romo96
Hello. I have installed new windows 7,on my previous windows 7. Till that, i have saved my important files in Local disc D. Windows is installed on local disc C.But previous windows version moved moved to D disk. And my files, that were in D disk, have lost.What can I do for moving back my files, which are very important for me....??please, help me,if you can.
Thanks Beforehand
You most likely installed the new Win 7 over your data partition rather than over the old Win 7 partition. it is important to always MAKE SURE where you are installing an OS. When installing any OS, if you choose to install over an old OS, it WILL NOT move the old installation, it will install directly in the same partition. If this is indeed what you did, you overwrote your data with the new installation. Sorry but your data will most likely be lost. Data recovery tools are only good if the old lost data has not been overwritten. it's worth trying but in your case will probably not be effective.
See my attachment in post 15 above. As Elmer says if you name the partitions so they are VERY obvious, these mistakes will become a thing of the past.
Thank's to all for trying to help me.On next time i have to be more careful choosing partition. Thanks to all.This was lesson for me!!
