VIDEO Is CPU Cooler Weight A Concern ???
whoosh
Cooler King
:zoned:
Is CPU Cooler Weight A Concern ??? In the latest video from Byte Size Tech titled "Is CPU Cooler Weight A Concern ???", the discussion revolves around the implications of using heavy CPU tower coolers on motherboards, particularly in scenarios involving transportation and frequent movement of desktop PCs. The video features a question by Mike, exploring whether the weight of tower coolers could damage motherboards over time and in various use cases.
Key Insights from the Video:​
  1. Weight's Impact on Mobility:
    • The primary concern regarding CPU cooler weight is when the system is frequently moved, such as during travels or relocations. If a desktop PC with a heavy cooler like the Noctua NH-D15 is stationary, the added weight does not pose much of an issue. However, if the computer is moved often—like during car rides or to conventions—this can become a factor as it may place stress on the motherboard.
  2. Quality of the Motherboard:
    • Premium motherboards are generally built to handle the weight of larger CPU coolers better than budget options. These premium boards often have more layers, greater thickness, and even reinforced backplates that distribute weight more effectively.
  3. Alternatives for Frequent Movers:
    • For users who transport their PCs frequently, liquid cooling solutions are suggested as a preferable alternative. Liquid coolers typically weigh less and reduce the risk of damaging the motherboard since they don't rely on a large heat sink.
  4. Consideration of Use Cases:
    • The presenter highlights that careful handling during upgrades or movements can mitigate concerns about weight. If users are cautious when lifting and transporting their PCs, the risk of damage is significantly lowered.
  5. Bonus Question About BIOS Updates:
    • The video also touches on the expected BIOS updates for upcoming AMD CPUs, noting that while new CPUs often require updates, platforms like B550 and X570 have matured and should not need extensive updates, ensuring stability for new hardware.
      Final Thoughts​
      This video serves as a reminder that while the weight of a CPU cooler can be a concern, it largely depends on how often and aggressively a PC is moved. For stationary setups, the weight of the cooler is less critical as long as the motherboard is of good quality. What are your thoughts? Do you think the weight of CPU coolers affects your build? Have you ever experienced issues with heavy coolers on your motherboards during transportation? Feel free to share your experiences or ask any further questions!
