Linux MTD Core CVE-2022-50304: Unregister on Error Fix Restores Module Load
Hand placing an 'unregister on error' tag while kernel boot messages display on screen.
A subtle cleanup bug in the Linux kernel’s MTD (Memory Technology Device) core can leave kernel objects registered even after a failed initialization, preventing the module from being reloaded and producing a persistent availability problem; the issue was assigned CVE-2022-50304 and has been fixed upstream by ensuring the block-device-backing infrastructure is unregistered on error.
Background​
The MTD subsystem provides kernel support for flash-memory devices, NAND/NOR chips, and other memory-technology devices used in embedded systems, appliances, routers, and some specialized server and IoT platforms. In September 2025 the vulnerability CVE-2022-50304 was publicly recorded after kernel maintainers and distribution security teams mapped a small but operationally important resource-leak condition in the MTD initialization path. The National Vulnerability Database (NVD) summary describes the root cause in plain terms: when a sub-initialization (init_mtdchar fails inside init_mtd, the code path did not unregister mtd_bdi (the MTD backing device info), leaving registration state inconsistent and blocking subsequent module loads. Ubuntu, SUSE, and other downstream trackers imported the CVE and published vendor advisories describing the same error trace — a duplicate sysfs name error (“sysfs: cannot create duplicate filename '/devices/virtual/bdi/mtd-0'”) and a kobject_add_internal failure returning -EEXIST — which is the visible symptom administrators should hunt for in logs when assessing exposure.
What went wrong: a technical anatomy​
The failing path​
  • During module load, the MTD core performs several registration steps: registering device classes, creating sysfs entries, and registering a backing-device-info (bdi) structure used for block-device accounting.
  • If an intermediate step — specifically init_mtdchar which sets up character interface support — fails, the existing code returned an error without cleaning up everything it had already registered.
  • That left mtd_bdi still registered. On a subsequent load attempt, the kernel could not recreate the same sysfs entries and failed with an -EEXIST condition, effectively making the MTD module unable to finish initialization until manual intervention. The kernel call stack and the textual error are documented in the NVD/OSV notes.
Why this matters in practice​
This is not a memory-corruption or privilege-escalation bug; it is an availability issue. The practical consequences are operational:
  • The MTD module may refuse to load after a transient failure, preventing access to flash devices serviced via MTD.
  • On embedded devices (routers, IoT appliances, firmware appliances) where MTD-backed storage is essential, the failure can be persistent across re-attempts to insert the module and may require an administrative reboot or manual cleanup.
  • On systems that perform automated module reloads or where unprivileged processes can trigger module load/unload cycles, an attacker who can provoke init failures could create a denial-of-service condition.
This pattern — failing to free or unregister partially-initialized resources on error paths — has long been a source of availability incidents in kernel subsystems. Upstream maintainers therefore favor surgical fixes that ensure every error path funnels through central cleanup logic. The uploaded investigation notes we reviewed describe this same defensive approach: centralize cleanup so partially-initialized structures are always released on error return.
The fix: what changed upstream​
The upstream correction is intentionally small and defensive: after the label that handles the out_procfs error path in init_mtd, the code now explicitly calls bdi_unregister(mtd_bdi) so that any earlier registration is undone before returning the error. This means the module can be cleanly reloaded later because the sysfs/bdi registration state is consistent. OSV and the stable kernel commit references document the change and point to the upstream stable commits that implement the cleanup. Why this is the right fix:
  • It’s local and low-risk: only the error path is adjusted; successful initialization behavior is unchanged.
  • It restores the invariant that “if init fails, nothing remains registered,” which is crucial for module re-loadability.
  • The patch is trivial to backport, which matters for distributions and vendors that maintain stable kernel branches.
This exact remediation pattern — guarantee resource de-registration on every error exit — is recommended for kernel-quality and has been used in prior filesystem and driver fixes that addressed similar resource-leak/availability problems. The uploaded internal notes echo this philosophy and cite analogous fixes in other kernel subsystems.
Who is affected and how urgent is patching?​
Affected systems​
  • Any Linux kernel build that includes the MTD core and the affected init path is potentially impacted. That commonly includes embedded device builds, certain custom Linux images, and platforms that rely on raw flash devices instead of block-backed storage.
  • Devices where the kernel is shipped by vendors (OEM Android kernels in embedded appliances, router firmware, custom appliance kernels) may be the longest tail to receive the fix because vendor backport and release cycles vary widely.
Attack vector and privileges​
  • The vector is local: an attacker or misbehaving process needs to provoke init_mtd failure conditions, or an operator must attempt to load the module and hit the fault.
  • Privilege requirements are low in many settings because module load/unload can be performed by administrators or by scripts; in some misconfigured systems, unprivileged users could indirectly trigger the condition via automated service interactions — so the practical risk depends heavily on local access controls.
Severity and scoring​
  • Distributions that have assigned scores characterize this as an availability-focused issue with a medium CVSS rating reflecting local attack vector and high availability impact. SUSE lists a CVSS v3 base score of 5.5 with Availability impact flagged as High in their triage.
Expedite patching if you operate​
  • Embedded fleets, appliances, routers, and devices that depend on MTD-backed storage.
  • Multi-tenant build/test hosts or CI infrastructure that might load or test device drivers or kernel modules.
  • Systems where the MTD module is loaded/unloaded dynamically by automation or provisioning tools.
If you manage such systems, prioritize verifying whether your vendor or distribution kernel packages include the stable backport identified by OSV/NVD and install the patched kernel packages as soon as feasible.
Detection, telemetry, and incident response​
What to look for in logs​
  • Kernel messages containing the string: sysfs: cannot create duplicate filename '/devices/virtual/bdi/mtd-0'
  • Call stack traces showing kobject_add_internal failing with -EEXIST during init_mtd or device/bdi registration.
  • Repeated module load failures for the mtd or mtdchar modules.
These textual indicators come directly from the vulnerability report and are the clearest sign a host has encountered the condition. Capture dmesg and journalctl output and preserve vmcore or crash dumps if you suspect intentional triggering in production.
Hunting & telemetry​
  • Add logwatch rules or SIEM alerts for the duplicate sysfs filename string and for mtd-related oops traces.
  • Monitor for repeated failed module loads and unexplained service errors on appliances that depend on MTD devices.
  • In multi-tenant or CI environments, correlate image or module tests with kernel logs to identify candidate triggers.
If you see the condition, remediation is to install the patched kernel and reboot. In environments where a reboot is expensive, you can temporarily remove or blacklist the offending module, but the only true fix is the patched code. The uploaded operational guidance recommends inventory → patch → validate → monitor as the prioritized playbook.
Patching and operational playbook​
  1. Inventory: find hosts that include MTD support and identify the kernel package and its changelog (uname -r; zcat /proc/config.gz | grep -w CONFIG_MTD).
  2. Map: check your distribution security tracker or vendor advisory for CVE-2022-50304 mappings to package versions. OSV and vendor advisories list upstream commit references you can use to confirm backport presence.
  3. Stage: deploy the patched kernel to a representative pilot group, exercise module load/unload and MTD operations.
  4. Rollout: phased deployment with telemetry monitoring for regression indicators and kernel stability.
  5. Validate: confirm the kernel changelog references the upstream stable commit or that the module no longer emits duplicate-sysfs errors after a clean reboot.
Short-term mitigations if you cannot patch immediately:
  • Restrict who may load kernel modules or interact with MTD interfaces.
  • Move untrusted workloads off hosts that may dynamically load drivers.
  • Increase log retention and alerting on the specific sysfs duplicate errors so you can quickly detect exploitation attempts or accidental triggers.
Broader context: why small fixes matter​
Kernel development best practice favors tiny, well-reasoned changes to eliminate corner-case error-path inconsistencies. Resource leaks that persist across failed initialization are deceptively dangerous: they may not cause an immediate crash, but they produce a persistent state that breaks future attempts to use the affected functionality and can effectively brick a subsystem until an operator intervenes. The upstream patch for CVE-2022-50304 embodies that minimal, surgical approach — register what you need, and always undo it on the way out if you fail. The files uploaded with the investigation highlight the same recurring themes across multiple kernel CVEs: centralized cleanup, defensive checks, and conservative failure modes are effective, low-risk approaches to fixing availability bugs.
Risks and caveats​
  • Vendor lag: even though the upstream patch is small, vendor and OEM kernels may still be unpatched; embedded devices and appliances frequently have long tails before updates are available. Do not assume a device is safe until the vendor advisory or package changelog explicitly states the fix has been included.
  • Operational windows: kernel updates require reboots. For high-availability appliances you must plan maintenance windows and test the updated kernel under representative loads to avoid disruption.
  • Unverified exploitation: there is no public evidence at disclosure that the bug was widely exploited in the wild or that it provides an escalation primitive beyond denial-of-service. Treat claims of active exploitation as unverified unless backed by incident telemetry.
Practical example: incident triage checklist​
  • Step 1: Gather logs (dmesg, journalctl) showing the duplicate sysfs error or kobject_add_internal failures.
  • Step 2: Verify kernel config for MTD support (zcat /proc/config.gz | grep CONFIG_MTD).
  • Step 3: Check kernel package changelog for the upstream commit IDs referenced in OSV/NVD (confirm the stable backport presence).
  • Step 4: If patch available, schedule update and reboot; if not, restrict access to module load and triage affected devices.
  • Step 5: After patching, re-attempt module load and validate absence of duplicate-sysfs traces; if problems persist, collect vmcore and interact with your vendor for additional diagnostics.
CVE-2022-50304 is a textbook example of an availability-centric kernel bug: small in code but large in operational impact if overlooked. The root cause was a missing unregister call in an error path of init_mtd, which left the MTD backing-device registration in place after a failed sub-initialization and prevented subsequent module loads. Upstream maintainers shipped a minimal and correct fix — unregister on error — and distributions have begun mapping and backporting the change. Administrators running kernels with MTD support should treat this as a high-priority operational patch for relevant systems: inventory hosts, verify vendor package mappings, and apply the patched kernel promptly while monitoring for the distinctive duplicate-sysfs error signs in kernel logs.
Key references used in this analysis include the NVD and OSV vulnerability entries summarizing the fix and the error trace, vendor advisories (Ubuntu, SUSE) that mapped CVE-2022-50304 to distribution packages, and internal analysis notes illustrating the cleanup-and-backport pattern used across similar kernel fixes.
