Power Monitor: PowerToys brings per monitor brightness and color control to Windows
Microsoft’s PowerToys appears poised to solve one of the most stubborn annoyances of multi‑monitor life: the need to squint behind your display and jab tiny OSD buttons just to dim a monitor, change color temperature, or lower built‑in speaker volume. A new PowerToys module — circulating under the working name Power Monitor — is currently in development and shows a simple, per‑monitor control surface with sliders for brightness, contrast, color temperature, and even speaker volume, all accessible from Windows rather than the monitor’s own on‑screen menus.
Four-monitor setup displays blue UI with display settings and a floating Quick Settings panel.Background / Overview​
For years Windows has provided easy, integrated brightness controls for built‑in laptop panels but not for most external monitors. That gap has spawned a healthy ecosystem of third‑party utilities — Monitorian, Twinkle Tray, DisplayBuddy and others — which talk to displays using the Display Data Channel / Command Interface (DDC/CI) and the Monitor Control Command Set (MCCS). These tools can be reliable and effective, but they’re fragmented, hardware‑dependent, and occasionally brittle depending on cables, docks and vendor implementations. A first‑party PowerToys module would give Windows users a unified, Microsoft‑maintained option and would likely become the go‑to choice for many users and IT teams. PowerToys itself has become Microsoft’s open, experimental playground for small, high‑utility features that don’t yet live in Settings. Recent PowerToys releases added tools like Light Switch (automatic theme switching) and regular enhancements to FancyZones and PowerToys Run — demonstrating Microsoft’s willingness to use PowerToys as a fast path for quality‑of‑life improvements. The proposed monitor tool fits that pattern: it’s visible, practical, and targeted at an everyday pain point.
What the new Power Monitor UI proposes​
The publicly shared screenshot and the accompanying GitHub discussion show a compact, flyout‑style control panel that appears to be designed to live in the same workflow space as other PowerToys flyouts and the Quick Settings area. Key UI and functional cues seen so far:
  • Per‑monitor controls — each connected screen listed with its model name and independent sliders.
  • Brightness and contrast sliders — primary controls shown prominently for each display.
  • Color temperature / white balance control — a slider or preset options for warm‑to‑cool adjustments.
  • Volume control — slider for monitors with built‑in speakers.
  • Potential for presets or per‑monitor profiles, and quick toggles to show/hide non‑controllable monitors.
These early mockups and proposed diffs are experimental; Microsoft has not announced a release date or guaranteed final feature set. The screenshots were shared by a PowerToys program manager on social media and then reported by multiple outlets, which picked up the initial details.
Under the hood: how software talks to a monitor​
Any Windows‑side monitor control must ride the industry standards that monitors expose. The technical plumbing that makes Twinkle Tray and Monitorian work is the same plumbing Power Monitor is expected to use:
  • DDC/CI (Display Data Channel / Command Interface) is the bidirectional protocol that lets a host query a monitor and send commands to it.
  • MCCS (Monitor Control Command Set) defines the set of commands — Virtual Control Panel (VCP) codes — for properties like brightness (commonly VCP 0x10), contrast (0x12), color temperature and speaker volume. The operating system exposes monitor configuration APIs that use DDC/CI under the hood.
Because DDC/CI and MCCS are standards, a single utility can, in principle, talk to a wide variety of displays. In practice, though, vendors implement subsets of MCCS, and some monitors only support a small number of VCP codes. The result: brightness often works, but more advanced VCP controls (precise color temperature adjustments, advanced color management or vendor‑specific features) may not be available on every display.
Compatibility and the practical limits​
A native Microsoft solution will simplify the user experience when it works, but the underlying hardware realities remain unchanged. Expect the same compatibility patterns PowerToys competitors face today.
Major compatibility considerations:
  • DDC/CI must be exposed end‑to‑end. Some USB‑C / Thunderbolt docks, inexpensive adapters, and certain DisplayLink chains do not forward DDC/CI, which prevents software from finding or controlling the monitor. That’s a common failure mode with third‑party utilities and will affect Power Monitor too unless the dock/vendor bridges are updated.
  • Monitor vendors vary in which MCCS VCP codes they implement. Most monitors expose brightness and sometimes contrast; fewer reliably expose color temperature or speaker volume via standard VCPs. Expect per‑monitor variance.
  • Connection type matters. DisplayPort and standard HDMI connections are the most likely to pass DDC/CI reliably. USB adapters, basic hubs, or non‑compliant dongles are common culprits when a monitor appears “uncontrollable”.
  • Firmware and drivers can affect behavior. Firmware updates for monitors and updated GPU/driver stacks can change whether DDC/CI calls succeed; that’s one reason third‑party utilities occasionally break across OS or driver updates.
Put simply: Power Monitor can centralize and simplify controls, but it cannot invent DDC/CI where the hardware path blocks it.
How this compares to existing third‑party solutions​
Third‑party apps have filled this space for years and will remain relevant for several reasons:
  • Twinkle Tray, Monitorian and DisplayBuddy already offer the core experience of slider‑based control and profiles, and have refined user interfaces and automations. They also provide an immediate compatibility test: if a third‑party tool can talk to your monitor, a Microsoft PowerToys module using the same standards almost certainly will too.
  • Paid or specialized utilities sometimes offer deeper integrations (hotkeys, per‑app automations, scripting, commercial support) that may take longer for Power Monitor to match.
  • PowerToys’ advantage will be distribution and trust: Windows users can get it via Microsoft Store, winget, or as part of enterprise images. That reduces friction for users who avoid installing unsigned or unknown software.
For many users, the path forward will be simple: try the new Power Monitor when it arrives; if your monitor isn’t controllable, fall back to a third‑party test app to confirm whether the limitation is hardware or software.
Practical advice: how to prepare and troubleshoot now​
If you want to be ready — or simply want to test whether your displays will work with Power Monitor when it lands — follow these steps:
  • Check your monitor OSD and enable DDC/CI or “Allow external control” if present.
  • Prefer direct DisplayPort or HDMI connections where possible when testing DDC/CI.
  • If using a dock, test with a direct cable to the GPU first; docks are often the compatibility choke point.
  • Install a third‑party DDC/CI tester (Monitorian, Twinkle Tray, or ddcutil on Linux) to confirm whether a display responds to VCP queries. If a monitor appears in those apps, Power Monitor will very likely control it too.
These steps will save time later and help you determine whether a missing control is due to Power Monitor limitations or the monitor’s own capabilities.
Enterprise and management considerations​
A PowerToys module distributed and maintained by Microsoft changes the calculus for IT administrators:
  • Deployability: PowerToys can be packaged in corporate images, distributed via winget, or governed with ADMX/Intune policies. That makes a first‑party monitor tool attractive for enterprise deployment compared to installing and maintaining a raft of third‑party apps across a fleet.
  • Policy controls: Enterprises will want to know whether Power Monitor can be disabled, preconfigured, or limited via Group Policy or Intune — an important detail IT teams should verify during pilot testing.
  • Support boundaries: For color‑critical workflows (photo and video studios), vendor or hardware calibration solutions will remain the recommended approach. Power Monitor is about convenience and quick adjustments, not certified color calibration workflows.
IT teams should pilot the feature on representative hardware and document fallback paths for devices where DDC/CI is blocked by docks or policy.
Benefits — why this matters for everyday users​
A simple, system‑level monitor control can deliver tangible, repeated benefits:
  • Less friction: No more reaching behind monitors or hunting for clumsy vendor apps when you need a quick brightness tweak.
  • Faster mode switching: Quickly shift between bright work settings and dim evening settings without interrupting workflows.
  • Unified multi‑monitor control: Normalize brightness and color across monitors from a single UI, which is useful when mixing different brands or panel types.
  • Better enterprise hygiene: Administrators can reduce support tickets caused by users installing unsupported apps when a first‑party option exists.
These are small, daily wins that compound into real productivity and comfort improvements for many users.
Risks, caveats and areas to watch​
While the proposal is promising, there are important caveats and potential risks to be mindful of:
  • Hardware limits remain. A Microsoft UI can’t force a monitor to implement more VCP controls; those decisions live with monitor vendors. Users should expect partial support in a minority of setups.
  • Color‑critical work: Changing brightness or color temperature via software can invalidate color profiles used in professional photo/video workflows. Professionals should re‑calibrate with a hardware colorimeter after major changes.
  • Driver/firmware regressions: Graphics driver updates or monitor firmware changes have been known to alter DDC/CI behavior. A first‑party PowerToys module reduces fragmentation but cannot eliminate the possibility of regressions triggered by other vendor updates.
  • Security considerations: Granting software control over external hardware introduces a theoretical attack surface. DDC/CI access typically requires local privileges, but administrators should verify how the Power Monitor module authenticates control requests and whether it exposes APIs to other apps. Treat unexpected or persistent changes in display settings as a suspicious indicator in sensitive environments.
  • Expect incremental delivery: PowerToys is an experimental channel. Features may land in stages (Dev/Beta channels first) and the module’s final name, scope, and behaviors could change before a stable release.
The sensible approach is pragmatic: welcome the convenience, but validate behavior on your hardware and keep calibration and management safeguards in place for professional contexts.
What to expect next​
At the moment, the Power Monitor concept exists as a GitHub proposal and early screenshots shared publicly; Microsoft has not provided a ship date. Observers should look for these milestones:
  • A merged pull request or a tracked issue in the PowerToys GitHub that changes status from draft to active work.
  • A PowerToys preview release (Dev or Canary) that surfaces the module for early testing.
  • Release notes indicating Group Policy or Intune settings for administrators.
  • Documentation on supported VCP codes and a compatibility list or detection behavior so users can understand which monitors will be controllable.
Until Microsoft ships a public build, third‑party tools remain reliable testbeds to understand whether your monitors will be controllable by this approach.
A native PowerToys monitor control module would be a welcome and practical upgrade for Windows 11 users who juggle multiple displays. By packaging brightness, contrast, color temperature and even speaker volume into a single, consistent UI, Microsoft can remove a small but persistent annoyance from daily workflows. The tool’s success will hinge on the immutable realities of hardware: whether DDC/CI is exposed by the monitor and by the connection path, and which MCCS VCP codes the display implements. In the short term, Power Monitor promises convenience and reduced friction; in the medium term, it could supplant many third‑party utilities as the standard way to manage external displays on Windows — provided Microsoft and hardware partners keep interoperability in focus.
Key takeaways:
  • Power Monitor — a proposed PowerToys module — aims to surface per‑monitor sliders for brightness, contrast, color temperature and volume directly in Windows.
  • It will rely on DDC/CI and MCCS (VCP codes) — the same standards used by existing third‑party utilities — so hardware compatibility patterns will remain the main constraint.
  • Test your monitors now using Twinkle Tray / Monitorian; if those apps work, Power Monitor should too when it ships.
  • For enterprises and color‑critical workflows, validate behavior on representative hardware and plan policies and calibration workflows before broad deployment.
The arrival of Power Monitor would not rewrite the laws of hardware compatibility, but it will remove a lot of daily friction — and for many users that will be enough to make multi‑monitor life feel markedly less annoying.
Source: Digital Trends Windows 11 could soon fix one of your biggest annoyances with using external monitors
