy logo image creation. It takes large source images (square and wide) and creates resized copies that are used for app logos and splash screens in Windows Universal Apps.
Right click any .png image and choose the new "Scale image..." context menu item.
If the file already has a scale (like scale-400.png) in its filename, then you will be given the option to generate the smaller scales.
If the file doesn't have a scale-xxx in its name, then you will be given the option to generate either square or wide images for Windows Universal App manifests. Depends on if your image is a square or not. It's best to start with really large images so that a lot of smaller scales can be generated.
Thanks!
Here’s a few more links you might find interesting:
Continue reading...
Intense
Controls, templates, and tools for building Universal Windows Platform apps on Windows 10. The Intense toolkit consists of two parts; a library of controls and helpers distributed as NuGet package, and a Visual Studio extension with project templates for creating new UWP apps.
Intense Templates
Adds new project and item templates to Visual Studio 2015 for creating Universal Windows apps. The templates are available in both C# and Visual Basic flavors.
The project templates are designed for both desktop and mobile scenarios. The adaptive layout ensures your app looks great on screens of any size, and is a perfect fit for Continuum.
Link Removed enables your mobile app to run on a large screen with keyboard and mouse support.
Installation
Download the VSIX installer from the Link Removed. Alternatively, search for intense in the Extensions and Updates dialog in Visual Studio 2015.
Intense Templates
- Link Removed
- Link Removed
- Link Removed
- Link Removed
- Link Removed
- Link Removed
Installation
Thanks!
- Turning your Windows 10 Project Templates up to 10 with Template10!
- Go beyond "Blank App" with these Windows 10 VS 2015 Project Templates
Continue reading...
