Windows 7 Problems getting eyefinity to work correctly
Lucasharmon97
I recently had re-install windows. The new installation was successful, but whenever I play a game that is full screen or use an application that is full screen, my Eyefinity gets disabled when I quit the application or Alt+Tab out of the application/game. Any way to fix this?
Experiencing issues with Eyefinity settings being disabled when exiting full-screen applications or games can be frustrating. To address this problem, you can try the following troubleshooting steps:
Adjusting Display Settings:​
  1. Reconfigure Eyefinity Settings:
    • Open AMD Radeon Settings or AMD Control Center.
    • Ensure that your Eyefinity settings are properly configured for your multi-monitor setup.
    []Reset Eyefinity:
    • Sometimes, resetting Eyefinity settings and setting them up again can resolve issues.
    ]Verify Display Driver:
    • Make sure you have the latest AMD graphics driver installed. Outdated drivers can sometimes cause conflicts with full-screen applications...
    []Reset Eyefinity:
      Managing Full-Screen Behavior:​
    []Game/Application Settings:
    • Check the settings within the specific game or application to see if there are any options related to display settings that might be overriding Eyefinity configurations.
    ]Windowed Full Screen:
    • Try running games in windowed full-screen mode instead, as this could prevent the Eyefinity settings from getting disabled when switching out of the game.
Additional Steps:​
  1. Monitor Cables:
    • Ensure that all the monitor cables are securely connected to the appropriate ports on your graphics card.
    []Restart Computer:
    • Rebooting the system sometimes resolves display-related issues.
    ]Driver Reinstallation:
    • If the issue persists, consider uninstalling the graphics driver completely and then reinstalling it.
    []Check for Updates:
    • Keep your Windows system updated with the latest patches and updates, as they can sometimes address compatibility issues.
    ]Contact AMD Support:
    • If none of the above steps work, reaching out to AMD support for specific guidance on Eyefinity settings might be beneficial.
      Conclusion:​
      By adjusting display settings, checking game/application configurations, and ensuring the proper connections, you can potentially resolve the issue of Eyefinity being disabled when exiting full-screen applications or games. Remember to keep your system and drivers up-to-date for optimal performance. If the issue persists after trying these steps, feel free to provide more details for further assistance.
