NVIDIA GeForce Hotfix 595.76: Fixes Overclock Voltage Cap and Game Issues
NVIDIA released a targeted GeForce Hotfix Display Driver—version 595.76—on March 4, 2026 to address several high-impact issues that emerged in recent driver cycles, most notably a condition that could cap GPU voltage during manual overclocks and reduce boost clocks and performance for affected users. ([nvidia.custhelp.sthelp.com/app/answers/detail/a_id/5812/~/geforce-hotfix-display-driver-version-595.76))
Neon-lit GeForce GPU glowing blue and orange with a circular voltage/clock gauge.Background / Overview​
The GeForce hotfix driver channel exists to push narrowly scoped fixes quickly, outside the cadence of full WHQL Game Ready releases. Hotfixes are intentionally lightweight: they build on a recent mainline driver and add a handful of targeted fixes so NVIDIA can get urgent mitigations into users’ hands faster than a full release cycle allows. NVIDIA’s support entry for 595.76 confirms the package is based on Game Ready Driver 595.71 and lists the affected items the hotfix addresses. (nvidia.custhelp.com)
This particular hotfix was driven by loud community telemetry and reproducible reports showing measurable drops in boost clocks and voltages when users applied manual overclocks with tools such as MSI Afterburner Independent testing and community threads demonstrated consistent behavior across some configurations, which appears to have accelerated NVIDIA’s decision to publish the hotfix.
The practical takeaway is simple: hotfixes are a pragmatic emergency tool. They restore functionality quickly for those experiencing the bug, but they are not a replacement for the more rigorously tested WHQL drivers that follow. NVIDIA explicitly warns that hotfix drivers go through an abbreviated QA process and are distributed through Customer Care rather than the regular NVIDIA App path. (nvidia.custhelp.com)
What 595.76 fixes (the short list)​
NVIDIA’s release notes for GeForce Hotfix Display Driver version 595.76 list a compact set of ta salient items for gamers and enthusiasts are:
  • Overclock voltage capping: A condition where GPU voltage could become capped when the card was overclocked, preventing expected boosting behavior and resulting in reduced clocks and performance. (nvidia.custhelp.com)
  • Resident Evil Requiem: Visual artifacts (white glowing light/dots) when Subsurface Scattering was enabled, plus path tracing performance improvements. (nvidia.custhelp.com)
  • Star Citizen: A crash that could occur when launching the game client. (nvidia.custhelp.com)
  • HDCP 1.x displays: Intermitten driver timeout while playing multi-key DRM content in a browser on older HDCP 1.x monitors. (nvidia.custhelp.com)
Those items were selected because they generated concentrated user reports and, in cases such as the overclock voltage issue, measurable regressions in performance telemetry. Multiple independent outlets and community threads corroborated the symptoms prior to the hotfix, and the vendor’s notes explicitly call out the internal bug tracker ID for the voltage problem—an extra level of granularity that helps power users and system integrators triage applicability.
Why this matters: the technical picture​
Modern GPU boost and overclocking behavior is a synthesized outcome of several layers:
  • The GPU firmware (VBIOS) that enumerates voltage-frequency tables and thermal/power limits.
  • The OS and driver power-management stack that enforces policies and runtime limits.
  • User-space utilities (Afterburner, vendor control panels) that request voltage/clock tner firmware and VRM designs that determine how voltage requests translate into actual delivered voltage.
When the driver inadvertently clamps or misapplies voltage targets, the GPU simply cannot reach the frequency points its silicon and firmware would otherwise permit. The symptoms are straightforward: lower peak and sustained clocks, reduced power draw, and measurable frame-rate drops in demanding scenes. Community reproductions using synthetic benchmarks and telemetry tools documented these patterns and showed that reverting to earlier drivers restored expected behavior in many cases—evidence that the regression was driverardware.
This is why NVIDIA’s hotfix not only lists the observable symptoms but also acknowledges the risk tradeoffs: hotfixes are intended as rapid mitigations and will be folded into the next fully tested release. If you require absolute stability for production work, a hotfix is not the safest choice—waiting for the full WHQL release is. (nvidia.custhelp.com)
How to decide whether to install​
Not every user should install a hotfix. Here’s a practical breakdown.
Install the hotfix if:
  • You are actively experiencing the regression described (reduced boost clocks, measurable performance loss with a previously stable overclock).
  • You are affected by the specific game fixes (e.g., Resident Evil Requiem artifacts, Star Citizen launch crash).
  • You are comfortable performing manual driver installs and have a rollback plan (restore point, saved driver package).
Wait, or avoid the hotfix, if:
  • You aren’t experiencing any of the issues the hotfix addresses.
  • You run production workloads where even a low-probability regression would be costly.
  • You prefer the safety of a fully validated WHQL release.
This guidance matches the vendor’s own framing: hotfix drivers are optional, beta-like, and intended for users who need an immediate mitigation. (nvidia.custhelp.com)
Installing 595.76 safely — a step-by-step checklist​
If you decide the hotfix applies to you, follow these conservative steps to minimize risk and make rollback straightforward.
  • Back up your current state. Create a Wand note your existing driver version.
  • Download the hotfix package from NVIDIA Customer Care or the official support article (NVIDIA distributes hotfixes through Customer Care). (nvidia.custhelp.com)
  • Optionally, download the previous driver package you want to be able to reinstall for rollback.
  • Boot to Safe Mode and run a clean driver uninstall using Display Driver Uninstaller (DDU) if you want the cleanest possible slate. Tr troubleshooting persistent or messy driver issues.
  • Run the hotfix installer and choose “Custom (Advanced)” → check Perform a clean install.
  • Reboot and validate. Use monitoring tools (GPU‑Z, HWiNFO, vendor utilities) to log voltage, clock, and power under a controlled benchmark or workload. If you restored expected behavior, test your usual workloads for a day or two.
If the hotfix introduces new problems, use the restore point or reinstall the saved prior driver package. If a complete clean uninstall is needed, run DDU a prior, known-good driver.
How to verify the fix: testing and evidence​
Quantitative verification beats anecdote. Here are repeatable checks:
  • Use GPU-Z or HWiNFO to log core voltage, power draw, and core clocks during a standardized synthetic run (Unigine, 3DMark) before and after installing the hotfix. Look for restored peak and sustained clock behavior.
  • Compare frame-time and 99th percentile frametimes in a real-game run before and afterpacing improved or regressions were introduced.
  • For overclockers: verify that the driver now honors the expected voltage offsets incrementally—apply a modest offset first, confirm stability, then step up.
Community posts and independent testers reported that the hotfix restored expected behavior in many configurations, although results across hardware/firmware variants are mixed—meaning you should verify on your own setup.
Community response and practical caveats​
Reaction to hotfixes tends to be polarized: affected users are grateful; others wcommunity themes around this and prior hotfixes include:
  • Hotfixes are not visible in the NVIDIA App and often must be downloaded from Customer Care, adding friction for mainstream users. Many community posts explicitly warn that hotfix drivers won’t show up in the normal updater.
  • Results are mixed in the field: a targeted fix that helps one configuration can, in rare cases, expose a different regression on another hardware/firmware combination. That’s a known risk when QA is abbreviated. (nvidia.custhelp.com)
  • Overclockers need to be vigilant: when drivers change voltage or boost characteristics, it’s not always clear whether the change is an intentional policy (thermal/protective) or an unintended regression. NVIDIA’s notes frame this as a bug fix, but the absence of full postmortems leaves some uncertainty for expractical implication is this: if you’re not impacted, the conservative approach is to wait for the next full WHQL driver; if you are impacted, the hotfix is the right tool, provided you follow prudent installation and verification steps.
The broader picture: what this says about NVIDIA’s driver cadence and QA​
The last several quarters show a pattern: rapid mainline releases, community-driven bug discovery, and frequent hotfixes. That workflow has strengths and weaknesses.
Strengths:
  • Speed: Hotfixes can restore critical functionality quickly for users experiencing high-impact regressions. (nvidia.custhelp.com)
  • Focus: By limiting scope, hotfixes reduce the risk of unrelated regressions relative to a larger full release.
Weaknesses:
  • Fragmentation: Multiple hotfixes across different release branches create a complex landscape for users and integrators.
  • Abbreviated QA: A shorter QA cycle increases the chance that edge-case regressions slip through, especially given the diversity of ions, and OEM laptop firmware.
For users and IT shops, the operational advice is to maintain a tested rollback plan and to treat hotfixes as engineered stopgaps rather than long-term baselines. Vendors and system integrators should also test hotfixes in representative lab environments before wide deployment.
Frequently asked practical questions​
  • Will the hotfix appear in the NVIDIA App?
    No — NVre typically distributed via Customer Care and do not show up in the NVIDIA App automatic update feed. You must download and install them manulp.com](NVIDIA Support))
  • Is it WHQL-siers are generally provided as expedited packages and are not positioned as full WHQL releases; NVIDIA’s support page reiterates that these are optional and run through an abbreviated QA process. (nvidia.custhelp.com)
  • Should I expect a performance uplift in all games?
    No. The hotfix targets specific regression scenarios. If your system wasn’t showing the clogged voltage/clock behavior or the listed game bugs, you probably won’t see a meaningful change. Empirical verification is necessary.
  • If the hotfix causes problems, how do I roll back?
    Use the Windows restoreinstall the previous driver package you saved, or perform a DDU uninstall followed by the known-good driver install.
Best practices for enthusiasts and system administrators​
  • Always keep a known-good driver copy: when upgrading, archive the installer for the prior driver so you can revert quickly.
  • Log before upgrading: run and save benchmarks or telemetry logs so you can demonstrate whether the hotfix solves or worsepply hotfixes incrementally in fleets: for managed systems, test on a small cohort before rolling out wider.
  • Keep firmware updated: VBIOS and motherboard BIOS interact with driver behavior—ensure firmware parity across test and production systems.
Independent corroboration and reporting and scope are confirmed by NVIDIA’s official knowledge-base entry (updated March 4, 2026), which provides the official download distribution note and the bug IDs addressed. (nvidia.custhelp.com)​
Independent outlets and community posts tracked the same symptoms and reported the hotfix rollout: community telemetry and testing backed the core complaint (reduced clocks/voltage when overclocked), and outlets covering driver news noted the quick turnaround. Those independent confirmations validate the vendor’s stated goals for the hotfix and the targeted nature of the fixes included.
Final analysis: strengths, risks, and a pragmatic recommendation​
NVIDIA did the right operational thing by issuing a narrowly scoped hotfix to address demonstrable regressions. For users experiencing the exact issues listed—especially overclockers seeing capped voltages and reduced boost clocks—this hotfix is the correct mitigation and should restore expected behavior when tested and applied correctly. (nvidia.custhelp.com)
However, hotfixes come with tradeoffs: an abbreviated QA cycle and distribution outside the mainstream updater means extra care is required by users and administrators. Expect mixed results across different vendor BIOS and OEM firmware combinations; validate thoroughly and maintain rollback plans.
Practical recommendation:
  • If you are impacted: install 595.76 following the clean-install checklist above, then validate with quantitative telemetry. (nvidia.custhelp.com)
  • If you are not impacted: wait for the next WHQL Game Ready release that will fold these fixes into the mainstream branch.
NVIDIA’s hotfix approach is a useful safety valve for urgent problems—when used appropriately and cautiously it can fix serious regressions quickly. But it remains an emergency tool, not a replacement for robust pre-release testing. If you choose to install GeForce Hotfix Display Driver 595.76, do so with a clear rollback plan, log your results, and validate across your typical workloads before adopting it broadly. (nvidia.custhelp.com)
Source: www.guru3d.com https://www.guru3d.com/download/geforce-59176-hotfix-driver-download/
