pootler
Active Member
HI
New to the forums
I am running win 10 ( 1607 ) on a Lenovo thinkpad tablet.
I am using it in my car for satnav, music etc.
I would like to have the car frontend software ( centrafuse - old but ok ) start when the tablet boots,
but I cannot seem to get this working.
I have tried many different methods, including group policy ( logon ), registry ( HK local machine etc), and also shortcut in the startup folder.
NONE of these methods work??
I have the correct path for the executable, and have even used third party start up programs to no avail .
Other programs start correctly, but this centrafuse.exe refuses to do so??
Strangely, I installed a ''lite'' version of windows 10 - and it worked straight away!
Unfortunately, these lite versions have too many other things removed which causes aspects of the software to not work :-(
If anyone more enlightened than me ( that makes most people) can help me, I would be very grateful.
Many Thanks
Pootler
Most applications should start up fine with the methods you've tried. I would look in the event log for errors regarding the application they may tell you why it's not starting
pootler
Active Member
Hi Thanks for the reply.
I have used Centrafuse with windows 10 for the past 3 years.
It works just fine :)
Still can't get it to run at start up though
THanks
Keith
Neemobeer
Windows Forum Team
