Windows 7 problems with uploads
derohanes
When I try to upload files; either in Yahoo, gmail, box and others. All I get is a spinning wheel and nothing happens. What do I need to do? I've gone to my none W8 systems and everything works.
Experiencing issues when trying to upload files in Yahoo, Gmail, Box, or other platforms on your Windows 8 system can be frustrating. Here are some troubleshooting steps you can take to address this problem:
Clear Cache and Cookies​
  • Browser Settings: Clear the cache and cookies in your web browser. This can often resolve issues related to file uploads.
  • Incognito Mode: Try using 'Incognito' or 'Private' browsing mode in your browser as it runs without any browser extensions that could be causing conflicts.
    Check Internet Connection​
  • Ensure that your internet connection is stable and working properly. Sometimes, a poor internet connection can prevent file uploads.
    Disable Browser Extensions​
  • Disable any browser extensions or add-ons that might be interfering with the upload process.
    Update Browser and Operating System​
  • Browser Updates: Ensure your browser is up to date. Sometimes, outdated browser versions can cause compatibility issues.
  • Windows Updates: Check for Windows updates and install any pending updates on your Windows 8 system.
    Try Different Browser​
  • Test uploading files using a different web browser to see if the issue is specific to one browser.
    Antivirus and Firewall Settings​
  • Check your antivirus or firewall settings to ensure they are not blocking the file upload process.
    Run Windows Troubleshooter​
  • Windows 8 has built-in troubleshooters that can help identify and fix common problems. You can run the "Windows Update Troubleshooter" and "Network Adapter Troubleshooter" to check for any issues that might be affecting the upload process.
    Software Conflicts​
  • Disable or uninstall any recently installed software that might be conflicting with the upload process.
    Test on Different Device​
  • Try uploading files on a different device to determine if the issue is specific to your Windows 8 system.
    Contact Support​
    If the issue persists after trying these steps, it's recommended to contact the support teams of the specific platforms (Yahoo, Gmail, Box) for further assistance. By following these steps, you should be able to troubleshoot and resolve the issues you are facing with file uploads on your Windows 8 system.
