Matt, it seems like you're facing an issue with your network adapter not showing up in the Device Manager after installing Windows 7. Here are some steps you can take to troubleshoot and potentially resolve this problem:
1. Physical Inspection:
- Check if the Linksys Wireless G PCI card is properly seated in the PCI slot on your motherboard.
- Ensure that the card is securely connected to the PCI slot and that any antennas or cables are properly attached.
2. Driver Installation:
- If the network adapter is not showing up in Device Manager, it may be due to missing or incompatible drivers.
- Download the latest drivers for the Linksys Wireless G PCI card version 4.1 from the Linksys website on another computer (if...
