Kieran McGee
Heya,
Have been having the occasional problem with blue screening for quite a while now, there doesn't seem to be any trigger that I can see, sometimes it happens when the computer is idle, sometimes when I'm playing games or browsing the web. Drivers for various bits of hardware have been updated several times, didn't seem to make a difference either way.
Have tried memory testing quite a few times but nothing came up, hoping some of you guys might be able to help. Anything would be appreciated. Have attached all the requested files and screenshots (I think :P )
  • RAMMon - SPD Info.txt
  • Seven Forums.zip
    Seven Forums.zip
BugCheck 50, {fffff6efffffff80, 0, fffff80002ef24be, 5}
Probably caused by : memory_corruption ( nt!MiDispatchFault+de )
BugCheck 3B, {c0000005, fffff80002e7f2bf, fffff880097eb010, 0}
Probably caused by : ntkrnlmp.exe ( nt!KeRemoveQueueEx+31f )
1600Mhz 9-9-9-24 . Yours is currently set 1600Mhz 9-9-9-28.
In the bios, set DRAM voltage manually 1.65v.
Update old drivers:
ATI (10.12 Preview)
atikmdag.sys Thu Nov 25 21:46:44 2010
Marvell
mv91xx.sys Fri Dec 25 01:45:39 2009
Huawei USB Modem
ewusbmdm.sys Mon Dec 07 06:53:24 2009
USB 3.0 Controller
nusb3hub.sys Thu Jan 21 22:22:18 2010...
Update old drivers:
ATI (10.12 Preview)
Marvell
Huawei USB Modem
USB 3.0 Controller
Marvel Yukon
yk62x64.sys Wed May 20 04:14:06 2009
Let's not touch your BitDiffender. Update drivers and adjust the RAM settings. 1600 9 9 9 24 1.65v.
CRASH DUMPS
Loading Dump File [F:\DMP\032111-18236-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02e04000 PsLoadedModuleList = 0xfffff800`03041e50
Debug session time: Mon Mar 21 15:48:47.449 2011 (UTC - 4:00)
System Uptime: 0 days 3:33:12.401
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
2: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002e7f2bf, Address of the instruction which caused the bugcheck
Arg3: fffff880097eb010, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`02e7f2bf 4c8918          mov     qword ptr [rax],r11
CONTEXT:  fffff880097eb010 -- (.cxr 0xfffff880097eb010)
rax=dffff880097ebbc8 rbx=0000001deb0814f9 rcx=0000000000000000
rdx=0000000000000001 rsi=fffffa80090476a0 rdi=fffffa8008ec4060
rip=fffff80002e7f2bf rsp=fffff880097eb9e0 rbp=0000000000000000
 r8=fffff80002e04000  r9=0000000000000000 r10=fffffffffffffffb
r11=fffffa80090433d0 r12=fffff880097ebbe0 r13=fffffa8008ec4168
r14=0000000000000001 r15=0000000000000001
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
nt!KeRemoveQueueEx+0x31f:
fffff800`02e7f2bf 4c8918          mov     qword ptr [rax],r11 ds:002b:dffff880`097ebbc8=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  spoolsv.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff8000316daf7 to fffff80002e7f2bf
STACK_TEXT:
fffff880`097eb9e0 fffff800`0316daf7 : 00000000`00000000 fffff880`097ebbc8 ffffffff`800041e8 fffff880`097ebb68 : nt!KeRemoveQueueEx+0x31f
fffff880`097eba90 fffff800`02e84aa6 : 00000000`00000000 fffff880`097ebba8 fffff880`097ebbc8 00000000`00000001 : nt!IoRemoveIoCompletion+0x47
fffff880`097ebb20 fffff800`02e73993 : fffffa80`08ec4060 00000000`77195270 fffff880`00000000 00000000`00000000 : nt!NtWaitForWorkViaWorkerFactory+0x285
fffff880`097ebc20 00000000`770e0fba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`026dfb68 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x770e0fba
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KeRemoveQueueEx+31f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
STACK_COMMAND:  .cxr 0xfffff880097eb010 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!KeRemoveQueueEx+31f
Loading Dump File [F:\DMP\032511-19609-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02e66000 PsLoadedModuleList = 0xfffff800`030a3e50
Debug session time: Fri Mar 25 12:04:58.380 2011 (UTC - 4:00)
System Uptime: 0 days 0:57:32.316
5: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff6efffffff80, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002ef24be, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000005, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000310e0e0
 fffff6efffffff80
FAULTING_IP:
fffff800`02ef24be 488b1c29        mov     rbx,qword ptr [rcx+rbp]
MM_INTERNAL_CODE:  5
BUGCHECK_STR:  0x50
PROCESS_NAME:  vsserv.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88005464820 -- (.trap 0xfffff88005464820)
rax=dfffffff00000420 rbx=0000000000000000 rcx=fffff68000000000
rdx=00000000ffffffff rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ef24be rsp=fffff880054649b0 rbp=0000006fffffff80
 r8=ffffdfffffff0000  r9=0000000000000000 r10=0000000fffffffff
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!MiDispatchFault+0xde:
fffff800`02ef24be 488b1c29        mov     rbx,qword ptr [rcx+rbp] ds:18c0:fffff6ef`ffffff80=????????????????
LAST_CONTROL_TRANSFER:  from fffff80002f558c1 to fffff80002ed6740
STACK_TEXT:
fffff880`054646b8 fffff800`02f558c1 : 00000000`00000050 fffff6ef`ffffff80 00000000`00000000 fffff880`05464820 : nt!KeBugCheckEx
fffff880`054646c0 fffff800`02ed482e : 00000000`00000000 00000000`10f8ea7e fa8006c0`99400400 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x40e8b
fffff880`05464820 fffff800`02ef24be : 00000000`00000000 00000000`10f92eca fffff680`00087c90 fffffa80`08b0f3f8 : nt!KiPageFault+0x16e
fffff880`054649b0 fffff800`02ef0743 : ffffffff`ffffff00 00000000`10f8ea7e 00000000`00000001 fffffa80`00000000 : nt!MiDispatchFault+0xde
fffff880`05464ac0 fffff800`02ed482e : 00000000`00000000 00000000`00000000 00000000`003b9a01 00000000`0fc00e14 : nt!MmAccessFault+0x343
fffff880`05464c20 00000000`0f9e54e6 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`0381e4b8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xf9e54e6
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiDispatchFault+de
MODULE_NAME: nt
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x50_nt!MiDispatchFault+de
DRIVERS
fffff880`044c4000 fffff880`04502000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f0f000 fffff880`00f66000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03cb3000 fffff880`03d3d000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04530000 fffff880`04546000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010e3000 fffff880`010ee000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04502000 fffff880`0450a000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`04390000 fffff880`04396000   AsIO     AsIO.sys     Mon Aug 03 03:03:16 2009 (4A768BB4)
fffff880`06bf5000 fffff880`06c00000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00d9b000 fffff880`00da4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00da4000 fffff880`00dce000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05a86000 fffff880`05aa6000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`048ee000 fffff880`050ff000   atikmdag atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
fffff880`04232000 fffff880`0427e000   atikmpag atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
fffff880`06b0a000 fffff880`06b34000   bdfm     bdfm.sys     Thu Apr 22 09:20:49 2010 (4BD04D31)
fffff880`02c1c000 fffff880`02c48000   bdfndisf6 bdfndisf6.sys Fri Aug 20 11:41:49 2010 (4C6EA23D)
fffff880`0114e000 fffff880`011b3000   bdfsfltr bdfsfltr.sys Fri Jun 25 09:41:26 2010 (4C24B206)
fffff880`02c48000 fffff880`02c6f000   bdfwfpf  bdfwfpf.sys  Fri Aug 20 11:41:40 2010 (4C6EA234)
fffff880`06b34000 fffff880`06b53000   BDHV     BDHV.SYS     Thu Apr 22 09:20:29 2010 (4BD04D1D)
fffff880`02d91000 fffff880`02d98000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0437f000 fffff880`04390000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06195000 fffff880`061b3000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00610000 fffff960`00637000   cdd      cdd.dll      unavailable (00000000)
fffff880`043d2000 fffff880`043ef000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`02d5e000 fffff880`02d88000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cc1000 fffff880`00d81000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`013ae000 fffff880`013de000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c63000 fffff880`00cc1000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01532000 fffff880`015a5000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04520000 fffff880`04530000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`066a8000 fffff880`066b6000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`042de000 fffff880`04361000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`04361000 fffff880`0437f000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03c68000 fffff880`03c77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01496000 fffff880`014ac000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05ae3000 fffff880`05b05000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`066b6000 fffff880`066c0000   dump_diskdump dump_diskdump.sys Mon Jul 13 20:01:00 2009 (4A5BCABC)
fffff880`0674c000 fffff880`0675f000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`066c0000 fffff880`0674c000   dump_mv91xx dump_mv91xx.sys Fri Dec 25 01:45:39 2009 (4B345F93)
fffff880`02d43000 fffff880`02d4b000   dump_mvxxmm dump_mvxxmm.sys Fri Dec 25 01:45:15 2009 (4B345F7B)
fffff880`0669c000 fffff880`066a8000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`050ff000 fffff880`051f3000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`0678a000 fffff880`067a6b00   ewusbmdm ewusbmdm.sys Mon Dec 07 06:53:24 2009 (4B1CECB4)
fffff880`067b6000 fffff880`067f5000   ewusbnet ewusbnet.sys Mon Dec 07 06:35:29 2009 (4B1CE881)
fffff880`0113a000 fffff880`0114e000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010ee000 fffff880`0113a000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015b6000 fffff880`015c0000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`015c0000 fffff880`015fa000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`0450a000 fffff880`04517000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02e1d000 fffff800`02e66000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06429000 fffff880`06442000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06442000 fffff880`0644a080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0641b000 fffff880`06429000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`060cd000 fffff880`06195000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017e2000 fffff880`017eb000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`043bc000 fffff880`043d2000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0440b000 fffff880`0441a000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05b62000 fffff880`05b70000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bbf000 fffff800`00bc9000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0427e000 fffff880`042c1000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01518000 fffff880`01532000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0178d000 fffff880`017b8000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05b05000 fffff880`05b0a200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`05b2c000 fffff880`05b41000   LHidFilt LHidFilt.Sys Thu Mar 18 04:51:17 2010 (4BA1E985)
fffff880`05b70000 fffff880`05b85000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05b4e000 fffff880`05b62000   LMouFilt LMouFilt.Sys Thu Mar 18 04:51:24 2010 (4BA1E98C)
fffff880`0644b000 fffff880`0646e000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c0b000 fffff880`00c4f000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`067a7000 fffff880`067b6000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`0675f000 fffff880`0676d000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0441a000 fffff880`04429000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05b41000 fffff880`05b4e000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d81000 fffff880`00d9b000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`061b3000 fffff880`061cb000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`061cb000 fffff880`061f8000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`06000000 fffff880`0604e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0604e000 fffff880`06071000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02c00000 fffff880`02c0b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f6f000 fffff880`00f79000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`014ba000 fffff880`01518000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03c5d000 fffff880`03c68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017d0000 fffff880`017e2000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01020000 fffff880`010ac000   mv91xx   mv91xx.sys   Fri Dec 25 01:45:39 2009 (4B345F93)
fffff880`010db000 fffff880`010e3000   mvxxmm   mvxxmm.sys   Fri Dec 25 01:45:15 2009 (4B345F7B)
fffff880`0163b000 fffff880`0172d000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0456a000 fffff880`04576000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`05bd8000 fffff880`05beb000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04576000 fffff880`045a5000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05a71000 fffff880`05a86000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03db1000 fffff880`03dc0000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03d3d000 fffff880`03d82000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0172d000 fffff880`0178d000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02c0b000 fffff880`02c1c000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03c51000 fffff880`03c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e66000 fffff800`03443000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0120b000 fffff880`013ae000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02d88000 fffff880`02d91000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0443d000 fffff880`04455000   nusb3hub nusb3hub.sys Thu Jan 21 22:22:18 2010 (4B5919EA)
fffff880`04200000 fffff880`04230000   nusb3xhc nusb3xhc.sys Thu Jan 21 22:22:21 2010 (4B5919ED)
fffff880`05b85000 fffff880`05bd8000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03d8b000 fffff880`03db1000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fb9000 fffff880`00fce000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f79000 fffff880`00fac000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fe3000 fffff880`00fea000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fea000 fffff880`00ffa000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015a5000 fffff880`015b6000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`02c9a000 fffff880`02d40000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05aa6000 fffff880`05ae3000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c4f000 fffff880`00c63000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04546000 fffff880`0456a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`045a5000 fffff880`045c0000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`045c0000 fffff880`045e1000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`045e1000 fffff880`045fb000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03c00000 fffff880`03c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04400000 fffff880`0440b000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02ddb000 fffff880`02de4000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02de4000 fffff880`02ded000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02ded000 fffff880`02df6000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01600000 fffff880`0163a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`042c1000 fffff880`042d9000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06475000 fffff880`0669b300   RTKVHD64 RTKVHD64.sys Fri Jan 29 01:48:35 2010 (4B6284C3)
fffff880`010ac000 fffff880`010db000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`06071000 fffff880`0607c000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`017c8000 fffff880`017d0000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06a74000 fffff880`06b0a000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06a0d000 fffff880`06a74000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`0607c000 fffff880`060a9000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04429000 fffff880`0442a480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01801000 fffff880`019fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`060a9000 fffff880`060bb000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02c8d000 fffff880`02c9a000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02c6f000 fffff880`02c8d000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03ddb000 fffff880`03def000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004e0000 fffff960`004ea000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04396000 fffff880`043bc000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0442b000 fffff880`0443d000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0676d000 fffff880`0678a000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04230000 fffff880`04231f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`048cd000 fffff880`048de000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05a17000 fffff880`05a71000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04877000 fffff880`048cd000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06400000 fffff880`0641b000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`0486a000 fffff880`04877000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fac000 fffff880`00fb9000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02d98000 fffff880`02da6000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02da6000 fffff880`02dcb000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`017b8000 fffff880`017c8000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fce000 fffff880`00fe3000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0144a000 fffff880`01496000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03dc0000 fffff880`03ddb000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02dcb000 fffff880`02ddb000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e5c000 fffff880`00f00000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f00000 fffff880`00f0f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03d82000 fffff880`03d8b000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003b0000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`04517000 fffff880`04520000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f66000 fffff880`00f6f000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05b0b000 fffff880`05b2c000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`06b53000 fffff880`06b84000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
fffff880`04460000 fffff880`044c4000   yk62x64  yk62x64.sys  Wed May 20 04:14:06 2009 (4A13BBCE)
Unloaded modules:
fffff880`06b84000 fffff880`06bf5000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`017eb000 fffff880`017f9000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`014ac000 fffff880`014b6000   dump_scsipor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`02cb7000 fffff880`02d43000   dump_mv91xx.
    Checksum:  00000000
    ImageSize:  0008C000
fffff880`02d4b000 fffff880`02d5e000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
