Neil154
I have 3 Win 11 PCs and my local network is set to private. For some reason the network changes to public sometimes, I reset it to private but later it changes back to public.
How do I get them to stay private?
Hi Neil — frustrating but fixable. Below are steps to both find the cause and force the network profile to stay Private on each PC. I’ll give quick diagnostics first, then a safe persistent fix you can use even on Windows 11 Home.
Quick checks (tell me what you see)
  • Are the PCs using Wi‑Fi, Ethernet or both?
  • Do you use any VPN (WireGuard, OpenVPN, corporate VPN), virtualization (Hyper‑V, VirtualBox), or third‑party security/firewall software?
  • Are these PCs domain‑joined (work/school account) or local/home PCs?
Diagnostic commands (run in an elevated PowerShell and paste results if you want help diagnosing)
  • Open PowerShell as Administrator and run:
    Get-NetConnectionProfile
    This shows the network Name...
    This shows the network Name, InterfaceIndex and current NetworkCategory (Public/Private/Domain).
Why this happens (short)
  • Windows may re-classify a network when the adapter/driver resets, if you connect to a different SSID, when a VPN/virtual adapter appears, or when third‑party security software changes firewall/network settings. Domain policies (GPO) can also override local settings.
How to make the profile stay Private (recommended)
Option A — One‑line PowerShell (temporary but immediate)
  • Run PowerShell as Administrator and replace <Name> with the Name from Get-NetConnectionProfile:
    Set-NetConnectionProfile -Name "<Name>" -NetworkCategory Private
    Or to set any non‑private connections to Private:
    Get-NetConnectionProfile | Where-Object {$.NetworkCategory -ne 'Private'} | ForEach-Object { Set-NetConnectionProfile -InterfaceIndex $.InterfaceIndex -NetworkCategory Private }
Option B — Persistent enforcement (recommended if it keeps flipping back)
Create a scheduled task that runs at startup/logon and forces networks to Private:
  • Open Task Scheduler → Create Task.
  • Name: Enforce Private Network. Check “Run with highest privileges”.
  • Triggers: “At startup” and “At log on (Any user)”.
  • Action: Start a program:
  • Program/script: powershell.exe
  • Add arguments:
    -WindowStyle Hidden -ExecutionPolicy Bypass -Command "Get-NetConnectionProfile | Where-Object {$.NetworkCategory -ne 'Private'} | ForEach-Object { Set-NetConnectionProfile -InterfaceIndex $.InterfaceIndex -NetworkCategory Private }"
  • OK. This runs as admin and will re‑set the profile if something changes it.
Notes & cautions
  • You need Administrator rights for Set-NetConnectionProfile and for the scheduled task.
  • If the machine is domain‑joined, domain GPO can override local settings — check with your IT. Domain networks should be Category = Domain.
  • If a VPN or security app is changing the profile, the scheduled task will mask the symptom but not stop the app from making changes. If you have a VPN/security app, check its settings or temporarily disable it to see whether the profile still flips.
Further troubleshooting (if it still flips)
  • Check Event Viewer → Applications and Services Logs → Microsoft → Windows → NetworkProfile → Operational for events when the change happens — note the timestamp and what other events show at the same time.
  • Check whether a virtual adapter appears (Get-NetAdapter) or VPN client logs.
  • Temporarily disable third‑party firewall/antivirus and watch for changes.
  • Tell me the output of Get-NetConnectionProfile and if you see any VPN adapters from Get-NetAdapter — I’ll suggest a tailored fix.
If you want, tell me:
  • Output of Get-NetConnectionProfile,
  • Whether the machine is Home/Pro/Enterprise,
  • If you use a VPN or security suite,
    and I’ll give a precise script or a step‑by‑step Task Scheduler export you can import.
