Two people work with holographic screens displaying futuristic data dashboards.
Microsoft’s Monitor is positioned as the single-pane observability lens Power Platform teams have been waiting for—bringing maker-level debugging, tenant-wide operational health metrics, contextual recommendations, and imminent alerting into a single, integrated experience that spans Power Apps and the Power Platform admin center. (microsoft.com, learn.microsoft.com)
Background / Overview​
Monitor began life as an in-studio debugging tool for Power Apps makers and evolved into a broader operational experience surfaced both in the Power Apps maker portal and the Power Platform admin center. The original Monitor tooling (often seen as the in-studio or “Live monitor” experience) is available by default for canvas apps and has been in Microsoft documentation and blogs for years as an essential troubleshooting capability for makers. (learn.microsoft.com, microsoft.com)
More recently Microsoft announced a unified Power Platform Monitor experience (sometimes referred to as Power Platform Monitor) that centralizes operational health metrics and recommendations for apps and automations across environments. That centralized Monitor has been rolling out as a preview in 2025 and is designed to serve two complementary audiences:
  • Makers: developers and app builders get per-resource, contextual insights in the maker portal (make.powerapps.com).
  • Admins and Center of Excellence teams: tenant-level dashboards, cross-environment metrics, and admin controls via the Power Platform admin center.
This split-surface design aims to let each role act on the same telemetry without switching tools—makers fix the code and UX; admins track tenant health and coordinate remediation.
What Monitor includes today​
Monitor is not a single monolith; it is a family of capabilities that together span tracing, metrics, recommendations, and (in preview) configurable alerts. Major elements documented by Microsoft include:
  • Live debugging for canvas apps: the classic Monitor session in Power Apps Studio that streams events and network traffic from an authored or published canvas app. This experience is available by default for canvas apps and is the maker-focused entry point for root-cause work.
  • Model-driven app monitoring: Monitor supports page-level troubleshooting for model-driven apps with the same session-based approach makers use for canvas apps.
  • Power Platform Monitor (admin center): a new admin-facing “Monitor” area in the Power Platform admin center that aggregates operational health metrics, surfacing resource cards and time-series charts, and includes recommendations calculated from runtime event logs and static analysis. The preview shows metrics such as App Open success rate, Time to interact, and Time to full load for canvas apps; Power Automate (cloud and desktop flows) metrics are being integrated on a rolling basis. (microsoft.com, learn.microsoft.com)
  • Power Automate coverage: cloud flows and desktop flows are available in the admin Monitor experience (preview), with Automation Center providing additional hierarchical run-history and Copilot insights for flows. (microsoft.com, learn.microsoft.com)
  • Contextual recommendations: Monitor doesn’t only report numbers; it surfaces actionable recommendations—examples include optimizing Power Fx formulas to improve app load times or identifying bottlenecks in flow execution. Recommendations are derived from aggregated runtime logs and static analysis. (learn.microsoft.com, microsoft.com)
  • Configurable alerts (preview): admins can create alert rules against Monitor metrics (e.g., threshold on app launches or degraded open success rate), select notification types (email), and scope alerts to managed environments. Alerts are evaluated against 24-hour aggregates and are currently a preview feature.
  • Logs, retention and scope: Monitor computes metrics by aggregating daily event logs. Event logs in the admin monitoring experiences are currently available for up to seven days, and metrics for up to 28 days. Recommendations require runtime activity and, in many cases, a Managed Environment to be available.
How Monitor is surfaced to different roles​
Makers (Power Apps maker portal)​
Makers access Monitor from make.powerapps.com. The in-studio Live monitor is visible under Advanced tools and streams a session of events for an app being authored or for a published app (Play published app). Makers can invite collaborators or connect an end user to a Monitor session to reproduce issues remotely. Monitor’s maker experience is intended to be no-friction—it’s integrated into the authoring workflow and provides immediate telemetry for debugging. (learn.microsoft.com, microsoft.com)
Administrators and CoE teams (Power Platform admin center)​
The Power Platform admin center hosts a tenant-level Monitor area. Admins can:
  • See product-level views and resource cards across environments
  • Drill into time-series metrics and recommendations
  • Create and manage alerts (preview)
  • Download or review related event logs for deeper investigation
Note: tenant-level analytics must be enabled to populate admin Monitor experiences; a Managed Environment is required to see certain recommendations. These prerequisites mean some admin features are not universally “on” by default across all tenants.
Verified technical specifics and limitations​
Several important technical details from Microsoft documentation shape how Monitor should be used and what to expect operationally:
  • Metrics are aggregated at daily intervals (24‑hour aggregates), and alerts evaluate against those aggregates. This introduces a natural cadence and potential latency; Monitor is not currently an instant stream-of-truth like a real-time trace system.
  • Event logs used to calculate metrics are available for up to seven days in the monitoring experiences; metrics themselves are available for up to 28 days. For long-term retention or correlation, Application Insights (or another external telemetry store) remains the authoritative option. Monitor does not replace Application Insights.
  • Maker access to analytics data is governed by tenant and environment settings. Tenant-level analytics must be enabled, and environment-level controls determine whether makers can see metrics and whether End User Pseudonymous Identifiers (EUPI) such as session IDs are available to makers. Administrators control these with dedicated PowerShell cmdlets. In other words, the visibility makers get into runtime data is configurable and privacy-conscious by design.
  • Some parts of the unified Monitor experience were introduced in stages: the original Power Apps Monitor reached general availability earlier (for maker debugging), while the Power Platform Monitor admin experience and cross-product automation observability were delivered as preview in 2025. This staggered rollout matters when interpreting statements such as “Monitor is enabled by default”—the reality is nuanced by role and the specific Monitor surface in question.
Why this matters: strengths and practical benefits​
Monitor’s design and scope deliver several real, operational advantages for organizations that depend on Power Platform solutions:
  • Unified visibility across makers and admins: having maker-level debugging in the same ecosystem as tenant-level health metrics reduces context switching and speeds triage. This helps troubleshooting move from “who owns this” to “here’s the root cause.”
  • Actionable recommendations, not just telemetry: Monitor pairs metrics with guidance—static analysis and runtime aggregation feed recommendations that tell makers and admins what actions are likely to improve a metric (for example, formula optimizations or flow redesign suggestions). That removes a lot of guesswork from tuning low-code apps. (learn.microsoft.com, microsoft.com)
  • Operationalization through alerts: the preview alerting framework lets admins define thresholds and receive notifications so teams can catch degraded health sooner. For production operations teams, this is a practical step toward SRE-style oversight for low-code assets.
  • No Azure subscription required: Monitor derives its insights from platform-collected runtime logs and does not require customers to provision Application Insights or other Azure monitoring services just to get the basic operational metrics. That lowers the barrier to adoption for organizations that want observability without extra infrastructure.
  • Tighter automation observability: Power Automate’s cloud and desktop flows are now visible at admin level (preview), and the Automation Center complements Monitor with hierarchical run history and Copilot-assisted troubleshooting—helpful for scaling automation operations. (microsoft.com, learn.microsoft.com)
Risks, caveats, and governance considerations​
While Monitor is compelling, prudent teams should weigh several operational and governance risks before flipping everything to “on”:
  • “Enabled by default” needs context: maker-facing live Monitor for canvas apps is available by default, but the admin Monitor experience relies on tenant-level analytics and managed-environment constructs to show recommendations. Claims of “no setup required” are accurate only for a subset of maker scenarios; admin-level insights often require configuration. Administrators must validate tenant settings before assuming full, tenant-wide visibility.
  • Data privacy and EUPI exposure: makers’ access to session IDs and user object IDs is controlled via environment settings. Organizations with strict privacy or compliance needs should audit these settings and decide whether makers should see pseudonymous identifiers. If maker access to EUPI is enabled, additional governance rules may be required to prevent misuse.
  • Alert noise and threshold design: Monitor’s current alert model evaluates 24‑hour aggregated metrics. Poorly planned thresholds can generate late or noisy alerts that reduce operator trust. Operations teams will need to design threshold tiers, response runbooks, and escalation paths—Monitor helps detect issues but won’t magically eliminate operational overhead.
  • Retention and forensic limits: with event logs available for seven days and metrics for 28 days, Monitor is excellent for near-term detection but insufficient for long-term forensic needs. Organizations should plan to forward telemetry to Application Insights or a SIEM for extended retention and cross-resource correlation when compliance or deep incident analysis is required.
  • Not a replacement for deep telemetry: Application Insights still provides more detailed traces, custom events, and longer retention—Monitor is additive, not a one-to-one replacement. Teams using Application Insights should use Monitor for operational baselining and quick remediation, but continue to rely on full instrumentation for deep diagnostics.
  • Feature maturity and preview status: several admin features—Alerts, Power Automate product views in Monitor, and some recommendations—were introduced as previews in 2025. Previews commonly change and might not be suited for production incident detection until they reach GA. Evaluate preview features conservatively. (microsoft.com, learn.microsoft.com)
Practical guide: getting started (quick, role-specific steps)​
  1. For makers who want to debug a canvas app:
    1. Sign in to Power Apps (make.powerapps.com).
    2. Open your app in Studio and choose Advanced tools → Open live monitor.
    3. Use “Play published app” or “Connect user” to reproduce and capture the session. (learn.microsoft.com, microsoft.com)
  2. For admins who want tenant-level visibility:
    1. Sign in to the Power Platform admin center.
    2. Ensure tenant-level analytics are turned on; confirm which environments are Managed Environments if recommendations are required.
    3. From the left nav, choose Monitor to view product overviews, resource cards, and time-series metrics; open Alerts to create threshold-based notifications.
  3. For SRE or operations teams:
    1. Design alert thresholds and runbooks before enabling wide-scale alerts. Monitor evaluates 24‑hour aggregates, so plan playbooks that consider alert cadence.
    2. Export or forward important telemetry (where possible) to Application Insights, Log Analytics, or your SIEM for long-term retention and correlation.
Adoption and governance checklist​
  • Confirm tenant-level analytics configuration and who can view EUPI in monitoring experiences.
  • Define which environments are Managed Environments (recommendations depend on this).
  • Establish alerting thresholds and an escalation matrix; start small and iterate to reduce noise.
  • Decide telemetry retention strategy—Monitor for near-term ops, Application Insights for long-term investigations.
  • Educate makers on the impact of publishing debug expressions (it can affect app performance) and control when debug info is published with an app.
Independent perspective from the community​
Early community and independent observers have welcomed the broader Monitor concepts while urging caution on governance and completeness. Community authors and newsletters noted the benefit of unified metrics and recommendations but highlighted the layered rollout—maker Monitor pieces were mature while admin-level Monitor was introduced as a preview in 2025, requiring admins to review tenants' analytics and Managed Environment settings before expecting full functionality. Community write-ups show practical maker workflows for model-driven app troubleshooting and stress the ongoing need for operational practices around telemetry retention and alert tuning. (carldesouza.com, ppweekly.com)
Final analysis: who should care and next steps​
Monitor meaningfully reduces the friction between discovery and remediation for low-code teams. For makers, Live monitor remains a fast, built-in way to trace app behavior and debug real user sessions. For administrators and CoE teams, the Power Platform Monitor promises a long-overdue operational control plane to manage health across applications and automations.
That said, organizations should treat admin-level Monitor as a complement to, not a replacement for, established telemetry and incident-response systems. Until all admin features exit preview, the realistic approach is to:
  • Use Monitor to reduce mean time to detection and guide first-line remediation.
  • Continue routing essential logs to Application Insights / SIEM for compliance and post-incident analysis.
  • Build governance guardrails around maker access to pseudonymous identifiers and around the distribution and handling of Monitor recommendations and alerts.
Monitor raises the bar for low-code observability—bringing observability and operational recommendations directly into the platforms where apps are built and run. With careful rollout, governance, and integration into existing incident processes, Monitor can shift Power Platform operations from reactive firefighting to systematic, measurable improvement.
(Notes on verification: this feature set and the administrative prerequisites described above are documented in Microsoft’s Power Apps and Power Platform articles and admin documentation, including maker Live monitor guidance, the Power Platform Monitor preview overview, and the alerts preview documentation. Some admin Monitor capabilities were delivered as a preview in 2025; where Microsoft’s pages list “preview” or require tenant or managed-environment settings, those constraints were reported in product documentation and therefore reflected here. For maker-facing Monitor functionality, the Live monitor experience has been generally available in Power Apps documentation for canvas and model-driven apps. (learn.microsoft.com, microsoft.com)
Source: Microsoft Effortless Visibility and Operational Insights for All with Monitor
