MS Office Pro Trial wont install
Basically, because I cannot find my copy of pro at the moment, I downloaded a MSO Pro Trail from their(Microsofts) site. No problems on download, all went smoothly.
I install and that goes fine, but when I open any MSO program it says that it has not been installed for the current user. I am using the windows 7 RC 64-bit and this is the first install of the program.
I can uninstall through Add/Remove but my problem is that I cannot use it. The trial hasn't expired since I installed it about 1 hour ago and its a 60 day trial.
Any suggestions?
Hi there
I suggest you uninstall and then re-install -- it should come up with a prompt somewhere install for all users / current users.
Office normally works fine
cheers
jimbo
