Cybersecurity operations center with a shield, threat alerts, bug icons, encrypted data, and locked storage.
Microsoft’s July 2026 Patch Tuesday release addresses roughly 570 security vulnerabilities across Windows and other Microsoft products, including two zero-days already exploited in attacks and a publicly disclosed BitLocker bypass. Windows 11 users should prioritize KB5101650 or KB5099414, while administrators running Active Directory Federation Services and on-premises SharePoint Server face the most urgent exposure.
The record-setting total was first reported by BleepingComputer, which counted 570 vulnerabilities released on July 14. Microsoft’s Security Update Guide supplies the underlying advisories, although totals published by security firms vary because they count CVEs, product entries, Chromium fixes, and updates issued earlier in the month differently.
This is not simply a bundle of 570 flaws in the Windows desktop operating system. The release spans Microsoft’s wider product portfolio, with Windows components, SharePoint Server, AD FS, Office, developer tools, and server technologies represented across the advisories.
Three Zero-Days Move to the Front of the Queue​
CVE-2026-56155 is an elevation-of-privilege vulnerability in Active Directory Federation Services. Microsoft says insufficiently granular access controls in AD FS can let an authorized local attacker elevate privileges and obtain administrative capabilities.
Microsoft Detection and Response Team members Jeremy Kingston and Scott Clark discovered the flaw, suggesting it surfaced during incident-response work. Microsoft has not disclosed the attacks, affected organizations, or initial access method, leaving defenders without indicators that would help them determine whether exploitation has already occurred in their environments.
The associated AD FS hardening involves the access control list for the Distributed Key Manager container. Administrators should review Microsoft’s CVE-2026-56155 guidance and KB5121391 rather than treating the standard Windows cumulative update as the entire remediation plan.
CVE-2026-56164 affects Microsoft SharePoint Server and permits elevation of privilege over a network. Microsoft describes the underlying weakness as missing authentication for a critical function, potentially allowing an unauthorized attacker to gain elevated access remotely.
The SharePoint flaw was reported by researchers associated with Mandiant Incident Response, Google Cloud and FLARE OTF, along with an anonymous researcher. As with the AD FS vulnerability, Microsoft has confirmed exploitation but has not explained how attackers are using it.
Organizations unable to patch SharePoint immediately can reduce exposure by enabling Antimalware Scan Interface integration and setting Request Body Scan mode to Full, according to Microsoft’s guidance. That mitigation should be treated as a temporary control, not a substitute for installing the security update and checking the server for signs of compromise.
The third zero-day, CVE-2026-50661, is a Windows BitLocker security-feature bypass. An attacker with physical access could reportedly bypass BitLocker Device Encryption on the system drive and obtain encrypted information.
Microsoft says it is not aware of active exploitation of CVE-2026-50661, but the vulnerability was publicly disclosed before a fix became available. Its physical-access requirement reduces the risk for most home systems, although it matters considerably for lost laptops, stolen corporate devices, shared workstations and computers handled by untrusted personnel.
The Record Number Needs Some Accounting​
BleepingComputer categorized the July release as 254 elevation-of-privilege flaws, 145 remote-code-execution vulnerabilities, 102 information-disclosure bugs, 35 denial-of-service flaws, 17 security-feature bypasses and 16 spoofing vulnerabilities. Its count identifies 59 vulnerabilities as Critical, including 48 remote-code-execution bugs.
Those categories add up to 569 rather than 570, illustrating why Patch Tuesday totals should not be treated as a perfectly standardized metric. Tenable reported 569 CVEs and 56 Critical vulnerabilities, while SecurityWeek used a broader count of 622 vulnerabilities. Differences can arise from revisions, duplicate product listings, Microsoft and third-party CVEs, and the inclusion or exclusion of fixes released outside the main Patch Tuesday window.
BleepingComputer excluded hundreds of Chromium vulnerabilities already fixed by Google and inherited by Microsoft Edge. It also excluded vulnerabilities addressed earlier in July in products and services including Azure OpenAI, Microsoft 365 Copilot, Exchange Online, Microsoft Entra Provisioning Service and Edge for Android.
The defensible conclusion is that July 14 delivered Microsoft’s largest Patch Tuesday release to date under the commonly used CVE-counting methods, substantially surpassing June 2026’s roughly 200 fixes. The precise headline figure matters less operationally than the presence of two exploited zero-days and a large set of Critical remote-code-execution vulnerabilities.
The sudden growth also does not necessarily mean Microsoft software became dramatically less secure in one month. Microsoft recently said it is using AI-assisted vulnerability discovery to identify weaknesses across the Windows codebase before attackers find them. More aggressive internal discovery can produce a larger patch count while reducing long-term exposure, though administrators still inherit the immediate testing and deployment burden.
Windows 11 Builds Advance With Security and Compatibility Changes​
Windows 11 versions 24H2 and 25H2 receive KB5101650, moving supported systems to OS builds 26100.8875 and 26200.8875 respectively. Windows 11 version 23H2 receives KB5099414 and advances to build 22631.7376.
Microsoft says it is not currently aware of any problems with either Windows 11 update. That status can change as deployment expands, so enterprises should continue staged rollouts and monitor the Windows release health dashboard rather than assuming a day-one clean bill of health guarantees broad compatibility.
The cumulative updates also contain changes beyond the July CVEs. Windows now includes curl 8.21.0, while Remote Desktop gains support for SHA-2 certificate thumbprints for trusted RDP publishers. SHA-1 remains available for compatibility but is scheduled for eventual removal, giving administrators another reason to audit policies and signed .rdp files.
A networking hardening change may have more immediate consequences. Applications using sockets over unregistered third-party Transport Driver Interface transports may stop working after installing updates released on or after July 14, 2026. Registered TDI transports are unaffected, but organizations with old networking, security or industrial software should include those applications in compatibility testing.
The update also continues Microsoft’s rollout of replacement Secure Boot certificates. Certificates used by many Windows devices began reaching expiration in June 2026, and Microsoft has been delivering newer certificates through Windows Update. Systems that have not yet received them should continue booting and accepting normal updates, but managed fleets should verify certificate readiness rather than relying solely on the automatic consumer rollout.
Patch Fast, but Test the Infrastructure Around It​
Home users can install the July updates through Settings, Windows Update and Check for updates. Because Windows security updates are cumulative, installing the current package also brings in earlier fixes missing from the device.
Enterprise administrators have a more complicated task. AD FS and SharePoint Server should receive priority because exploitation is confirmed, followed by internet-facing servers, Remote Desktop infrastructure and machines carrying sensitive BitLocker-protected data.
A practical deployment order is to patch exposed identity and collaboration servers first, examine logs and endpoint telemetry for suspicious activity, and then accelerate workstation and general server rings after essential application tests. Organizations using custom TDI transports should validate network-dependent applications before broad deployment, but that compatibility concern should not become a reason to leave exploited SharePoint or AD FS systems exposed.
Windows 11 24H2 Home and Pro also reach end of servicing on October 13, 2026, while Windows 11 23H2 Enterprise and Education reach that milestone on November 10, 2026. July’s unusually large release therefore arrives as some administrators must manage both an urgent security rollout and migrations to versions that will continue receiving fixes after the autumn support deadlines.
Update: Cisco Talos Releases Snort Rules for July Vulnerabilities (July 14, 2026)​
Cisco Talos has released Snort 2 and Snort 3 signatures designed to detect attempted exploitation of some vulnerabilities addressed in Microsoft’s July security release. Cisco Security Firewall and Snort users should install the latest rule updates, although Talos cautions that signatures may change as additional technical details emerge.
Talos also highlighted critical, unauthenticated remote-code-execution flaws affecting Windows DHCP Server and SharePoint Server. The SharePoint issues, CVE-2026-50522 and CVE-2026-58644, involve unsafe deserialization and add further urgency for administrators already responding to actively exploited CVE-2026-56164.
The signatures provide an additional monitoring layer for detecting probes and possible exploitation before or during patch deployment. They do not replace Microsoft’s updates or establish that systems have not already been compromised. Security teams should update detection rules, accelerate patching of exposed SharePoint and AD FS infrastructure, and investigate relevant alerts and historical activity.
Update: Microsoft Urges Quality Updates Within Three Days (July 15, 2026)​
Microsoft has tightened its deployment guidance, recommending that organizations defer Windows quality updates for fewer than three days. Microsoft suggests setting update deadlines to zero or one day and limiting the grace period to no more than two days, with Intune and Windows Autopatch offered as deployment options.
Microsoft attributes the growing volume and urgency of security fixes partly to AI accelerating vulnerability discovery for both defenders and attackers. Its multi-model MDASH scanning system reportedly identified 16 significant vulnerabilities in Windows networking and authentication components, including four Critical remote-code-execution flaws.
For administrators, the revised guidance favors rapid, policy-enforced deployment over lengthy deferral periods. Organizations should still perform essential compatibility checks, particularly around July’s TDI transport changes, but Microsoft’s position is that routine quality updates should reach managed devices within days rather than weeks.
Update: July Update Adds Automatic Point-in-Time Restore (July 15, 2026)​
Techlicious reports that the July Windows update also introduces Point-in-Time Restore, a recovery feature that automatically creates system snapshots every 24 hours. Users can restore a malfunctioning PC from the Windows Recovery Environment if an update, driver, or configuration change prevents normal operation.
The feature is reportedly enabled by default on Windows Home and Pro devices with system drives of at least 200GB. This gives eligible users another recovery option, but organizations should assess the feature’s storage, management, and security implications before relying on it.
Techlicious also discusses the publicly disclosed BitLocker bypass. Contrary to its framing, Microsoft’s advisories identify the actively exploited vulnerabilities as the AD FS and SharePoint flaws; Microsoft has not reported active exploitation of the BitLocker issue.
Update: July Update Improves Shutdown Speed and File Explorer Reliability (July 15, 2026)​
PCMag reports that the July cumulative update also includes several user-facing improvements beyond its security fixes. Microsoft says the update should accelerate shutdowns and improve File Explorer’s performance and reliability.
The release also adds an option to resize the touchpad’s right-click zone, giving laptop and touchpad users more control over how secondary clicks are recognized.
These changes provide practical quality-of-life benefits, but the update’s security fixes remain the primary reason to deploy it quickly. Organizations should verify the File Explorer and shutdown improvements during staged testing while continuing to prioritize systems exposed to the actively exploited vulnerabilities.
  1. Microsoft ships record Patch Tuesday fixing active attacks - Techlicious Techlicious Wed, 15 Jul 2026 00:21:36 GMT
  2. CVE-2026-56164: Patch Exploited SharePoint and AD FS Zero-Days blog.talosintelligence.com
  3. support.microsoft.com support.microsoft.com
Hacker in hoodie shields data as blue and red cyber shields and code lines clash.
Additional coverage of this story: CVE-2026-56164: Patch Exploited SharePoint and AD FS Zero-Days
Cisco Talos counts 622 disclosures, including 57 critical flaws, and provides Snort 2 and 3 detection rules. It highlights Internet-facing SharePoint farms, external AD FS flows, and suspicious authentication or web activity as priorities alongside patching.
  • windowsforum-cve-2026-56164-patch-exploited-sharepoint-and-ad-fs-zero-days.webp
Story update: Cisco Talos Releases Snort Rules for July Vulnerabilities — the article above has been updated.
  • windowsforum-july-2026-patch-tuesday-fix-2-exploited-ad-fs-and-sharepoint-zero-days.webp
Story update: Microsoft Urges Quality Updates Within Three Days — the article above has been updated.
Story update: July Update Adds Automatic Point-in-Time Restore — the article above has been updated.
Futuristic data center with glowing blue shield, network nodes, and explosive red cyber effect.
Additional coverage of this story: CVE-2026-56164 SharePoint Exploit: Patch July 14 Now
It emphasizes that exploited SharePoint flaw CVE-2026-56164 has only a 5.3 Moderate rating but is in CISA’s Known Exploited Vulnerabilities catalog, and identifies SharePoint 2016, 2019 and Subscription Edition as affected.
Cybersecurity server tower with glowing shield, attackers, and red electric shards amid neon blue data streams.
Additional coverage of this story: CVE-2026-56164: Patch Exploited SharePoint Server Flaw Now
Petri and Trend Micro’s Zero Day Initiative count 621 CVEs, including 63 Critical issues, and highlight CISA’s addition of the exploited SharePoint flaw to its Known Exploited Vulnerabilities catalog. They also prioritize Hyper-V’s CVE-2026-57092, rated 9.9.
  • windowsforum-cve-2026-56164-patch-exploited-sharepoint-server-flaw-now.webp
Story update: July Updates Add Point-in-Time Restore and New Compatibility Risks — the article above has been updated.
Story update: July Update Improves Shutdown Speed and File Explorer Reliability — the article above has been updated.
Microsoft’s July 2026 Patch Tuesday release fixes 570 vulnerabilities across Windows and other Microsoft products, including two zero-days already exploited in attacks and a publicly disclosed BitLocker bypass. Windows users should install the July 14 cumulative updates promptly, while administrators responsible for SharePoint Server and Active Directory Federation Services should treat this cycle as an urgent deployment rather than a routine monthly rollout.
The record total was detailed by BleepingComputer and corroborated by Microsoft’s Security Update Guide. It eclipses the more than 200 flaws addressed in June, but the headline needs qualification: Microsoft did not patch 570 defects solely in the Windows operating system. The count spans a broad portfolio including Windows, SharePoint Server, Office, .NET, Visual Studio, SQL Server and other Microsoft software.
The scale is still remarkable. BleepingComputer counted 254 elevation-of-privilege vulnerabilities, 145 remote-code-execution flaws, 102 information-disclosure bugs, 35 denial-of-service issues, 17 security-feature bypasses and 16 spoofing vulnerabilities. Those categories total 569 because Microsoft’s wider release also includes vulnerability types, such as tampering, that are not represented in that abbreviated breakdown.
Cybersecurity graphic highlighting a Windows update fixing 570 vulnerabilities and protecting servers, identity systems, and devices. Two Exploited Zero-Days Move Servers to the Front​
The most immediate concern is CVE-2026-56164, an elevation-of-privilege vulnerability in Microsoft SharePoint Server. Microsoft says attackers are already exploiting the flaw, which stems from missing authentication for a critical function and can be reached over a network by an unauthenticated attacker.
That combination makes on-premises SharePoint installations the obvious first priority. An internet-facing collaboration server is a materially different risk from a desktop vulnerability requiring an attacker to have an existing local foothold, particularly when Microsoft has already observed exploitation.
Microsoft credited researchers from Mandiant Incident Response, Google Cloud and FLARE, along with an anonymous researcher, for reporting the SharePoint issue. The relevant July updates include KB5002882 for SharePoint Server Subscription Edition, with separate packages available for supported SharePoint releases.
Administrators should inventory every on-premises SharePoint farm, verify the installed product and patch level, and avoid assuming that ordinary Windows Update policies will cover the application server. SharePoint security updates have their own deployment and post-installation considerations, including the need to run the appropriate configuration process across the farm.
The second exploited zero-day, CVE-2026-56155, affects Active Directory Federation Services. It is an elevation-of-privilege vulnerability discovered by Jeremy Kingston and Scott Clark of Microsoft’s Detection and Response Team.
CVE-2026-56155 requires local access, making it less directly exposed than the SharePoint flaw. It remains significant because AD FS occupies a sensitive identity role: an attacker who has already reached a federation server may be able to turn limited access into more powerful control. Organizations that still operate AD FS should patch those servers quickly and review security telemetry for suspicious local access or privilege changes.
These are not merely theoretical weaknesses promoted by a high monthly count. Microsoft’s exploited designation means attacks were observed before broadly available fixes arrived, even though the company has not publicly described the campaigns, victims or scale of exploitation.
BitLocker’s Physical-Attack Boundary Gets Another Repair​
The third zero-day, CVE-2026-50661, is a Windows BitLocker security-feature bypass. It was publicly disclosed before the July update, but Microsoft had not reported active exploitation when the patches were released.
The flaw involves a protection-mechanism failure that could permit an unauthorized attacker with physical access to bypass a BitLocker security control and reach encrypted data. That requirement narrows the practical threat for a desktop secured inside an office, but it matters considerably for laptops, removable systems, kiosks and machines exposed to theft or hands-on tampering.
A physical-access requirement should not be mistaken for a harmless flaw. BitLocker is specifically intended to protect data when a device leaves its owner’s control, so a bypass in that scenario cuts into the feature’s core security promise.
Organizations managing mobile fleets should therefore include the July Windows update in their BitLocker compliance checks rather than treating disk encryption as sufficient by itself. Recovery keys should remain escrowed and tested, firmware should be current, and high-risk systems should use appropriate preboot authentication policies where operationally feasible.
For home users, the practical action is simpler: confirm that Windows Update completed successfully and that a BitLocker recovery key is stored somewhere accessible before restarting. Installing security updates without knowing where that key resides can turn an otherwise ordinary recovery prompt into a lockout.
The Record Number Is Less Useful Than the Attack Path​
Fifty-nine vulnerabilities in Microsoft’s July count are rated Critical, including 48 remote-code-execution flaws, nine elevation-of-privilege vulnerabilities, one security bypass and one spoofing issue. That is a substantial attack surface, but severity labels and raw totals do not provide a complete deployment order.
A remotely exploitable flaw on an exposed server generally deserves attention before a local privilege-escalation bug on an isolated workstation. Likewise, a vulnerability known to be exploited should move ahead of a higher-scoring issue for which Microsoft considers exploitation unlikely.
For enterprise teams, a defensible July sequence is straightforward:
  • On-premises SharePoint Server systems should receive the CVE-2026-56164 updates first, especially when they are reachable from the internet.
  • AD FS servers should follow quickly because CVE-2026-56155 is under active exploitation and affects identity infrastructure.
  • BitLocker-protected laptops and other devices at elevated risk of theft or physical access should be prioritized for CVE-2026-50661.
  • Remaining Windows clients, servers, Office installations, developer tools and Microsoft applications should proceed through accelerated testing and deployment.
The record also reflects how vulnerability counting can differ between reports. BleepingComputer’s 570 figure excludes Microsoft flaws fixed earlier in July in products and services such as Azure OpenAI, Microsoft 365 Copilot, Exchange Online, Entra Provisioning Service and Edge for Android. Other security publications have cited totals above 600 by combining Patch Tuesday with those earlier releases.
That does not make either number inherently wrong; it means administrators should not use a single headline figure as an asset inventory. The Security Update Guide, Microsoft Update Catalog, product-specific advisories and an organization’s own software records remain the reliable way to determine exposure.
July’s Windows Updates Carry Compatibility Changes Too​
For Windows 11 versions 25H2 and 24H2, the principal cumulative package is KB5101650, advancing the systems to OS builds 26200.8875 and 26100.8875 respectively. Microsoft says it is not currently aware of any issues with that update, although the release includes more than vulnerability repairs.
KB5101650 upgrades the built-in curl utility to version 8.21.0 and adds SHA-2 certificate-thumbprint support for trusted Remote Desktop publishers. It also continues Microsoft’s deployment of replacement Secure Boot certificates ahead of certificate expirations that began in June 2026.
One hardening change deserves testing in specialized environments. Microsoft warns that applications using sockets over unregistered third-party Transport Driver Interface transports may stop working after security updates released on or after July 14. The change affects supported editions across Windows 10, Windows 11 and Windows Server, while registered TDI transports are not affected.
That caveat is unlikely to trouble a normal home PC, but it could surface in legacy networking, security or industrial software. Administrators should test applications with low-level network dependencies rather than using the size of the release as justification for bypassing validation altogether.
Windows 11 Home and Pro systems on version 24H2 also have a separate deadline approaching: Microsoft lists October 13, 2026 as the end of monthly updates for those editions. The July patch protects them now, but moving to Windows 11 25H2 is the longer-term requirement.
Consumers can install the release through Settings, Windows Update and Check for updates. Enterprise teams face a more demanding job: patch the exploited SharePoint and AD FS paths immediately, validate the TDI hardening change, and then drive the remaining July updates through rings quickly enough that a record-breaking patch count does not become a record-sized window of exposure.
Update: SharePoint Zero-Day Added to CISA Exploited-Vulnerability Catalog (July 15, 2026)​
CISA has added CVE-2026-56164 to its Known Exploited Vulnerabilities catalog, reinforcing the need to patch exposed on-premises SharePoint Server farms immediately. Follow-up reporting also identifies a temporary Microsoft mitigation for organizations unable to deploy the update at once: enable the Antimalware Scan Interface and configure Request Body Scan mode to Full. This may help detect malicious POST requests but does not replace patching or compromise assessment.
The lifecycle implications are now clearer. SharePoint Server 2016 and 2019 reached the end of extended support on July 14, 2026—the same day this security update was released. It is therefore their final expected scheduled security baseline. Organizations retaining either release should install the July update, investigate potentially exposed systems, and accelerate migration to SharePoint Server Subscription Edition or SharePoint Online.
PCWorld’s newer coverage also highlights additional Critical SharePoint flaws, including CVE-2026-58644 and CVE-2026-50522, that may allow unauthenticated remote code execution through unsafe deserialization. Administrators should treat the complete SharePoint security package as an emergency deployment, not patch only the exploited CVE.
Glowing cybersecurity vault with a cracked USB-like key and red-blue data streams in a neon server room.
Additional coverage of this story: CVE-2026-56164: Patch Exploited SharePoint Zero-Day Now
The coverage adds that CISA has listed the exploited SharePoint flaw in its Known Exploited Vulnerabilities catalog and notes that SharePoint Server 2016 and 2019 reached end of extended support on July 14, leaving affected organizations to plan migration.
Story update: SharePoint Zero-Day Added to CISA Exploited-Vulnerability Catalog — the article above has been updated.
Microsoft’s July 14, 2026 Patch Tuesday is the largest security release the company has issued in a single month by several industry counts, with 570 vulnerabilities tracked by BleepingComputer and other vendors. The release includes two zero-days already exploited in attacks against on-premises SharePoint Server and Active Directory Federation Services (AD FS), plus a publicly disclosed Windows BitLocker bypass that raises the stakes for lost, stolen, and unattended PCs.
For Windows 11 24H2 and 25H2, the key client update is KB5101650, which advances systems to builds 26100.8875 and 26200.8870 respectively. Microsoft’s support documentation says the cumulative update also contains the prior month’s non-security changes, but the security story is what should drive deployment decisions this week.
The Cryptonomist’s report correctly captures the unusual scale of the release, though “570” is not the only total in circulation. SecurityWeek and Zero Day Initiative counted 622 Microsoft CVEs. The difference is methodological: researchers do not always count bundled advisories, product variants, Chromium-related fixes, and shared CVEs the same way. For IT teams, the practical conclusion is unchanged: July is an exceptionally large patch cycle, not a routine monthly maintenance window.
Cybersecurity operations center monitors a July 2026 patch with 570 vulnerabilities and active exploit alerts. The Exploited Flaws Are in AD FS and SharePoint, Not Generic Active Directory​
The two actively exploited vulnerabilities deserve to be prioritized ahead of the raw CVE count.
CVE-2026-56155 is an elevation-of-privilege vulnerability in Active Directory Federation Services. AD FS is often casually folded into “Active Directory” discussions, but it is a distinct federation role that issues and signs authentication tokens for applications that trust it. That makes an exploited weakness on an AD FS server consequential even if its severity score does not sound like a classic Internet-wide remote-code-execution emergency.
CVE-2026-56164 affects Microsoft Office SharePoint Server and is also an elevation-of-privilege issue under active exploitation. BleepingComputer and The Hacker News both reported that Microsoft marked the bug as exploited before the July patch release. Organizations with on-premises SharePoint, especially installations reachable from the internet or integrated tightly with sensitive internal workflows, should treat it as an urgent remediation item.
Microsoft has not publicly detailed the exploitation chains, which is normal when attacks are ongoing. Administrators should not read the lack of step-by-step exploit information as evidence of low risk. The vendor’s exploited designation is enough to move both patches to the front of the queue.
This is also a month to separate Microsoft 365’s hosted SharePoint Online service from on-premises SharePoint Server. The July zero-day is a server product concern; an organization relying entirely on SharePoint Online has a different exposure profile than one operating SharePoint Server Subscription Edition, 2019, or an older farm in its own data center.
There is an additional support deadline worth noting. NHS England’s cyber advisory says SharePoint Server 2016 and SharePoint Server 2019 reached end of support on July 14, 2026. Any organization still operating those versions is now confronting a familiar but uncomfortable combination: a high-priority patch month and software that no longer has a normal forward security path.
The BitLocker Zero-Day Changes the Physical-Access Calculation​
The third zero-day, CVE-2026-50661, is a Windows BitLocker security feature bypass vulnerability. Unlike the AD FS and SharePoint flaws, Microsoft is not aware of active exploitation, but the issue had been publicly disclosed before a fix was available.
The distinction matters. This is not a remote compromise that turns every Windows laptop into an immediate network exposure. The attack requires physical access to the device. But BitLocker’s job is specifically to protect data when the device is no longer in its owner’s hands, so a physical-access limitation is not a reason to dismiss the flaw.
For a desktop bolted under a receptionist’s desk, the risk may be manageable through ordinary physical security. For a corporate laptop in a hotel room, an endpoint in a retail location, a mobile field device, or a system awaiting disposal, the risk is more tangible. Organizations should patch it promptly, confirm that BitLocker recovery-key escrow is functioning, and avoid treating encryption as a substitute for physical controls.
July’s BitLocker fix also lands in an environment where administrators have already spent much of 2026 dealing with recovery prompts, Windows Recovery Environment trust issues, and Secure Boot certificate transition work. Test the update in representative hardware groups, but do not let a desire for perfect regression certainty become a blanket reason to defer an exploited-zero-day release.
KB5101650 Includes a Compatibility Change Administrators Should Test​
Microsoft lists no known issues for KB5101650 at publication time, but the release documentation contains an important compatibility warning: Windows is now enforcing Transport Driver Interface transport-registration requirements. Applications that use sockets through unregistered third-party TDI transports can stop working after the July update.
TDI is old Windows networking architecture, which means many modern organizations will never encounter the problem. The affected estate is more likely to include legacy security products, specialist networking utilities, industrial software, or internally developed applications carrying historical dependencies. That is precisely the type of breakage a conventional pilot ring can catch.
Microsoft also says KB5101650 fixes an issue in which some third-party applications using OLE Automation to interact with Microsoft Office could fail to launch Office or open documents after June’s KB5094126 security update. That is useful remediation for organizations that hit the June regression, but it should not be confused with a reason to skip normal post-deployment checks.
A second caveat applies to some Dell PCs with Intel processors. Microsoft says KB5101650 may be temporarily unavailable for a limited set of devices because Dell reported potential shutdowns, performance degradation, heat, and battery-drain problems. That is a targeted safeguard rather than a general withdrawal, but affected fleets should check their Windows Update and vendor-management status rather than attempting to force-install the package blindly.
The AI Narrative Needs More Restraint Than the CVE Total Suggests​
Microsoft’s May security blog introduced MDASH, short for multi-model agentic scanning harness, and said the internal system helped researchers find 16 vulnerabilities across Windows networking and authentication components. The company positioned the tooling as a way to accelerate vulnerability discovery while keeping humans responsible for validation and release decisions.
That background has encouraged a simple explanation for July’s record: AI found hundreds more bugs, therefore Patch Tuesday exploded. The evidence does not support such a direct conclusion. Microsoft has not said MDASH alone produced July’s 570 or 622-count release, and a record CVE total can reflect expanded code review, product breadth, coordinated disclosures, counting practices, and accumulated remediation work as much as one discovery tool.
Still, the operational direction is clear. If Microsoft’s discovery capacity rises, enterprises should expect vulnerability management to become more continuous rather than easier. More findings can improve security before criminals find the same defects, but they also create larger validation workloads, denser update packages, and less room for teams that rely on a long “wait and see” posture.
Patch the Exposed Services First, Then Move Through Client Rings​
This is a month for risk-based sequencing rather than a single all-or-nothing deployment decision.
  • Organizations running AD FS should identify every federation server, confirm its patch state, and review exposure and privileged-access pathways immediately.
  • Organizations with on-premises SharePoint Server should prioritize the actively exploited CVE-2026-56164, particularly for externally reachable farms and environments holding sensitive documents.
  • Windows client and server teams should deploy the applicable July cumulative updates through their normal pilot rings, with targeted testing for legacy networking software after the TDI enforcement change.
  • Endpoint teams should treat the BitLocker bypass as a priority for portable and remotely deployed devices, while confirming recovery keys and physical-asset controls.
The record-setting number will dominate headlines, but the deployment priority is narrower than 570 vulnerabilities suggests. AD FS and SharePoint Server owners have the most urgent work; everyone else should still move rapidly through July’s cumulative updates with the same discipline required by any patch cycle that includes active exploitation.
Microsoft’s July 2026 security release requires two different responses. Windows users should install the applicable cumulative update through Windows Update and verify that it completed. IT teams should separately assess exposed AD FS and SharePoint Server deployments and obtain the applicable product updates through Microsoft’s security-update resources, then move through a controlled Windows client rollout that accounts for a Dell compatibility hold, third-party networking guidance, Secure Boot recovery media, and approaching Windows 11 support deadlines.
Samaa’s July 16 report characterizes the release as addressing 570 reported vulnerabilities, including three zero-days affecting Active Directory Federation Services, SharePoint Server, and Windows BitLocker. It also reports 254 privilege-escalation flaws, 145 remote-code-execution flaws, 102 information-disclosure vulnerabilities, and 59 issues rated critical.
The total number is useful context, but deployment priority comes from where the reported zero-days sit. Identity infrastructure, collaboration servers, and encrypted endpoints have different attack and recovery models. A Windows cumulative update should not be treated as proof that server products such as AD FS or SharePoint Server have been remediated.
Who needs to act now​
  • Consumers and most Windows 11 users: Install KB5101650 or KB5099414, as applicable, through Settings > Windows Update.
  • Dell systems using Intel Innovation Platform Framework drivers: Wait for the temporary safeguard hold to be lifted rather than forcing the update.
  • AD FS and SharePoint Server owners: Obtain and apply the applicable separate product updates through Microsoft’s security-update guidance.
  • Deployment and endpoint teams: Test recovery media and relevant legacy networking software before broad rollout.
Pilot rings, rollout sequencing, exception tracking, and compensating controls described below are WindowsForum operational recommendations, not documented Microsoft deployment requirements.
Microsoft’s Windows release information also shows that July carries changes beyond the CVE list. The applicable Windows updates include third-party TDI transport guidance, an update to the bundled curl tool, Remote Desktop publisher certificate guidance, and ongoing Secure Boot certificate work. That makes testing important, especially for organizations with legacy networking software, custom deployment media, or long-lived RDP trust configurations.
July 2026 security graphic shows Windows Update, server protections, and Windows 11 support ending October 13. The Zero-Days Set the Patch Order​
The three named zero-days should be separated by product and ownership rather than treated as one generic Windows problem.
CVE-2026-56155 affects Active Directory Federation Services, or AD FS. Because AD FS is identity infrastructure and is often exposed to partners, remote users, or internet-facing authentication flows, administrators should determine whether their organization runs an affected deployment and consult Microsoft’s security-update guidance for the applicable product update.
CVE-2026-56164 affects Microsoft SharePoint Server. SharePoint commonly holds internal documents, workflows, intranet content, and connections to other business systems. SharePoint Server administrators should identify affected deployments, review Microsoft’s security-update guidance, and apply the relevant SharePoint update through their normal server-maintenance process.
CVE-2026-50661 concerns Windows BitLocker and is reported as a security-bypass issue. That makes the Windows client update relevant to organizations with BitLocker-protected endpoints, particularly where devices contain sensitive business or personal data.
These are not interchangeable risks. Internet-facing identity and collaboration infrastructure should lead the response because those services can represent high-consequence infrastructure. Windows endpoints should follow through a managed deployment process, with mobile and sensitive-data devices receiving early attention.
For consumers and small organizations using supported Windows 11 devices, the procedure is straightforward:
  1. Open Settings.
  2. Select Windows Update.
  3. Select Check for updates.
  4. Choose Download & install for the offered update.
  5. Select Restart when prompted.
After the restart, verify the result under Settings > System > About by checking the Windows version and OS build, or under Windows Update > Update history by confirming that the cumulative update installed successfully.
Microsoft’s Windows Builds Carry Security Changes Beyond the CVE List​
For Windows 11 25H2 and 24H2, Microsoft identifies KB5101650 as the July cumulative update. It moves version 25H2 to Build 26200.8875 and version 24H2 to Build 26100.8875. Windows 11 23H2 receives KB5099414 and moves to Build 22631.7376.
Windows 11 versionJuly cumulative updateJuly OS buildSupport/lifecycle notice
25H2KB510165026200.8875Current July security release
24H2KB510165026100.8875Home and Pro end updates October 13, 2026; Enterprise and Education October 12, 2027
23H2KB509941422631.7376Enterprise and Education end updates November 10, 2026
Microsoft says KB5101650 incorporates non-security improvements from the June 9 update, KB5094126, and the June 23 preview update, KB5095093. That is normal cumulative-update behavior, but it means a July deployment is not a narrow security-only change. Administrators are evaluating a consolidated servicing package with both security fixes and platform changes.
One of the more consequential changes concerns third-party TDI transports. Microsoft’s guidance applies to updates released on or after July 14, 2026. Organizations that maintain specialized applications, legacy networking components, endpoint tools, or vendor software built around older networking assumptions should review the guidance and validate relevant workloads before broad deployment.
That warning will not matter to most home PCs, but it can matter to organizations that have not fully inventoried older networking dependencies. As a WindowsForum operational recommendation, a pilot ring should include devices running specialized networking software before deployment expands across the fleet. The question is not whether every application uses TDI; it is whether the organization knows which applications depend on nonstandard or legacy networking components.
Microsoft is also updating the curl tool bundled with Windows to version 8.21.0. Developers, automation teams, and administrators that rely on the in-box command-line environment should account for that change in their routine validation.
Remote Desktop is another area where the update points toward trust-configuration maintenance. Microsoft recommends using SHA-256 or a stronger algorithm for trusted RDP publisher certificate thumbprints. Organizations should identify configurations that continue to rely on SHA-1 and plan an orderly migration in line with that guidance. This is a configuration-review task, not a reason to defer the Windows security update.
Secure Boot and Recovery Media Need Validation, Not Assumptions​
The Windows update information continues Microsoft’s work around newer Secure Boot certificates as existing certificates began expiring in June 2026. Microsoft says affected devices that have not yet received newer certificates will continue to start and that standard Windows updates will continue to install.
That reassurance is useful, but Secure Boot changes still deserve operational testing. They are most visible not during ordinary daily use, but during recovery, reimaging, bare-metal deployment, offline servicing, or booting from custom installation media. A device can appear healthy in production while an outdated recovery workflow fails at the moment it is needed most.
Microsoft warns that missing boot.stl on installation media can cause error 0xc0430001 when that media is used. Organizations using custom media, dynamic updates, Windows PE, or internally maintained deployment images should validate their recovery and provisioning paths before relying on them for broad rollout or incident recovery.
The practical takeaway is narrower than a full imaging redesign: test the media your organization actually uses. Confirm that a representative device can boot it, reach the expected recovery or setup environment, and complete the organization’s standard provisioning sequence. This is a WindowsForum operational recommendation for teams that manage custom Windows deployment workflows.
Timeline​
June 9, 2026 — Microsoft released KB5094126 for Windows 11 25H2 and 24H2, advancing builds to 26200.8655 and 26100.8655; Windows 11 23H2 received KB5093998.
June 23, 2026 — Microsoft released the KB5095093 preview update for Windows 11 25H2 and 24H2, advancing builds to 26200.8736 and 26100.8736.
July 14, 2026 — Microsoft’s guidance for the third-party TDI transport registration change applies to updates released on or after this date. KB5101650 applies to Windows 11 25H2 and 24H2, while KB5099414 applies to Windows 11 23H2.
October 13, 2026 — Windows 11 24H2 Home and Pro editions reach end of updates.
November 10, 2026 — Windows 11 23H2 Enterprise and Education editions reach end of updates.
Dell’s Temporary Hold Requires Exception Tracking​
Microsoft has placed a temporary safeguard hold on a limited number of Dell devices using Intel Innovation Platform Framework drivers because of an incompatibility involving an Intel component. Microsoft says affected systems may experience changes in performance, power consumption, or general system behavior, and that availability is expected to resume after the issue is addressed.
For affected organizations, this is not an instruction to bypass Windows Update safeguards indiscriminately. It is an exception-management problem.
As a WindowsForum operational recommendation, administrators should identify the Dell systems in scope, record the affected driver and device populations, monitor Microsoft’s updated availability guidance, and maintain an explicit owner for each held device. Where a held device has elevated exposure or contains sensitive local data, teams can assess temporary compensating controls appropriate to their environment. Those controls should be based on the organization’s own risk model, not treated as a Microsoft-mandated substitute for the update.
For consumers, a Dell laptop that does not immediately receive KB5101650 may be subject to the safeguard hold rather than permanently excluded from servicing. The appropriate response is to use the normal Windows Update path and avoid improvised driver downloads or registry workarounds from untrusted sources.
A safeguard hold can be frustrating, but it is also a useful reminder that deployment velocity and deployment discipline are not opposites. The goal is to patch every eligible system quickly while keeping a visible, time-limited list of systems that cannot yet take the update.
Windows 11 Lifecycle Dates Belong in the Same Dashboard​
Microsoft’s release information also highlights Windows 11 support deadlines that should be part of the same operational review.
Windows 11 version 24H2 Home and Pro editions stop receiving updates on October 13, 2026. Enterprise and Education editions of 24H2 have support through October 12, 2027. Windows 11 23H2 Enterprise and Education editions reach end of updates on November 10, 2026.
Those dates change the nature of patch compliance. A device can be fully patched this month and still become a near-term support problem if it remains on an edition or version nearing end of updates. Organizations should inventory not merely “Windows 11” devices, but the exact version and edition running on each device.
Microsoft also notes that KB5027397 is the enablement package needed to update to Windows 11 23H2. The larger lesson is that Windows servicing remains version-specific. Upgrade eligibility, enablement packages, cumulative updates, and lifecycle dates all depend on the precise release and edition in use.
Microsoft’s release information also includes updates to AI components such as Image Search, Content Extraction, Semantic Analysis, and Settings Model. Regardless of which devices receive those components, their inclusion reflects the increasingly modular nature of Windows servicing: endpoint-management teams must account for more than the traditional operating system core when validating a release.
Prioritized rollout checklist for admins​
The following sequence is a WindowsForum operational recommendation for organizations that need to balance exposure, testing, and deployment speed.
  1. Hand off AD FS and SharePoint Server review to the relevant server owners. Identify affected deployments, consult Microsoft’s security-update guidance, obtain the applicable product updates, and use established server-maintenance and monitoring procedures to confirm completion.
  2. Pilot the Windows client updates. Deploy KB5101650 to a representative Windows 11 25H2 and 24H2 ring, and KB5099414 to a representative 23H2 ring. Include BitLocker-protected mobile systems, devices used by privileged staff, systems running critical line-of-business software, and machines with known legacy networking dependencies.
  3. Track Dell Intel IPF exceptions. Identify Dell devices affected by the temporary safeguard hold, document their business owner and risk level, and monitor Microsoft’s guidance for renewed availability. Keep the exception list active until affected devices receive the update.
  4. Validate recovery and deployment media. Test the organization’s installation and recovery media, especially where custom images, Windows PE, dynamic updates, or offline servicing are involved. Confirm that the media boots successfully and account for Microsoft’s warning that a missing boot.stl file can result in error 0xc0430001.
  5. Test relevant networking workloads. Review specialized applications and vendor components that may depend on third-party TDI transports or older networking assumptions. Microsoft’s TDI guidance applies to updates released on or after July 14, 2026.
  6. Review RDP publisher trust settings. Identify trusted RDP publisher configurations using SHA-1 thumbprints and plan migration to SHA-256 or a stronger algorithm, following Microsoft’s recommendation.
  7. Move to broad client deployment after validation. Confirm installation through endpoint-management reporting, including successful installation and restart status. Devices that are offline, paused, held, or repeatedly failing installation should remain visible as exceptions rather than being counted as compliant.
  8. Reconcile version inventory with lifecycle dates. Flag Windows 11 24H2 Home and Pro systems approaching October 13, 2026, and Windows 11 23H2 Enterprise and Education systems approaching November 10, 2026. Treat version migration as part of security readiness rather than a separate future project.
What Windows Users Should Verify After Installation​
For individual users, the most important check is that Windows Update has actually completed the cumulative update and restarted the device. Opening Windows Update without installing an offered update is not the same as being protected.
Use Settings > Windows Update > Check for updates > Download & install > Restart, then confirm the result in one of two places:
  • Settings > System > About for the Windows version and OS build.
  • Windows Update > Update history for the installed cumulative update entry.
Users on Windows 11 25H2 or 24H2 should look for KB5101650 when it is offered to their device. Users on Windows 11 23H2 should look for KB5099414. If an update is not offered immediately, particularly on an affected Dell system, avoid forcing unsupported changes and check Windows Update again after Microsoft’s safeguard guidance changes.
Organizations should make the same distinction at scale. A deployment dashboard should show not only that an update was targeted, but that it downloaded, installed, restarted successfully, and reported the expected build. Devices that are offline, paused, held, or repeatedly failing installation need separate follow-up rather than being counted as broadly compliant.
The Practical Reading of July’s Security Release​
The July 2026 release calls for a focused sequence rather than a single blanket action. Server owners should review the applicable AD FS and SharePoint Server security updates through Microsoft’s security-update guidance. Endpoint teams should then pilot and deploy the applicable Windows cumulative updates, while tracking Dell Intel IPF exceptions and testing workloads covered by the TDI transport guidance.
The BitLocker issue reinforces the importance of promptly updating managed Windows endpoints. The Secure Boot and boot.stl warning reinforces the value of testing recovery media. The RDP publisher guidance reinforces the need to move away from SHA-1 dependencies in favor of SHA-256 or stronger configurations. And the Windows 11 lifecycle dates reinforce that patch compliance is incomplete if a fleet is left on versions nearing end of updates.
For WindowsForum readers, the useful takeaway is not simply “install the update.” It is to install and verify the Windows update on clients, give server-product remediation to the appropriate owners, keep Dell-held devices on an explicit exception list, and validate recovery paths before the next incident makes that validation urgent.
Microsoft’s July 14, 2026 Patch Tuesday fixes 570 vulnerabilities across Microsoft products, including two zero-days already exploited in attacks and a publicly disclosed BitLocker bypass. The headline number is a record by BleepingComputer’s Patch Tuesday count, but it should not be read as “570 Windows 10 and Windows 11 bugs”: the release spans Windows, Windows Server, SharePoint Server, Office, .NET, Azure components, and other Microsoft software.
The immediate priority is not the scale of the batch but the two confirmed in-the-wild vulnerabilities: CVE-2026-56155 in Active Directory Federation Services and CVE-2026-56164 in Microsoft SharePoint Server. Microsoft’s own security guidance and reporting from BleepingComputer indicate both were being used before the July patches arrived. That moves this from a routine monthly update into a deployment exercise for identity and collaboration administrators.
Microsoft had warned on July 9 that customers should expect larger security releases as it expands AI-assisted vulnerability discovery across the Windows codebase. Its new multi-model scanning system, called MDASH, is designed to sift candidate flaws, validate them, and send only high-confidence findings to engineering teams. The July volume is therefore evidence of a faster discovery pipeline, not proof that Windows suddenly accumulated hundreds of new defects in a month.
Cybersecurity analysts monitor AI-driven vulnerability alerts, patch deployment, audit logs, and encrypted systems. The real emergency sits in AD FS and on-premises SharePoint​
CVE-2026-56155 is an elevation-of-privilege flaw in Active Directory Federation Services, the identity component still used by many organizations for federated sign-on. Microsoft says insufficiently granular access control can allow an authorized attacker to elevate privileges locally. In practice, an attacker who has already gained a foothold could potentially turn that position into administrative control over a particularly sensitive identity system.
The associated remediation has an operational wrinkle. Microsoft’s July Windows security update begins the first hardening phase for the AD FS Distributed Key Manager container ACL. The update initially runs in Audit mode, logging insecure permissions rather than automatically correcting them. Administrators need to inspect the AD FS Admin event log for Event ID 1132, then plan the opt-in ACL remediation rather than treating the monthly reboot as the entire job.
That distinction matters. A rushed permissions change around the Distributed Key Manager container can affect the certificates AD FS uses for token signing and token encryption. The correct response is still urgent patching, but it should be paired with review of the audit events, validation of federation flows, and confirmation that every AD FS server has received the update.
CVE-2026-56164 is the other active zero-day, affecting on-premises Microsoft SharePoint Server rather than SharePoint Online. Microsoft describes it as a missing-authentication issue in a critical function that allows an unauthenticated attacker to elevate privileges over a network. BleepingComputer reported that Microsoft has not published technical details of the active exploitation, which is all the more reason to assume internet-exposed SharePoint infrastructure is a priority target.
Microsoft recommends enabling the Antimalware Scan Interface on affected SharePoint servers and setting Request Body Scan mode to Full as a mitigation. That is not a substitute for applying the update. It is a compensating control for organizations that need time to test or coordinate an emergency maintenance window.
BitLocker deserves attention, but its threat model is different​
The third zero-day, CVE-2026-50661, is a publicly disclosed Windows BitLocker security-feature bypass. Unlike the AD FS and SharePoint flaws, Microsoft has not said it is being actively exploited. Successful exploitation requires physical access to the target device, and the expected outcome is access to data that the attacker should not be able to read from an encrypted system drive.
That makes the fix important for laptops, lost-device scenarios, field hardware, and any organization that depends on BitLocker as part of its data-protection posture. It is less likely to be the first item in an incident-response queue than an exposed SharePoint farm or AD FS server, but it should not be pushed into next month’s cycle.
The July update also reinforces a familiar lesson: full-disk encryption is a layer, not a magic wall. BitLocker remains valuable, but its assurance depends on the device’s patch state, Secure Boot posture, TPM configuration, recovery-key controls, and physical custody.
The record is 570—or 622—depending on the counting rule​
Security coverage around this month’s release has produced two totals. BleepingComputer counted 570 vulnerabilities in the Patch Tuesday set released by Microsoft on July 14, excluding issues repaired earlier in the month and a large set of Chromium vulnerabilities fixed upstream by Google. Malwarebytes reported 622 Microsoft CVEs when using a broader tally.
The discrepancy is not evidence that either outlet got the story wrong. It demonstrates why vulnerability totals need context: vendors publish fixes continuously, products inherit fixes from upstream projects, and “Patch Tuesday” can be defined narrowly as that day’s Microsoft advisories or broadly as the month’s Microsoft security activity.
Under BleepingComputer’s July 14 count, 59 issues are rated Critical. The breakdown is led by 254 elevation-of-privilege vulnerabilities and 145 remote-code-execution vulnerabilities, followed by 102 information-disclosure issues, 35 denial-of-service flaws, 17 security-feature bypasses, and 16 spoofing vulnerabilities. Numbers at this scale can make any monthly release look equally urgent; they are not. Exposure, exploit status, and the role of the affected system should determine deployment order.
For most home users, the practical action is straightforward: install the latest cumulative update through Windows Update, reboot, and verify the device is current. The Windows 11 July cumulative updates include KB5101650 for version 25H2 and version 24H2, and KB5099414 for version 23H2. Windows 10’s July security update, KB5099539, is relevant to systems enrolled in Extended Security Updates now that standard Windows 10 support has ended.
AI speeds discovery, not change control​
Microsoft’s position is that AI-driven discovery lets it identify weaknesses earlier, prioritize risk, and reduce the time between an internal finding and customer protection. MDASH is described as a multi-model pipeline that scans critical binaries, validates candidate bugs through model-based review, and passes confirmed findings into a Windows-specific proof process intended to eliminate false positives.
That is a meaningful technical change, but it does not remove the enterprise patching problem. If AI increases the rate at which vendors find valid vulnerabilities, IT teams will receive larger batches more often. The bottleneck moves from discovery to triage, compatibility testing, staged deployment, rollback planning, and proof that critical systems remain healthy after the update.
Microsoft argues that optional preview updates, Known Issue Rollback, Windows Autopatch, Intune, and hotpatch capabilities can soften that burden. Those tools help, but they do not decide whether an organization’s bespoke SharePoint integration, legacy AD FS configuration, endpoint security driver, or line-of-business application will behave correctly after a cumulative update.
Administrators should therefore treat July’s release as two tracks. The first is an accelerated security response for exposed SharePoint Server, AD FS, and Windows devices at elevated physical-loss risk. The second is a disciplined validation cycle for the remaining fixes, with monitoring for application failures, federation errors, performance regressions, and update-health signals.
The larger consequence is that Patch Tuesday may no longer be sized for the old cadence of human-only code review. Microsoft has made clear that it expects AI to uncover more flaws faster. July’s record release shows the defensive benefit of that approach—but it also gives Windows administrators a preview of the patch volume they may need to absorb from now on.
