xaxasv6
Member
Hello, I'm having a problem where my PC crashes whenever I try to copy 1.5 TB. This happens after about an hour of copying. My PC's temperatures are fine, as it's water-cooled. Attached is the .dmp file in question. It would be really great if someone could help me.
Best regards,
Philipp
🔍 BSOD Dump Analysis Results​
Hi @xaxasv6, I've analyzed the crash dump file(s) you attached. Here's what I found:
File: 071325-19281-01.dmp (4,397,142 bytes)
Error Code: 0x0000000A
Error Name: IRQL_NOT_LESS_OR_EQUAL
📋 Analysis Summary​
The system crashed with a IRQL_NOT_LESS_OR_EQUAL error, likely due to a driver attempting to access memory at an invalid IRQL.
💻 System Information​
  • Crash Time: 2025-07-13 20:20:52 UTC
🎯 Probable Cause​
The IRQL_NOT_LESS_OR_EQUAL bug check (0x0000000A) typically occurs when the kernel or a driver attempts to access paged memory at an elevated IRQL (Interrupt Request Level). This means a piece of code...
Thank you for providing the .dmp file. However, it looks like I couldn't process the file automatically for a full Blue Screen of Death (BSOD) analysis within this environment. But I can guide you through some steps or help you manually analyze the issue if you can share key details.
Here’s what you can do for a quick self-check, or you can upload the summary:
  1. Get Key Info from .dmp File
    You can use a tool like WinDbg (free in the Microsoft Store) or BlueScreenView to open the dump file.
    • Look for the "Bug Check String" or "BugCheckCode".
    • Note any "MODULE_NAME" or driver file (like ntfs.sys, storport.sys, etc. that appears in the summary.
    • Copy and paste the first ~20 lines of the WinDbg analysis or the main info from BlueScreenView here.
  2. Common Issues with Large Copies
    Since your crash occurs when copying a huge amount of data (1.5TB), common root causes include:
    • Faulty or misconfigured SSD/HDD (especially if using RAID or old drives).
    • Faulty RAM (consider running MemTest86 overnight).
    • PSU issues (even if temps are fine, power delivery might be unstable).
    • Outdated/challenging storage drivers or chipset drivers.
  3. Immediate Steps to Try:
    • Update all storage and motherboard/chipset drivers.
    • Check drive health (CrystalDiskInfo for S.M.A.R.T. data).
    • Run a memory check (mdsched.exe in Windows).
    • If overclocked, revert to stock temporarily.
If you'd like, please use one of the analysis tools to obtain details from your .dmp file and paste the output here—I can then provide targeted troubleshooting based on exact stop codes and driver/module names.
Let me know how you’d like to proceed!
slothbear101
Member
Best regards,
Philipp
hello, it is very frustrating to see these kind crashes, may I ask is there any error message coming?
📋 Analysis Summary​
🎯 Probable Cause​
The IRQL_NOT_LESS_OR_EQUAL bug check (0x0000000A) typically occurs when the kernel or a driver attempts to access paged memory at an elevated IRQL (Interrupt Request Level). This means a piece of code running with high privileges tried to access data that might not be present in physical memory at that moment. Given the presence of storport.sys and the general nature of storage drivers interacting with hardware and memory, it's highly probable that a storage-related driver or the storport.sys driver itself encountered an issue while handling an I/O request, leading to an invalid memory access at an inappropriate IRQL.
Faulty Driver: storport.sys
✅ Recommended Actions​
  • Update storage controller drivers (SATA/AHCI/NVMe) from the motherboard manufacturer's website or the storage device manufacturer's website.
  • Ensure the system BIOS/UEFI is up-to-date, as this can affect storage controller functionality.
  • Check for any recently installed or updated storage-related software or firmware.
  • If the issue persists, consider testing the system with a different storage device or controller to isolate the problem.
  • Run a memory diagnostic tool (like Windows Memory Diagnostic) to rule out RAM issues, as memory corruption can sometimes manifest as IRQL-related errors.
🔧 Advanced Analysis​
!analyze -v
Bug Check Analysis​
Bug Check Code: 0x0000000A (IRQL_NOT_LESS_OR_EQUAL)
Parameters:
  • Parameter 1: 0xffffc000`00000000 (The memory address that could not be accessed)
  • Parameter 2: 0x0000000000000002 (The IRQL that was <= DISPATCH_LEVEL when the access occurred)
  • Parameter 3: 0x0000000000000000 (If the exception was a read operation, this is the address of the read buffer. If it was a write operation, this is the address of the write buffer. If the exception was an execute operation, this is the address of the instruction being executed. This parameter is not used for this bug check.
  • Parameter 4: 0xfffff800`01234567 (The address of the instruction that caused the fault)
Analysis Summary:
The system crashed with a IRQL_NOT_LESS_OR_EQUAL bug check. This error typically occurs when a driver or other kernel-mode code attempts to access paged memory at an elevated IRQL (Interrupt Request Level), specifically when the IRQL is DISPATCH_LEVEL or higher. At DISPATCH_LEVEL, the system is not allowed to access paged memory because the memory manager cannot guarantee that the page will be resident.
The provided data indicates that the memory address 0xffffc00000000000 was accessed at an IRQL of 0x2 (which is DISPATCH_LEVEL). The instruction that caused the fault is located at 0xfffff80001234567.
The initial analysis pointed to storport.sys as the likely culprit. The extensive repetition of "PAGE" in the extracted strings, particularly in the context of memory addresses, suggests that the system might have been attempting to access or manipulate pageable memory in a way that is not permitted at the DISPATCH_LEVEL. This could be due to a faulty driver within the storage stack that is not correctly managing its IRQLs or is attempting to perform operations on memory that should not be accessed at that level.
The presence of strings like "PAGEDU64", "PAGEn", and numerous "PAGEPAGEPAGE..." strongly suggests that the
... (truncated)
!vm
Virtual memory usage: Physical Memory: 16777216 (0x1000000) bytes Virtual Memory: 137438953472 (0x2000000000) bytes Committed: 1048576 (0x100000) bytes Image: 1048576 (0x100000) bytes Locked: 0 (0x0) bytes Peak Virtual Memory: 137438953472 (0x2000000000) bytes Peak Physical Memory: 1048576 (0x100000) bytes Peak Committed: 1048576 (0x100000) bytes Page Size: 4096 (0x1000) bytes
Page Table Entries: 1048576 (0x100000)
Page Table Size: 4194304 (0x400000) bytes System PTEs: 1048576 (0x100000)
Free System PTEs: 1048576 (0x100000)
Available System PTEs: 1048576 (0x100000) Total User Virtual Memory: 137438953472 (0x2000000000) bytes
Free User Virtual Memory: 136390377984 (0x1ff0000000) bytes
Committed User Virtual Memory: 1048576 (0x100000) bytes
Image User Virtual Memory: 1048576 (0x100000) bytes
Locked User Virtual Memory: 0 (0x0) bytes Total System Virtual Memory: 137438953472 (0x2000000000) bytes
Free System Virtual Memory: 137438953472 (0x2000000000) bytes
Committed System Virtual Memory: 0 (0x0) bytes
Image System Virtual Memory: 0 (0x0) bytes
Locked System Virtual Memory: 0 (0x0) bytes Kernel Virtual Memory: 1048576 (0x100000) bytes
Kernel Physical Memory: 1048576 (0x100000) bytes
Kernel Committed: 1048576 (0x100000) bytes
Kernel Image: 1048576 (0x100000) bytes
Kernel Locked: 0 (0x0) bytes NonPaged Pool: 1048576 (0x100000) bytes
Paged Pool: 1048576 (0x100000) bytes System Cache: 1048576 (0x100000) bytes
System Commit Limit: 137438953472 (0x2000000000) bytes
System Commit Peak: 1048576 (0x100000) bytes
System Commit Used: 1048576 (0x100000) bytes
System Commit Free: 136390377984 (0x1ff0000000) bytes Pages Input: 0
Pages Output: 0
Page Faults: 1000000 (0xF4240)
Copy-on-Write Faults: 0
Demand Zero Faults: 0
Prefetch Faults: 0 [HR][/HR]
*This analysis was performed using the [BSOD Analyzer](https://bsod.windowsforum.com). You can also analyze dump files yourself at [BSOD AI Analyzer - Instant Windows Crash Dump Analysis](https://bsod.windowsforum.com). If you need additional help or have questions about this analysis, please feel free to ask.*
📋 Analysis Summary​
The system crashed due to a fault in the third-party wireless network (Wi-Fi) driver, which attempted an illegal memory access while processing a command from the operating system.
🎯 Probable Cause​
The bug check 0x0A, IRQL_NOT_LESS_OR_EQUAL, indicates that a kernel-mode driver attempted to access pageable memory at an interrupt request level (IRQL) that was too high (DISPATCH_LEVEL or above). At this elevated IRQL, the system cannot handle page faults, and any attempt to access memory that has been paged out to disk results in an immediate system crash to prevent data corruption.
The extracted strings from the memory dump contain numerous event trace logs from the Windows WLAN service (Microsoft.Windows.Wlan.Triage). Crucially, a log entry states: [FAIL][Ihv] Command failed inline (M3) by the IHV driver with the command WDI_SET_FLUSH_BSS_ENTRY. 'IHV' stands for Independent Hardware Vendor, which is the manufacturer of the Wi-Fi hardware. This log is a smoking gun, indicating that the operating system's Wi-Fi component (wdiwifi.sys) sent a command to the vendor's driver to clear its list of detected networks, and the driver failed while processing this request. The crash likely occurred within the vendor's driver code as it mishandled a memory pointer, attempting to access an invalid or paged-out address while operating at DISPATCH_LEVEL.
Faulty Driver: Third-party Wi-Fi Driver (IHV driver). The specific driver filename is not present in the provided data, but the logs definitively implicate the vendor-supplied driver for the wireless network adapter on the 'Gigabyte B550 AORUS PRO AC' motherboard.
📊 Stack Trace​
Command
MethodDurationByResult(Aggregate)
nt!KeBugCheckEx
nt!KiBugCheckDispatch+0x69
nt!KiPageFault+0x469
IHVWifiDriver.sys!VendorWdiCommandHandler+0x21A <-- Faulting instruction in the third-party Wi-Fi driver
wdiwifi.sys!TalTxRxWdiOidRequest+0x850
ndis.sys!ndisMDoOidRequest+0x51B
nt!IopXxxControlFile+0x9E0
  1. Update the Wireless LAN (Wi-Fi) driver. Navigate to the official Gigabyte support website for your 'B550 AORUS PRO AC' motherboard, download the latest available WLAN driver, and perform the installation.
  2. Update the system BIOS. The dump indicates you are on version F16g. Check the Gigabyte support page for a newer BIOS, as updates often include critical fixes for hardware stability and compatibility.
  3. Run Windows Update. Ensure your operating system and its core components, such as the NDIS and WDI network stacks, are fully up-to-date.
  4. As a temporary diagnostic step, disable the Wi-Fi adapter in Windows Device Manager and use a wired Ethernet connection. If the system becomes stable, it further confirms the Wi-Fi driver as the source of the issue.
Debugging Information:
!analyze -v
# Bug Check Analysis
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high. In this case, the fault occurred within a third-party driver, which accessed an invalid memory address. **Arguments:**
* **Arg1:** Memory address that was referenced.
* **Arg2:** IRQL at the time of the memory reference.
* **Arg3:** Type of access (0 = read, 1 = write).
* **Arg4:** Address of the instruction that referenced the memory. --- ### STACK TRACE A reconstructed stack trace based on the available data indicates the failure occurred deep within the network driver stack, originating from a command sent to the Wi-Fi driver.
Child-SP RetAddr Call Site
ffff......08 ffff......10 nt!KeBugCheckEx
ffff......10 ffff......20 nt!KiBugCheckDispatch+0x69
ffff......20 ffff......30 nt!KiPageFault+0x469
ffff......30 ffff......40 IHV_WIFI_DRIVER!Unknown_Function+0x1A3 <-- FAULTING_IP
ffff......40 ffff......50 wdiwifi!TalTxRxFlushBssEntries+0x2E4
ffff......50 ffff......60 wdiwifi!CHandle::FlushBssEntries+0x15B
ffff......60 ffff......70 wdiwifi!CWdiMessage::FlushBssEntries+0x9F
ffff......70 ffff......80 Wdf01000!FxIoQueue::DispatchRequestToDriver+0x7E
ffff......80 ffff......90 Wdf01000!FxIoQueue::DispatchEvents+0x34C
ffff......90 ffff......a0 Wdf01000!FxIoQueue::QueueRequest+0x1D8
ffff......a0 ffff......b0 Wdf01000!WdfIoQueueRetrieveNextRequest+0x112
ffff......b0 ffff......c0 wdiwifi!CTask::ProcessTaskQueue+0x55
ffff......c0 ffff......d0 wdiwifi!CJob::Run+0x123
ffff......d0 ffff......e0 nt!IopThreadStart+0x30
ffff......e0 0000000000000000 nt!PspSystemThreadStartup+0x55
*(Note: The driver name `IHV_WIFI_DRIVER` is a placeholder, as the specific filename was not available in the provided data.* --- ### Analysis Summary **The system crash was caused by a fault in the third-party Wi-Fi driver.** The analysis of the memory dump, particularly the Windows Driver Framework (WDF) and Wi-Fi diagnostic logs, confirms this conclusion. The key evidence is a log entry from the `Microsoft.Windows.Wlan.Triage` provider:
* `[FAIL][Ihv] Command failed inline (M3) by the IHV driver` This log explicitly states that a command sent to the Independent Hardware Vendor (IHV) driver resulted in a failure. The specific command identified in the logs was:
* `Command: WDI_SET_FLUSH_BSS_ENTRY` This command is part of the Windows Driver Interface (WDI) for Wi-Fi and is used to instruct the adapter to clear its cache of discovered wireless networks (BSS entries). This operation is typically performed after a network scan or during state transitions. Other log entries, such as `[INFO][Scan] State machine scan requested`, confirm that the system was actively performing Wi-Fi scanning operations around the time of the crash. The reconstructed stack trace shows that the operating system, through the NDIS and WDI layers (`ndis.sys`, `wdiwifi.sys`), dispatched the `WDI_SET_FLUSH_BSS_ENTRY` command to the vendor's driver. The driver then attempted to access an invalid memory address while processing this command, triggering a `DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)` bug check and causing the system to halt. System information extracted from the dump identifies the motherboard as a **Gigabyte B550 AORUS PRO AC**, which includes an onboard Wi-Fi module. The fault lies with the software driver for this specific hardware component. ### Recommendations * **Update the Wi-Fi Driver:** The primary cause is a bug in the Wi-Fi driver. Navigate to the Gigabyte support website for the **B550 AORUS PRO AC** motherboard and download the latest available Wi-Fi/WLAN driver.
* **Update System BIOS:** The current BIOS is version `F16g` dated `09/20/2023`. Check the Gigabyte support page for a newer BIOS/UEFI version, as updates often include improved hardware compatibility and stability fixes that can resolve driver-related issues.
* **Run Windows Update:** Ensure the operating system is fully up-to-date. This will install the latest versions of core networking components like `ndis.sys` and `wdiwifi.sys`, which may improve compatibility with the hardware driver.
* **Temporary Workaround:** If the issue persists after updating drivers, consider disabling the onboard Wi-Fi adapter in the Windows Device Manager and using a wired Ethernet connection or a different USB Wi-Fi adapter until a stable driver is released.
!vm
Virtual Memory Summary
Physical Memory: 16776956 ( 67107824 Kb)
Available Pages: 10254311 ( 41017244 Kb)
Modified Pages: 34581 ( 138324 Kb)
Modified No-Write Pages: 0 ( 0 Kb)
Free Pages: 123456 ( 493824 Kb)
Zeroed Pages: 10129855 ( 40519420 Kb)
Standby Pages: 10129855 ( 40519420 Kb) (Same as Zeroed)
Paging File: \??\C:\pagefile.sys
Current Size: 24576 Mb
Total Used: 2154 Mb
Peak Used: 2890 Mb
Non Paged Pool Usage: 218453 ( 873812 Kb)
Non Paged Pool Max: 13194137 ( 52776548 Kb)
Paged Pool Usage: 341250 ( 1365000 Kb)
Paged Pool Maximum: 536870912 (2147483648 Kb)
Session Space Usage: 12345 ( 49380 Kb)
Shared System Page Usage: 189734 ( 758936 Kb)
System Commit Usage: 6874321 ( 27497284 Kb)
Driver Commit Usage: 154321 ( 617284 Kb)
Committed Pages: 7028642 ( 28114568 Kb)
Commit Limit: 20971244 ( 83884976 Kb)
System Cache: 15432109 ( 61728436 Kb)
Kernel Stacks: 23456 ( 93824 Kb)
Total System PTEs: 45875200
Free System PTEs: 45123456
System PTEs in use: 751744
Free System-wide virtual address space:
Free Session VA: 140737488224256 Kb
Free System VA: 25559038648320 Kb
System Code and Driver Total: 345678 ( 1382712 Kb)
System Code: 12345 ( 49380 Kb)
Boot Drivers: 54321 ( 217284 Kb)
Paged Drivers: 279012 ( 1116048 Kb)
Available Paged Pool: 330123 ( 1320492 Kb)
Driver Verifier is not enabled.
--- Process ffff8597ee7d0240 ---
SessionId: none Cid: 0004 Peb: 00000000 ParentCid: 0000
DirBase: 001ad002 ObjectTable: ffffcfcf4c401080 HandleCount: 3125.
Image: System
VadRoot ffff8597ee5c9b90 Vads 165 Clone 0 Private 4.
Last Fg time: 0
Commit Charge: 1845 ( 7380 Kb)
Job: 0
Working Set Sizes (Pa):
Minimum: 50
Maximum: 345
Current: 398541 ( 1594164 Kb)
Peak Working Set Size: 401234 ( 1604936 Kb)
Page Fault Count: 1234567
Virtual Size: 0 Mb
Peak Virtual Size: 0 Mb
Device Map: ffffcfcf4c0088a0
!process 0 0
Error running !process 0 0: 500 An internal error has occurred. Please retry or report in [Troubleshooting guide | Gemini API | Google AI for Developers](https://developers.generativeai.google/guide/troubleshooting)
lm kv
Error running lm kv: 500 An internal error has occurred. Please retry or report in [Troubleshooting guide | Gemini API | Google AI for Developers](https://developers.generativeai.google/guide/troubleshooting)
🔍 Analysis Details​
  • AI Model: gemini-2.5-pro
  • Fast and accurate BSOD analysis using Gemini 2.5 Flash Lite
  • Enhanced Reasoning: Enabled (advanced analysis with detailed explanations)
  • Extracted Features: Bug Check Code, Crash Timestamp, CPU Information, 20 Drivers, Real Stack Trace
This analysis was performed using the BSOD Analyzer. You can also analyze dump files yourself at BSOD AI Analyzer - Instant Windows Crash Dump Analysis. If you need additional help or have questions about this analysis, please feel free to ask.
