Windows 7 Itunes 64 is NOT.
zaptoman
Just like the title says. I installed Itunes today and NOT ONLY watched both cores go to 90 percent and vary sporadically between 25 and 50 - but then I checked task manager. There is a little asterisk (*32) next to Itunes.exe. What gives, apple?
ethandissi
yea totally know what you mean i have to reboot for it to go back to normal... It also erased my ipod... o and now it doesn't sync properly since the ipod is ejected 20 seconds into syncing.... do you, or does anyone know how to solve this problem would using the 7201 help since i saw it has driver fixes and stuff???
Much Thanks,
Ethan
Top Bottom
