Possible hardware related Win 7 + XP regular BSODs
Hello experts!
I've recently been experiencing a very regular BSOD on my PC. I'm fairly sure it's a hardware issue (minidumps here: View attachment Minidumps.zip ) as I've had a look at the minidump and it's a 124 error (0x124_GenuineIntel or X64_0x124_GenuineIntel_PROCESSOR_BUS depending on which dump I open). I thought that heat might have been the problem, so I've cleaned the (admittedly large amount of) dust from the innards, but it doesn't seem to have helped. Still could be the problem I guess, especially as the problem appears to become more severe (every 5 mins instead of every hour, say) when it's switched on for a long time. But then it also happens whenever I try anything processor-intensive (I think - haven't tested that extensively).
Two interesting points to note:
1) I have a dual boot Win 7 / XP system and the BSOD happens on both (lending weight to the hardware problem guess).
2) This started shortly after I installed a multitouch simulator for WP7 development on windows 7 (see Step by Step Tutorial : Installing Multi-Touch Simulator for Silverlight Phone 7 | Michael Sync). I have subsequently uninstalled, but the very first BSOD happened seconds after installation - coincidence?
I also could swear that I recently heard a mysterious loud "crack" noise, but I don't know when and I don't know if it came from the computer. But it's possible. Probably best to ignore that one.
I am currently running the win 7 memory test tool, but it's taking hours. I'll report back and edit this post if it comes back with any results.
In the meantime, if anyone can take a look at those minidump file and help out I'd be eternally grateful!
Here's a snippet of sample output from the most recent minidump:
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8004e25038, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000001040080f, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`009ec9d8 fffff800`03402903 : 00000000`00000124 00000000`00000000 fffffa80`04e25038 00000000`b2000000 : nt!KeBugCheckEx
fffff880`009ec9e0 fffff800`02f9a593 : 00000000`00000001 fffffa80`04e25ea0 00000000`00000000 fffffa80`04e25ef0 : hal!HalBugCheckSystem+0x1e3
fffff880`009eca20 fffff800`034025c8 : 00000000`00000728 fffffa80`04e25ea0 fffff880`009ecdb0 fffff880`009ecd00 : nt!WheaReportHwError+0x263
fffff880`009eca80 fffff800`03401f1a : fffffa80`04e25ea0 fffff880`009ecdb0 fffffa80`04e25ea0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`009ecbd0 fffff800`03401dd5 : 00000000`00000002 00000000`00000001 fffff880`009ece30 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`009ecc10 fffff800`033f5e88 : 00000000`00004000 00000000`00004000 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`009ecc40 fffff800`02e82fec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`009ecc70 fffff800`02e82e53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`009ecdb0 fffff800`02e7b4e4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`07997658 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!memmove+0xb4
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_BUS
Followup: MachineOwner
Cheers,
Karli
Hi, welcome to the forums,
as you've noticed it is
Probably caused by : hardware
which is not good.
First of all uninstall whatever you've installed recently and unplug whatever you've plugged in. Check your CPU - primetest95 and memory - memtest86 overnight or during 3-4 hrs.
090510-22390-01.dmp
BugCheck 124, {0, fffffa8004f20038, b2000000, 1040080f}
STACK_TEXT:
fffff880`009ec9d8 fffff800`033f8903 : 00000000`00000124 00000000`00000000 fffffa80`04f20038 00000000`b2000000 : nt!KeBugCheckEx
fffff880`009ec9e0 fffff800`02f90593 : 00000000`00000001 fffffa80`049cc7d0 00000000`00000000 fffffa80`049cc820 : hal!HalBugCheckSystem+0x1e3
fffff880`009eca20 fffff800`033f85c8 : 00000000`00000728 fffffa80`049cc7d0 fffff880`009ecdb0 fffff880`009ecd00 : nt!WheaReportHwError+0x263
fffff880`009eca80 fffff800`033f7f1a : fffffa80`049cc7d0 fffff880`009ecdb0 fffffa80`049cc7d0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`009ecbd0 fffff800`033f7dd5 : 00000000`00000002 00000000`00000001 fffff880`009ece30 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`009ecc10 fffff800`033ebe88 : 00000000`00000000 fffff880`009e4180 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`009ecc40 fffff800`02e78fec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`009ecc70 fffff800`02e78e53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`009ecdb0 fffff880`03b609c2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`02f1bc98 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : intelppm+0x39c2
Hi.
First lets take care of all software issues. Then if still necessary, we can look at hardware. Software (drivers) sometimes triggers these stops. I see notorious problems. Let's start.
Install my attachment to update your ATK0110 driver to latest:
ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005
Visit Intel's website to let it scan and install the latest drivers. This network driver is way too old and absolutely needs an update:
E1G6032E E1G6032E.sys Wed May 28 19:14:51 2008
http://downloadcenter.intel.com/default.aspx?iid=gg_support-EN_01+home_downloadctr
Reboot.
Post new dumps if it becomes necessary. We'll see what we can do or hopefully the above may have already fixed it.
Uninstall VirtualClone CD software. The driver is too old. Reboot.
VClone VClone.sys Fri May 22 19:08:37 2009
This one is less related to the crash, but you may want to update it at some point:
ctac32k.sys Wed Jul 02 11:38:22 2008
Creative audio
Creative audio
I think you might have mixed up crash dumps, perhaps? (I'm only looking at most recent, but that's not in there at all - so nothing to be concerned with.)
#7
Oh, I'm doing 090510-22390-01.dmp
(I see there one you find too - VClone VClone.sys Fri May 22 19:08:37 2009)
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\090510-22390-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e0a000 PsLoadedModuleList = 0xfffff800`03047e50
System Uptime: 0 days 1:20:14.733
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*** ERROR: Module load completed but symbols could not be loaded for intelppm.sys
1: kd> !analyze -v
Arguments:
Arg2: fffffa8004f20038, Address of the WHEA_ERROR_RECORD structure.
Debugging Details:
PROCESS_NAME:  System
CURRENT_IRQL:  f
STACK_TEXT:
STACK_COMMAND:  kb
fffff800`00ba9000 fffff800`00bb3000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e0a000 fffff800`033e6000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff800`033e6000 fffff800`0342f000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c24000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`00c38000 fffff880`00c7c000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:29:10 2009 (4A5BDF66)
fffff880`00c7c000 fffff880`00c90000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00c90000 fffff880`00cee000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00cee000 fffff880`00dae000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00dae000 fffff880`00dff000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`00e00000 fffff880`00e1b000   ctxusbm  ctxusbm.sys  Mon Sep 07 21:09:28 2009 (4AA54C58)
fffff880`00e1b000 fffff880`00e31000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`00e31000 fffff880`00e3d000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`00e44000 fffff880`00ee8000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ee8000 fffff880`00ef7000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00ef7000 fffff880`00f4e000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f4e000 fffff880`00f57000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f57000 fffff880`00f61000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f61000 fffff880`00f94000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f94000 fffff880`00fa1000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00fa1000 fffff880`00fb6000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00fb6000 fffff880`00fcb000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00fcb000 fffff880`00fe9000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`00fe9000 fffff880`00ff6000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`0105e000 fffff880`01083000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`01083000 fffff880`01093000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`01093000 fffff880`0109c000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`010a1000 fffff880`010fd000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`010fd000 fffff880`01104000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`01104000 fffff880`01114000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01114000 fffff880`0112e000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`0112e000 fffff880`01137000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`01137000 fffff880`01161000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`01161000 fffff880`0116c000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`0116c000 fffff880`011b8000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`011b8000 fffff880`011cc000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`011cc000 fffff880`011d5000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`011d5000 fffff880`011de000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`011de000 fffff880`011e9000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`011e9000 fffff880`011fa000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01209000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`01209000 fffff880`0122c000   ehdrv    ehdrv.sys    Mon Nov 16 09:51:48 2009 (4B010494)
fffff880`0122c000 fffff880`0123a000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`0123f000 fffff880`013e2000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013e2000 fffff880`013fc000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`0143a000 fffff880`01450000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01450000 fffff880`01480000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`014b6000 fffff880`014e0000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`014e4000 fffff880`01557000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`01557000 fffff880`01568000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01568000 fffff880`01572000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`01572000 fffff880`015be000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`015be000 fffff880`015f8000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`015f8000 fffff880`015ff000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0168b000 fffff880`016d5000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`016d7000 fffff880`017c9000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`017c9000 fffff880`017d9000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`017d9000 fffff880`017e1000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`017e1000 fffff880`017f3000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`017f3000 fffff880`017fc000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`02c00000 fffff880`02c0f000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`02c0f000 fffff880`02c2d000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`02c2d000 fffff880`02c35080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`02c38000 fffff880`02cc2000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02cc2000 fffff880`02d07000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02d07000 fffff880`02d10000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d10000 fffff880`02d36000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02d36000 fffff880`02d45000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d45000 fffff880`02d62000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02d62000 fffff880`02d7d000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02d7d000 fffff880`02dcb000   vmm      vmm.sys      Thu Jan 21 12:38:48 2010 (4B582EB8)
fffff880`02dcb000 fffff880`02ddf000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02ddf000 fffff880`02deb000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`02deb000 fffff880`02df6000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`02df6000 fffff880`02e00000   ElbyCDIO ElbyCDIO.sys Tue Feb 17 19:11:23 2009 (499AEFBB)
fffff880`03a00000 fffff880`03a23980   E1G6032E E1G6032E.sys Thu May 29 02:14:51 2008 (483DE76B)
fffff880`03a24000 fffff880`03a31000   fdc      fdc.sys      Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`03a31000 fffff880`03a3d000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`03a3d000 fffff880`03a5a000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`03a5a000 fffff880`03a78000   i8042prt i8042prt.sys Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`03a78000 fffff880`03a87000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03a87000 fffff880`03a97000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`03a97000 fffff880`03aa3000   unisofthid unisofthid.sys Sat May 16 21:08:52 2009 (4A0F0134)
fffff880`03aa3000 fffff880`03b26000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03b26000 fffff880`03b37000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03b37000 fffff880`03b5d000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03b5d000 fffff880`03b73000   intelppm intelppm.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03b73000 fffff880`03bb6000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`03bb6000 fffff880`03be7000   ctoss2k  ctoss2k.sys  Thu Apr 09 12:44:01 2009 (49DDC361)
fffff880`03be7000 fffff880`03c00000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`03c00000 fffff880`03c46000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`03c46000 fffff880`03c51000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`03c51000 fffff880`03ca7000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`03ca7000 fffff880`03cb8000   usbehci  usbehci.sys  Sat Oct 24 07:27:33 2009 (4AE28235)
fffff880`03cb8000 fffff880`03cc0000   ctprxy2k ctprxy2k.sys Thu Apr 09 12:46:13 2009 (49DDC3E5)
fffff880`03cc0000 fffff880`03cc5200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`03cc6000 fffff880`03cce000   ASACPI   ASACPI.sys   Mon Mar 28 05:30:36 2005 (42476C4C)
fffff880`03cce000 fffff880`03dc2000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`03dc2000 fffff880`03dff000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`03e00000 fffff880`03e5a000   usbhub   usbhub.sys   Sat Oct 24 07:28:24 2009 (4AE28268)
fffff880`03e5a000 fffff880`03e92000   ctsfm2k  ctsfm2k.sys  Thu Apr 09 12:43:48 2009 (49DDC354)
fffff880`03e92000 fffff880`03efa000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`03efb000 fffff880`03f2a000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`03f2a000 fffff880`03f45000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`03f45000 fffff880`03f66000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`03f66000 fffff880`03f80000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`03f80000 fffff880`03f8b000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`03f8b000 fffff880`03f9a000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03f9a000 fffff880`03fa9000   VClone   VClone.sys   Sat May 23 02:08:37 2009 (4A173075)
fffff880`03fa9000 fffff880`03fd8000   SCSIPORT SCSIPORT.SYS Tue Jul 14 03:01:04 2009 (4A5BCAC0)
fffff880`03fd8000 fffff880`03fd9480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`03fda000 fffff880`03fec000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`04800000 fffff880`0484a000   emupia2k emupia2k.sys Thu Apr 09 12:43:41 2009 (49DDC34D)
fffff880`0484a000 fffff880`04855000   flpydisk flpydisk.sys Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`04873000 fffff880`049f4000   ha20x2k  ha20x2k.sys  Thu Apr 09 12:45:37 2009 (49DDC3C1)
fffff880`04a00000 fffff880`04a35000   CT20XUT  CT20XUT.SYS  Thu Apr 09 12:47:24 2009 (49DDC42C)
fffff880`04a35000 fffff880`04a41000   NuidFltr NuidFltr.sys Tue Jun 29 11:54:32 2010 (4C29B4C8)
fffff880`04a41000 fffff880`04a4e000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`04a4e000 fffff880`04a5e000   point64  point64.sys  Tue Jun 29 11:54:31 2010 (4C29B4C7)
fffff880`04a5e000 fffff880`04a79000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`04a79000 fffff880`04a96000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`04a96000 fffff880`04ab0c00   usbaudio usbaudio.sys Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`04ab1000 fffff880`04ad4000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`04af5000 fffff880`04ba3000   ctac32k  ctac32k.sys  Wed Jul 02 11:38:22 2008 (486B3E7E)
fffff880`04ba3000 fffff880`04bad000   MTConfig MTConfig.sys Tue Jul 14 03:02:08 2009 (4A5BCB00)
fffff880`04bad000 fffff880`04bc2000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`04bc2000 fffff880`04bdd000   CTHWIUT  CTHWIUT.SYS  Thu Apr 09 12:47:27 2009 (49DDC42F)
fffff880`04c00000 fffff880`04c13000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`04c13000 fffff880`04c21000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`04c21000 fffff880`04c33000   dc3d     dc3d.sys     Thu Jul 01 13:07:45 2010 (4C2C68F1)
fffff880`04c33000 fffff880`04c41000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`04c41000 fffff880`04c42f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`04c4d000 fffff880`04daa000   CTEXFIFX CTEXFIFX.SYS Thu Apr 09 12:47:19 2009 (49DDC427)
fffff880`04daa000 fffff880`04db6000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`04db6000 fffff880`04dd3000   cdfs     cdfs.sys     Tue Jul 14 02:19:46 2009 (4A5BC112)
fffff880`04dd3000 fffff880`04de1000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`04de1000 fffff880`04ded000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`04ded000 fffff880`04df6000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05e00000 fffff880`05e2d000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`05e3a000 fffff880`05f0c000   eamon    eamon.sys    Mon Nov 16 09:51:14 2009 (4B010472)
fffff880`05f0c000 fffff880`05f2d000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`05f2d000 fffff880`05f42000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05f42000 fffff880`05f5a000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05f5a000 fffff880`06000000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`06800000 fffff880`0682d000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`0682d000 fffff880`0687b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`0687b000 fffff880`0689e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`0689e000 fffff880`068be000   epfwwfpr epfwwfpr.sys Mon Nov 16 09:46:31 2009 (4B010357)
fffff880`068be000 fffff880`068c9000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`068c9000 fffff880`068db000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`068ed000 fffff880`069b5000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`069b5000 fffff880`069d3000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`069d3000 fffff880`069eb000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`06c00000 fffff880`06c38000   RDPWD    RDPWD.SYS    Tue Jul 14 03:16:47 2009 (4A5BCE6F)
fffff880`06c38000 fffff880`06c6e000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`06c6e000 fffff880`06c79000   asyncmac asyncmac.sys Tue Jul 14 03:10:13 2009 (4A5BCCE5)
fffff880`06cef000 fffff880`06d85000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`06d85000 fffff880`06db6000   WUDFRd   WUDFRd.sys   Tue Jul 14 03:06:06 2009 (4A5BCBEE)
fffff880`06db6000 fffff880`06de4000   rdpdr    rdpdr.sys    Tue Jul 14 03:18:02 2009 (4A5BCEBA)
fffff880`06de4000 fffff880`06def000   tdtcp    tdtcp.sys    Tue Jul 14 03:16:32 2009 (4A5BCE60)
fffff880`06def000 fffff880`06dfe000   tssecsrv tssecsrv.sys Tue Jul 14 03:16:41 2009 (4A5BCE69)
fffff880`0fe00000 fffff880`0fea5700   ctaud2k  ctaud2k.sys  Thu Apr 09 12:46:11 2009 (49DDC3E3)
fffff880`0fea6000 fffff880`0fec8000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`0fecc000 fffff880`10bf5700   nvlddmkm nvlddmkm.sys Sun Apr 04 03:06:21 2010 (4BB7D7FD)
fffff880`10bf6000 fffff880`10bf7180   nvBridge nvBridge.kmd Sun Apr 04 02:50:52 2010 (4BB7D45C)
fffff880`10bf8000 fffff880`10c00000   mshidkmdf mshidkmdf.sys Tue Jul 14 03:06:24 2009 (4A5BCC00)
fffff960`000e0000 fffff960`003ef000   win32k   win32k.sys   unavailable (00000000)
fffff960`004a0000 fffff960`004aa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00770000 fffff960`00797000   cdd      cdd.dll      unavailable (00000000)
fffff960`008d0000 fffff960`00931000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`06c79000 fffff880`06cea000   spsys.sys
    Checksum:  00000000
fffff880`01480000 fffff880`0148e000   crashdmp.sys
    Checksum:  00000000
fffff880`0148e000 fffff880`0149a000   dump_ataport
    Checksum:  00000000
fffff880`0149a000 fffff880`014a3000   dump_atapi.s
    Checksum:  00000000
fffff880`014a3000 fffff880`014b6000   dump_dumpfve
    Checksum:  00000000
#8
Thanks for the speedy replies!
I'll work my way through your suggestions and report back with the results (it might take a few days though!).
Cheers,
Karli
#9
Cheers,
Karli
You're welcome. But why a few days to uninstall a software, install a driver from this page and let another page scan and install? That's like 5-7 minutes worth, less on a fast pc.
#10
Because it's late and I'm starting a new job on Monday so I want to avoid computers for a bit ;)
I actually tried your driver update suggestions, but my pc is bluescreening within seconds of startup now, so I haven't got past the java plugin install yet! I will put it to bed for the night and try again in the morning once it's cooled down properly.
Cheers,
Karli
#11
Great! You can boot to safe mode + networking to do everything, which shoudn't bsod there. If it does, definite hardware issue.
Much luck with the new employment!
#12
Here's where I'm up to:
  • Managed to update the ATK0110 driver.
  • The Windows 7 memory test freezes after a few minutes and I can't get it to run through.
  • Got the Intel tool to run; it seemed to think the wired network driver was up to date, but the graphics, audio and wireless network driver were not.
At this point I'm getting BSODs even in safe mode, and almost too frequently for me to copy any new minidumps over the network. I think it may well be time to admit defeat on this one and buy some new components. I'm hoping it's safe to reuse my graphics card and hard drives at least though, but my prime suspect now is CPU and/or motherboard.
Glad I posted here though - I definitely know where to come if I have any problems like this again. Thanks all!
Karli
#13
The memory is faulty. Test it with Memtest86+ to be sure.
CPU/motherboard/video is good.
You're welcome.
#14
That sounded worth a try...
Got to 93% of the first pass, 40% of the way through test #8 for 4096M - 5120M. No errors detected, but it hit an "Unexpected Interrupt - Halting" message with the following data:
Type: 47d5
PC: 86
CS: b
Eflag: bfffff00
Code: 10
DS: 2bb20
SS: 2ba34
Plus what looks like a whole bunch register and stack info values.
Will now repeat for a single DIMM and cycle through them.
Cheers,
Karli
#15
After much testing, it seems that the "B" channel memory slots are not working. My system *seems* to work fine with DIMMs in A1-A2 slots only, regardless of which DIMMs I choose. I currently have 4x1GB, so I have the option of switching to 2x2GB. That would be far cheaper than a new PC obviously!
Thanks again for the help - I'll mark this as solved.
Cheers,
Karli
