Windows 7 Need help with finding and deleting program or file
lazybones
An image from 'Need help with finding and deleting program or file'. Desktop screenshot with Star Wars wallpaper, showing a right-click menu in Slovenian and various app icons.
this chinese program or file got instaled on my computer and i cant find it or delet it sorry for foreign language
If you didn't install the program, it's most likely a virus/malware. Did you scan for viruses using your installed AV?
You should do that and scan/remove any viruses found. In addition it's a good idea to download the free MALWAREBYTES antispyware program from malwarebytes.org and scan/remove all spyware viruses found. Power off your computer for 5 minutes. Reboot and retest your computer and see if it's gone. If it is, you had a simple spyware virus most likely and you're good to go. :up:
90% of the computers I see in my shop contain spyware viruses; so it's a pretty good bet that's what you have.
<<<BIGBEARJEDI>>>
BIGBEARJEDI
<<<BIGBEARJEDI>>>
Neemobeer
Windows Forum Team
  • Open regedit
  • Expand HKEY_CLASSES_ROOT
  • Expand *
  • Expand shell
  • If you see those chinese entries in there delete them
If those funny entries only appear when you right click shortcuts the other place to look
  • Open regedit
  • Expand lnkfile
  • Expand shell (if it exists)
  • Any keys in here will show up as right click menu items on .lnk files only
