Windows 7 Please help tried every thing bsod
ushhh
hello every one i have gotten a bsod a few times now and i cant seem to figure out how to fix it please find attached my minidump file thanks
Only 93 updates since SP1 - most systems have 130 to 140. Please visit Windows Update and get ALL available updates
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM)...
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
This device is disabled:
Intel(R) Centrino(R) Wireless Bluetooth(R) 4.0 + High Speed Adapter USB\VID_8087&PID_07DA\6&65B8F94&0&1 This device is disabled.
Is this deliberate? If so, why?
Please uninstall MSI Afterburner. It, along with Riva Tuner and EVGA Precision, are known to cause BSOD's on some Win7 systems.
If overclocking, please stop while we're troubleshooting. Once we've stopped the BSOD's - feel free to resume the overclock.
MSINFO32 points to vsserv as an issue in one of the BSOD's. This is associated with your BitDefender application. Please un-install it. Then download/install a fresh copy of the latest, Win7 compatible version
This driver is suspicious to me (TMP4BCE.tmp). Please perform a full system scan once you've reinstalled BitDefender.
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Wed Oct 17 06:31:37.983 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101712-7004-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:02:32.858[/B]
BugCheck Code: [B]BugCheck 4A, {77a6138a, 2, 0, fffff88015014b60}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )[/B]
BugCheck Info: [B]IRQL_GT_ZERO_AT_SYSTEM_SERVICE (4a)[/B]
PROCESS_NAME: [B]vsserv.exe[/B]
BUGCHECK_STR:  RAISED_IRQL_FAULT
FAILURE_BUCKET_ID: [B]X64_RAISED_IRQL_FAULT_vsserv.exe_nt!KiSystemServiceExit+245[/B]
CPUID:        "Intel(R) Core(TM) i7-3820QM CPU @ 2.70GHz"
MaxSpeed:     2700
CurrentSpeed: [B]2693[/B]
  BIOS Version                  G75VW.210
  BIOS Release Date             06/15/2012
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product Name                  G75VW
[/font]
3rd Party Drivers:
[B]tmp4BCE.tmp                 Sat Jul 26 09:29:37 2008 (488B26C1)[/B]
[B]ASMMAP64.sys                Thu Jul  2 05:13:26 2009 (4A4C7A36)[/B]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[B]kbfiltr.sys                 Mon Jul 20 05:21:42 2009 (4A643726)[/B]
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
TurboB.sys                  Fri Apr 16 19:07:26 2010 (4BC8EDAE)
atkwmiacpi64.sys            Tue Sep  6 21:44:52 2011 (4E66CC94)
AiCharger.sys               Thu Sep 22 22:04:40 2011 (4E7BE938)
bdfwfpf.sys                 Mon Nov 14 12:16:17 2011 (4EC14CE1)
avchv.sys                   Fri Nov 25 04:04:45 2011 (4ECF5A2D)
SynTP.sys                   Thu Jan 26 18:20:22 2012 (4F21DFB6)
Smb_driver.sys              Thu Jan 26 18:21:28 2012 (4F21DFF8)
AMPPAL.sys                  Thu Mar 15 09:02:45 2012 (4F61E875)
bdvedisk.sys                Tue Apr 17 07:34:26 2012 (4F8D5542)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
viahduaa.sys                Fri May  4 06:35:46 2012 (4FA3B102)
iusb3hub.sys                Mon May 21 03:21:36 2012 (4FB9ED00)
iusb3xhc.sys                Mon May 21 03:21:40 2012 (4FB9ED04)
iusb3hcs.sys                Mon May 21 03:23:42 2012 (4FB9ED7E)
Netwsw00.sys                Sun Jun  3 11:33:40 2012 (4FCB83D4)
avc3.sys                    Wed Jun  6 10:20:08 2012 (4FCF6718)
avckf.sys                   Wed Jun  6 10:24:19 2012 (4FCF6813)
bdfndisf6.sys               Mon Jun 18 07:55:01 2012 (4FDF1715)
trufos.sys                  Fri Jun 22 05:40:41 2012 (4FE43D99)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
L1C62x64.sys                Wed Jul 18 22:55:34 2012 (50077726)
gzflt.sys                   Wed Aug 29 10:52:43 2012 (503E2CBB)
iaStorA.sys                 Sat Sep  1 21:01:24 2012 (5042AFE4)
dump_iaStorA.sys            Sat Sep  1 21:01:24 2012 (5042AFE4)
iaStorF.sys                 Sat Sep  1 21:01:27 2012 (5042AFE7)
nvstusb.sys                 Tue Oct  2 14:11:53 2012 (506B2E69)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
[/font]
tmp4BCE.tmp - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Link Removed - Invalid URL
Smb_driver.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
dump_iaStorA.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
