Windows 7 Random BSODs and freezes
Ted21
Hi everyone. I've been having problems with random BSODs/freezes/restarts for quite a while now. Today I made a clean install of windows 7 professional SP1 after breaking the RAID 0 of my hdds. I had another BSOD though while playing Lineage 2. I have attached the .rar with the report from the W7F diagnostics tool plus CPU-Z and RAMMon.
System specs:
M/B:Asus P5Q3
CPU:Intel Core2 Quad Q9550 @ 2.83GHz
RAM:2xCorsair 2gb 1333Mhz DDR3
GPU:ASUS EAH4870
PSU:XPOWER XPR-1000 ACTIVE PFC-ATX 12V 1000W
edit: I just did a bugcheck analysis on the minidump, so here goes:probably caused by : atikmdag.sys ( atikmdag+2c2949 )
Checked the said driver: atikmdag Kernel 18/8/2009 6:05:47 §£
I think it's out of date... Can someone post a link for a newer version?
  • W7F_28-05-2013.rar
usasma
Fantastic Member
Google says this is the chipset of your video card: Radeon HD 4870
Updated drivers are here: AMD Catalyst? Driver for AMD Radeon? HD 4000, HD 3000 and HD 2000 Series
Please note that these are Legacy drivers (it means that they won't be supported much longer - and they may have older components in them).
As such, please install the DRIVERS ONLY using this procedure: ATI video cards - DRIVER ONLY installation procedure - Sysnative Forums
Only 2 Windows Updates installed. Most systems have 160 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
You have the 2005 version of ASACPI.sys - which is known to cause BSOD's on some Windows systems. Please visit here: ASUS - P5Q3 , then select your OS (Win7 64 bit).
Then click on the Utilities section.
The first item is "ATK0110 driver for WindowsXP/Vista/Win7 32&64-bit" - download and install that to update this driver.
Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics (particularly the video tests): Hardware Diagnostics. Let us know the results and we can move on from there.
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon May 27 15:58:03.674 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052713-26301-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17514.amd64fre.win7sp1_rtm.101119-1850
System Uptime:[B]0 days 1:07:58.985[/B]
Probably caused by :[B]atikmdag.sys ( atikmdag+2c2949 )[/B]
BugCheck [B]3B, {c0000005, fffff88004b1e949, fffff880084bd9e0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88004b1e949, Address of the instruction which caused the bugcheck
Arg3: fffff880084bd9e0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  l2.exe
FAILURE_BUCKET_ID: [B]X64_0x3B_atikmdag+2c2949[/B]
CPUID:        "Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz"
MaxSpeed:     2830
CurrentSpeed: [B]2833[/B]
  BIOS Version                  1102
  BIOS Release Date             06/11/2010
[/font]
3rd Party Drivers:
[COLOR=RED][B]ASACPI.sys                  Sun Mar 27 22:30:36 2005 (42476C4C)[/B][/COLOR]
[COLOR=RED][B]Rt64win7.sys                Thu Feb 26 04:04:13 2009 (49A65B0D)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
atikmdag.sys                Mon Aug 17 23:05:47 2009 (4A8A1A8B)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
[/font]
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
Top Bottom
