Problem with Windows 10 Symbols in windbg?
Josephur
Windows Forum Admin
So I'm an avid Windows Debugger user, I'm on build 1151 (Version 10.0.10586, or as winver.exe likes to say 10586.14)
I downloaded the Win 64 symbols from Microsoft, and set my _NT_SYMBOL_PATH environment variable to
the normal shtick "SRV*H:\Symbols*http://msdl.microsoft.com/download/symbols"
The symbols do exist in H:\Symbols, and the Microsoft server is there to catch any I don't have, this is how I've always done it.. but then any time I analyze a dump this is what I'm getting:
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: ffffffffffffffa4, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff801edcd17b6, address which referenced memory
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that   ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    Type referenced: nt!_KTHREAD                                   ***
SYMSRV:  H:\symbols\ntoskrnl.exe\564577807cc000\ntoskrnl.exe - file not found
*** ERROR: ERROR_INTERNET_HTTP_TO_HTTPS_ON_REDIR|default
SYMSRV:  A connection with the server could not be established
SYMSRV:  H:\symbols\ntoskrnl.exe\564577807cc000\ntoskrnl.exe not found
SYMSRV:  https://msdl.microsoft.com/download/symbols/ntoskrnl.exe/564577807cc000/ntoskrnl.exe not found
***    work.                                                          ***
***    work.                                                          ***
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_DATE:  11/16/2015
BASEBOARD_PRODUCT:  Z170 PRO GAMING
BASEBOARD_VERSION:  Rev X.0x
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
WRONG_SYMBOLS_TIMESTAMP: 56457780
WRONG_SYMBOLS_SIZE: 7cc000
FAULTING_MODULE: fffff801edc7f000 nt
DEBUG_FLR_IMAGE_TIMESTAMP:  56457780
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
BUGCHECK_P1: ffffffffffffffa4
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff801edcd17b6
READ_ADDRESS: unable to get nt!MiSessionIdBitmap
Unable to get value of nt!MiSessionWsList
ffffffffffffffa4
CURRENT_IRQL:  0
FAULTING_IP:
nt+527b6
fffff801`edcd17b6 410fb646a5      movzx   eax,byte ptr [r14-5Bh]
CPU_COUNT: 8
CPU_MHZ: fa8
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CUSTOMER_CRASH_COUNT:  1
ANALYSIS_VERSION: 10.0.10240.9 amd64fre
LAST_CONTROL_TRANSFER:  from fffff801eddcbfe9 to fffff801eddc1460
STACK_TEXT:
ffffd000`2357b238 fffff801`eddcbfe9 : 00000000`0000000a ffffffff`ffffffa4 00000000`00000002 00000000`00000000 : nt+0x142460
ffffd000`2357b240 00000000`0000000a : ffffffff`ffffffa4 00000000`00000002 00000000`00000000 fffff801`edcd17b6 : nt+0x14cfe9
ffffd000`2357b248 ffffffff`ffffffa4 : 00000000`00000002 00000000`00000000 fffff801`edcd17b6 00000000`00010000 : 0xa
ffffd000`2357b250 00000000`00000002 : 00000000`00000000 fffff801`edcd17b6 00000000`00010000 00000000`00000000 : 0xffffffff`ffffffa4
ffffd000`2357b258 00000000`00000000 : fffff801`edcd17b6 00000000`00010000 00000000`00000000 00000000`00000000 : 0x2
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt+527b6
FOLLOWUP_NAME:  MachineOwner
BUGCHECK_STR:  56457780
EXCEPTION_CODE: (NTSTATUS) 0x56457780 - <Unable to get error code text>
FAILURE_EXCEPTION_CODE:  56457780
EXCEPTION_STR:  WRONG_SYMBOLS
IMAGE_NAME:  ntoskrnl.wrong.symbols.exe
MODULE_NAME: nt_wrong_symbols
SYMBOL_NAME:  nt_wrong_symbols!564577807CC000
BUCKET_ID:  WRONG_SYMBOLS_X64_TIMESTAMP_151113-053912
DEFAULT_BUCKET_ID:  WRONG_SYMBOLS_X64_TIMESTAMP_151113-053912
PRIMARY_PROBLEM_CLASS:  WRONG_SYMBOLS
FAILURE_BUCKET_ID:  WRONG_SYMBOLS_X64_TIMESTAMP_151113-053912_56457780_nt_wrong_symbols!564577807CC000
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:wrong_symbols_x64_timestamp_151113-053912_56457780_nt_wrong_symbols!564577807cc000
FAILURE_ID_HASH:  {0c3a4f60-922a-c9ff-fd88-d6759fefaec3}
Followup:     MachineOwner
So of course the two errors that make no sense are that I'm using the wrong symbols, which I clearly am not.
The other is the ERROR_INTERNET_HTTP_TO_HTTPS_ON_REDIR error which basically means an http connection is being redirected to an https connection. This was not a problem before on Win 7/8, what the heck am I doing wrong? Anyone else having problems using a local store and the aforementioned Microsoft Symbol server?
Windows Forum Admin
Microsoft MVP
I used to have this issue but not anymore although I couldn't tell you why it's working ok from me. There is a work around for this issue and I'm just trying to find where I put the link.
There we go:
PDB Type Theft - Hewlett Packard Enterprise Community
Josephur
Windows Forum Admin
It appears I cannot connect to msdl.microsoft.com on port 80 or 443 at all, resolving that issue first, then I will tackle the next issue. I block a lot of MS telemetry data sites but msdl is not in my blocks, not sure why its not connecting at all.. and this is a fresh install, and I'm connecting to the same IP as a friend resolves it to, strange.... will post my findings.
Josephur
Windows Forum Admin
It appears that while testing Spybot's Anti-Beacon software to see how it blocks telemetry data, it added an entry 65.52.0.0/14 to my firewall, which is what is preventing these connections. Testing further....
