Windows 7 problem with winasm32.rom
Abanish
i got the problem with winasm32.rom error at the startup.....
it also says "the specifeid module cannot be found"...
somebody plz help me how to solve the problem
thank you in advance
Hi. Download and install Malwarebytes. Run it then update the definitions. Let it scan and remove everything it finds.
If you don't have any antivirus installed, install MSE.
