winget help
Activated Win 11 Pro retail license inside a VM. Deleted vm along with all associated files without deactivating the license from that vm. Now product key is locked to that vm that no longer exists. How do I get my product key reinstated?
Hi — I can help. Short answer: because you used a retail key inside a VM then deleted that VM without deactivating, Microsoft’s activation servers still see that product key bound to the (now‑gone) VM hardware ID. The usual fix is to try the built‑in activation steps first and, if they fail, contact Microsoft Activation Support and ask them to reset the key so you can reactivate it on your current machine. Steps and exact things to try are below.
  • Quick checks (on the machine where you want to use the key)
  • Sign into Windows with the Microsoft account you used to buy/register Windows (Settings > Accounts > Your info). If the license was ever linked to that account you may be able to restore it.
  • Settings > System > Activation...
  • Settings > System > Activation — try “Change product key” and enter your retail key (if not already entered). If it errors, note the full error code/message (for example 0xC004C003 or 0xC004F074).
  • Run these commands from an elevated Command Prompt (right‑click Start → Windows Terminal (Admin) or Command Prompt (Admin):
  • slmgr /ipk <your-product-key> — installs the key (replace <> with the key).
  • slmgr /ato — attempts online activation.
  • slmgr /dlv — shows license details (license type will say Retail/OEM/Volume). Copy any useful output or error codes.
  • Use Activation Troubleshooter and phone activation
  • Settings > System > Activation > Troubleshoot. If you see “I changed hardware on this device recently,” follow that flow and sign into your Microsoft account to pick a device to reactivate (works if your digital entitlement is linked to your MS account).
  • If Troubleshooter can’t help, run slui 4 (in Start → Run) to launch phone activation. Choose your country and call the number shown (automated system or agent). The phone activation will ask for the Installation ID shown on screen — you give it and the system/agent gives you a Confirmation ID to enter back into the wizard.
  • If online/phone activation fails: contact Microsoft Activation Support
  • For retail keys Microsoft support can reset the activation so the key can be used again. Expect to speak with an activation agent and provide:
  • The product key.
  • A short explanation that the key was used inside a VM which was deleted without deactivating and you need the key un‑locked/reset.
  • Proof of purchase (order number, Microsoft Store receipt or retailer receipt) if available.
  • Your Microsoft account email if the license should be linked.
  • You can reach them via:
  • The “Get Help” app in Windows (type “Get Help”), or
  • Microsoft Support > Contact Us from another browser (or search “Microsoft activation support”), then choose Windows activation / phone support.
    (If you want, tell me your country and I’ll point you to the right contact/phone option.
  • What Microsoft will likely do
  • For a Retail key they will normally validate ownership and reset the activation so you can activate the key again on your new host/VM. For an OEM key (preinstalled on hardware) or volume/MAK/SVLK keys, different rules apply and it may not be transferrable.
  • What I need from you if you want more help
  • Where do you want to reactivate the key (your host PC, a new VM, a different PC)?
  • Do you have the original product key string and any proof of purchase?
  • What exact error message or error code do you see when you try to activate?
Important notes & warnings
  • Do NOT post your full product key publicly in the forum. Share it only with Microsoft support or privately if I need to see it to help debug.
  • If you have an OEM key it generally cannot be transferred between machines; retail keys are transferable.
  • If you want, I can draft the script/message you should use when you call Microsoft (what to say, what info to have ready).
If you tell me the activation error code you get now and whether the key is Retail vs OEM (you can check with slmgr /dlv on any machine currently using it), I’ll give the next exact steps and a short phone script you can use with Microsoft support.
