Windows 7 Mic Not Deteced Splitter Adapter Win 8.1
Hieya
I have windows 8.1 and i had to use a splitter adapter which allow my 3.5 mm headphones with a inline mic to be alble to use on my computer. I can use the mic on steam but not skype. When i go to Recording devices it does show that the mic is making noise but when im on Steam it shows that i can talk just fine. Even when I playback my voice I can hear myself but it doesnt work on skype either. The headset splitter adapter splits into two 2 connections. I have everything on full like volume and microphone boost. What can I do so it picks up my inline mic on my headphones?
-Thank you
-GT70 895 (870M)
It seems like you're encountering issues with getting your inline mic on your headphones to work correctly with Skype on Windows 8.1. Here are a few steps you can try to troubleshoot and potentially resolve this issue: 1. Check Skype Settings: - Ensure that Skype is set to use the correct audio input device. Go to "Tools" > "Options" > "Audio settings" and check that the correct microphone is selected. 2. Verify Windows Settings: - Confirm that your sound settings in Windows are correctly set. Right-click on the sound icon in the system tray, select "Recording devices," and check if your mic is listed and enabled. 3. Update Audio Drivers: - Make sure your audio drivers are up to date. Go to the manufacturer's (Realtek...
It seems like you're encountering issues with getting your inline mic on your headphones to work correctly with Skype on Windows 8.1. Here are a few steps you can try to troubleshoot and potentially resolve this issue: 1. Check Skype Settings: - Ensure that Skype is set to use the correct audio input device. Go to "Tools" > "Options" > "Audio settings" and check that the correct microphone is selected. 2. Verify Windows Settings: - Confirm that your sound settings in Windows are correctly set. Right-click on the sound icon in the system tray, select "Recording devices," and check if your mic is listed and enabled. 3. Update Audio Drivers: - Make sure your audio drivers are up to date. Go to the manufacturer's (Realtek, Conexant, etc. website and download the latest drivers for your sound card. 4. Reinstall Skype: - Try reinstalling Skype to ensure that any software-related issues are resolved. 5. Test with Another Application: - Test your mic with another application, such as the Voice Recorder app in Windows, to check if the issue is specific to Skype. 6. Check Hardware Connections: - Ensure that all connections are secure. Try plugging the headphones into different ports on your computer to rule out port-related issues. 7. Test with A Different Mic: - If possible, try using a different mic or headset to see if the issue is with the mic itself. By following these steps, you should be able to identify and resolve the problem with your inline mic not working correctly on Skype.
