- Thread Author
- #1
Well I've been getting random lockups for quite some time however here is the kicker,it ONLY happens with more than 4GB of RAM installed...anything less than 4GB I am perfectly fine but anything more my computer locks up totally randomly.
Random bits of information:
Latest DXDiag ran just now:
Any more information,the blood of my firstborn for example needed then just ask and I shall provide it.
EDIT:
Just read that and my BIOS date is way out of whack,anything important about this?
EDIT2:
Link Removed - Invalid URL
Also just ran this thing to solve another unrelated problem,it shows...a lot of info that could be useful
- Tested all of my RAM sticks individually and in any combination I can think of,as long as the total is nothing more than 4GB I'm fine and dandy but soon as I hit 6,8,10(Due to what sticks I have I can only go up in multiples of 2GB) I get random lockups.
- Lockups can happen on desktop when I'm afk and the computer is completely idle,after 2 hours of intensive gaming killing splicers in Bioshock 2 or just while I'm transcoding a movie on the fly(This actually seems to be relatively safe,does not happen often)
- On the lockup whatever sound that was playing repeats(The last 0.2 seconds of it or something) so it sounds like BZZZZTTTTTT no matter what
- New motherboard,new PSU and hard drives passed a chkdisk recently(Albeit with some grumbling from them about bad sectors)
- SFC scan completed,no problems to report with my file integrity.
- PSU has plenty of power for the system
- Just recently installed SP1(After the problem started) in an attempt to fix it,to no avail by the looks of the recent lockup and now I have no updates pending so windows is fully updated.
- Obviously checkSUR ran with no problems before installing SP1
- Booting into an Ubuntu liveCD and running random stressy things for the computer does not produce the same effects,it runs perfectly fine.
- Computer temp is high but within an acceptable range most of the time
- Once it crashes/locks up once it sometimes does the same on boot again and again till I just leave the thing alone for an hour or two and try booting it up again
- Event Viewer just shows this for each event when it locks up and I'm forced to reboot it manually:
[URL="http://windows7forums.com/"]-[/URL] <Event xmlns="[B]http://schemas.microsoft.com/win/2004/08/events/event">[/B]
[B] [URL="http://windows7forums.com/"]-[/URL] <System>
<Provider Name="[B]Microsoft-Windows-Kernel-Power[/B]" Guid="[B]{331C3B3A-2005-44C2-AC5E-77220C37D6B4}[/B]" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="[B]2012-07-18T09:15:17.128931900Z[/B]" />
<EventRecordID>5380184</EventRecordID>
<Correlation />
<Execution ProcessID="[B]4[/B]" ThreadID="[B]8[/B]" />
<Channel>System</Channel>
<Computer>ALEX-DESKTOP</Computer>
<Security UserID="[B]S-1-5-18[/B]" />
</System>
[URL="http://windows7forums.com/"]-[/URL] <EventData>
<Data Name="[B]BugcheckCode[/B]">0</Data>
<Data Name="[B]BugcheckParameter1[/B]">0x0</Data>
<Data Name="[B]BugcheckParameter2[/B]">0x0</Data>
<Data Name="[B]BugcheckParameter3[/B]">0x0</Data>
<Data Name="[B]BugcheckParameter4[/B]">0x0</Data>
<Data Name="[B]SleepInProgress[/B]">false</Data>
<Data Name="[B]PowerButtonTimestamp[/B]">0</Data>
</EventData>
</Event>
[/B]
System Information
Time of this report: 7/18/2012, 11:10:17
Machine name: ALEX-DESKTOP
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer:
System Model:
BIOS: BIOS Date: 08/11/11 09:12:01 Ver: 04.11
Processor: AMD Phenom(tm) II X4 955 Processor (4 CPUs), ~3.2GHz
Memory: 10240MB RAM
Available OS Memory: 10238MB RAM
Page File: 4742MB used, 15731MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Previously: Crashed in DirectSound (stage 3). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x9442)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9442&SUBSYS_22661787&REV_00
Display Memory: 1778 MB
Dedicated Memory: 1010 MB
Shared Memory: 767 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SyncMaster
Monitor Id: SAM05CD
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1077 (English)
Driver Version: 8.850.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/20/2011 02:07:48, 795648 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-D702-11CF-0270-6C02BEC2C535}
Vendor ID: 0x1002
Device ID: 0x9442
SubSys ID: 0x22661787
Revision ID: 0x0000
Driver Strong Name: oem27.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_RV7X:8.850.0.0:pci\ven_1002&dev_9442
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (VIA High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_0397&SUBSYS_1043836C&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: viahduaa.sys
Driver Version: 6.00.0001.8800 (English)
WHQL Logo'd: n/a
Date and Size: 10/1/2010 20:41:00, 1349232 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: HD Audio HDMI out (VIA High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: SPDIF Interface (TX1) (VIA High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: Speakers (Avnex Virtual Audio Device)
Hardware ID:
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: {0.0.0.00000000}.{906e62eb-da3f-4de9-a2a7-92cfb71d8f4e}
Driver Version: ()
WHQL Logo'd: n/a
Date and Size: , 0 bytes
Other Files:
Driver Provider: AVNEX Ltd.
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Microphone (VIA High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x0
Format Flags: 0x0
Description: Stereo Mix (VIA High Definition Audio)
Cap Flags: 0x0
Format Flags: 0x0
Description: Microphone (Avnex Virtual Audio Device)
Driver Name: {0.0.1.00000000}.{64d04f90-b8b9-4d1c-b351-c365079c06e7}
Driver Version: ()
Cap Flags: 0x0
Format Flags: 0x0
Description: Microphone (Screaming Bee Audio)
Driver Name: ScreamingBAudio64.sys
Driver Version: 2.00.0002.0000 (English)
Date and Size: 12/1/2009 15:49:52, 38992 bytes
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: G15 Gaming Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC226
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: G15 GamePanel LCD
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC227
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/25/2011 04:29:26, 343040 bytes
| Driver: usbd.sys, 3/25/2011 04:28:59, 7936 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/20/2010 11:33:25, 33280 bytes
| Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
| Service: kbdhid
| Vendor/Product ID: 0x046D, 0xC232
| Service: kbdhid
+ Razer Naga
| Vendor/Product ID: 0x1532, 0x0015
| Matching Device ID: hid\vid_1532&pid_0015&mi_01
| Upper Filters: RzSynapse
| Service: kbdhid
| Driver: RzSynapse.sys, 12/16/2010 10:23:14, 126464 bytes
| Driver: WdfCoInstaller01007.dll, 5/10/2010 14:40:50, 1490656 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC231
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
+ Razer Naga
| Matching Device ID: hid\vid_1532&pid_0015&mi_00
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 14:33:57, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 20.2 GB
Total Space: 1430.8 GB
File System: NTFS
Model: SAMSUNG HD154UI ATA Device
Drive: D:
Free Space: 11.7 GB
Total Space: 939.9 GB
File System: NTFS
Model: Hitachi HDT721010SLA360 ATA Device
Drive: F:
Free Space: 3.9 GB
Total Space: 4.0 GB
File System: NTFS
Drive: L:
Free Space: 0.4 GB
Total Space: 953.9 GB
File System: NTFS
Model: SAMSUNG HD103SJ ATA Device
Drive: E:
Model: Optiarc DVD RW AD-7280S ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 10:19:21, 147456 bytes
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_83891043&REV_00\3&267A616A&0&99
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:04, 25600 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:14, 325120 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:26, 343040 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_83891043&REV_00\3&267A616A&0&9A
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:04, 52736 bytes
Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_00\3&267A616A&0&A4
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 14:33:48, 184704 bytes
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_83891043&REV_00\3&267A616A&0&91
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_83891043&REV_00\3&267A616A&0&92
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_84321043&REV_06\4&1708FA51&0&0050
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_83891043&REV_00\3&267A616A&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301787&REV_00\4&2A1FC852&0&0110
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 11:43:43, 122368 bytes
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_836C1043&REV_00\3&267A616A&0&A2
Name: ASMedia XHCI Controller
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&AB0F605&0&0038
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1022&DEV_9609&SUBSYS_83881043&REV_00\3&267A616A&0&50
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_83891043&REV_00\3&267A616A&0&A1
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 02:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 02:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 02:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 14:32:46, 155520 bytes
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_83891043&REV_00\3&267A616A&0&98
Device ID: PCI\VEN_1022&DEV_9607&SUBSYS_83881043&REV_00\3&267A616A&0&38
Name: ATI Radeon HD 4800 Series
Device ID: PCI\VEN_1002&DEV_9442&SUBSYS_22661787&REV_00\4&2A1FC852&0&0010
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1152 (English), 4/20/2011 02:44:50, 9319936 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0020 (English), 4/20/2011 01:20:52, 53248 bytes
Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6210 (English), 4/20/2011 01:22:34, 306176 bytes
Driver: C:\Windows\system32\atiumd64.dll, 7.14.0010.0833 (English), 4/20/2011 01:31:14, 5440000 bytes
Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0308 (English), 4/20/2011 01:40:04, 3868672 bytes
Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0023 (English), 4/20/2011 02:03:06, 120320 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 2/28/2011 21:30:06, 233012 bytes
Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 4/20/2011 01:13:38, 53760 bytes
Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 4/20/2011 01:13:38, 53760 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1057 (English), 4/20/2011 01:23:14, 366080 bytes
Driver: C:\Windows\system32\atiumd6a.cap, 4/20/2011 01:36:12, 989600 bytes
Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 4/20/2011 02:02:26, 16384 bytes
Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 4/20/2011 02:09:20, 151552 bytes
Driver: C:\Windows\system32\atiapfxx.blb, 4/20/2011 02:09:46, 165296 bytes
Driver: C:\Windows\system32\atiumd6v.dll, 7.14.0010.0184 (English), 4/20/2011 01:40:50, 1222656 bytes
Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1092 (English), 4/20/2011 02:04:20, 203776 bytes
Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1092 (English), 4/20/2011 02:04:56, 480256 bytes
Driver: C:\Windows\system32\atipdl64.dll, 6.14.0010.2563 (English), 4/20/2011 02:02:50, 423424 bytes
Driver: C:\Windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 4/20/2011 02:02:22, 59392 bytes
Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.4126.37954 (English), 4/20/2011 02:05:08, 462848 bytes
Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.10750 (English), 4/20/2011 02:30:18, 22900736 bytes
Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.1385 (English), 4/20/2011 01:45:54, 7768064 bytes
Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.1385 (English), 4/20/2011 01:46:18, 51200 bytes
Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.1385 (English), 4/20/2011 01:46:06, 44544 bytes
Driver: C:\Windows\system32\atipblag.dat, 3/17/2011 17:51:46, 3929 bytes
Driver: C:\Windows\system32\atiu9p64.dll, 8.14.0001.6210 (English), 4/20/2011 01:21:34, 38912 bytes
Driver: C:\Windows\system32\atiuxp64.dll, 8.14.0001.6210 (English), 4/20/2011 01:21:46, 40960 bytes
Driver: C:\Windows\system32\atig6pxx.dll, 8.14.0001.6210 (English), 4/20/2011 01:22:56, 14848 bytes
Driver: C:\Windows\system32\atig6txx.dll, 8.14.0001.6210 (English), 4/20/2011 01:22:50, 39936 bytes
Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 22:35:28, 118784 bytes
Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0355 (English), 4/20/2011 01:49:32, 4951552 bytes
Driver: C:\Windows\SysWOW64\atiumdag.dll, 7.14.0010.0833 (English), 4/20/2011 01:38:06, 4286464 bytes
Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0308 (English), 4/20/2011 01:30:38, 4056576 bytes
Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 4/20/2011 01:13:30, 52736 bytes
Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 4/20/2011 01:13:30, 52736 bytes
Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1057 (English), 4/20/2011 01:23:08, 262144 bytes
Driver: C:\Windows\SysWOW64\atiumdva.cap, 4/20/2011 01:29:36, 989600 bytes
Driver: C:\Windows\SysWOW64\atiumdmv.dll, 7.14.0010.0184 (English), 4/20/2011 01:40:16, 1923584 bytes
Driver: C:\Windows\SysWOW64\atipdlxx.dll, 6.14.0010.2563 (English), 4/20/2011 02:02:44, 356352 bytes
Driver: C:\Windows\SysWOW64\Oemdspif.dll, 6.15.0006.0006 (English), 4/20/2011 02:02:32, 278528 bytes
Driver: C:\Windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 4/20/2011 02:02:18, 43520 bytes
Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.10750 (English), 4/20/2011 02:07:04, 17693184 bytes
Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0355 (English), 4/20/2011 01:59:22, 4161536 bytes
Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.1385 (English), 4/20/2011 01:42:06, 6389760 bytes
Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.1385 (English), 4/20/2011 01:46:16, 46080 bytes
Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.1385 (English), 4/20/2011 01:46:04, 44032 bytes
Driver: C:\Windows\SysWOW64\atipblag.dat, 3/17/2011 17:51:46, 3929 bytes
Driver: C:\Windows\SysWOW64\atiu9pag.dll, 8.14.0001.6210 (English), 4/20/2011 01:21:26, 29184 bytes
Driver: C:\Windows\SysWOW64\atiuxpag.dll, 8.14.0001.6210 (English), 4/20/2011 01:21:40, 31232 bytes
Driver: C:\Windows\SysWOW64\atigktxx.dll, 8.14.0001.6210 (English), 4/20/2011 01:22:42, 32768 bytes
Driver: C:\Windows\SysWOW64\atiglpxx.dll, 8.14.0001.6210 (English), 4/20/2011 01:22:54, 12800 bytes
Driver: C:\Windows\atiogl.xml, 4/5/2011 23:46:16, 32200 bytes
Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 16:34:36, 51200 bytes
Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 19:33:08, 332800 bytes
Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6210 (English), 4/20/2011 01:22:54, 12800 bytes
Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1077 (English), 4/20/2011 02:07:48, 795648 bytes
Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1077 (English), 4/20/2011 02:09:06, 676864 bytes
Driver: C:\Windows\system32\coinst.dll, 1.00.0003.0005 (English), 4/20/2011 01:27:00, 58880 bytes
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_83891043&REV_00\3&267A616A&0&90
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_83891043&REV_00\3&267A616A&0&88
Device ID: PCI\VEN_1022&DEV_9603&SUBSYS_83881043&REV_00\3&267A616A&0&10
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_83891043&REV_00\3&267A616A&0&A5
Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_83891043&REV_3C\3&267A616A&0&A0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_9600&SUBSYS_83881043&REV_00\3&267A616A&0&00
Driver: n/a
Name: Atheros AR5007G Wireless Network Adapter #2
Device ID: PCI\VEN_168C&DEV_001D&SUBSYS_2055168C&REV_01\4&2966AB86&0&30A4
Driver: C:\Windows\system32\DRIVERS\athrx.sys, 8.00.0000.0238 (English), 10/5/2009 17:34:00, 1542656 bytes
Driver: C:\Windows\system32\drivers\vwifibus.sys, 6.01.7600.16385 (English), 7/14/2009 01:07:21, 24576 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
Zune AAC Decoder DMO,0x005fffff,1,1,ZuneAACDec.dll,11.05.7600.6740
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Microsoft Zune Mpeg4s Decoder DMO,0x00800001,1,1,ZUNEMP4SDECD.dll,12.08.2345.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
Xiph.Org Theora Decoder,0x00600000,1,1,dsfTheoraDecoder.dll,
Xiph.Org Vorbis Decoder,0x00600000,1,1,dsfVorbisDecoder.dll,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
LogMeIn Video Encoder,0x00200000,1,1,racodec.ax,4.01.0000.2504
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Audio Source,0x00200000,0,1,wmprevu.dll,10.00.0000.3809
Zune Enhanced Video Renderer,0x00200000,1,0,ZuneEvr.dll,4.08.2345.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Xiph.Org Ogg Muxer,0x00200000,1,0,dsfOggMux.dll,
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
Xiph.Org FLAC Decoder,0x00600000,1,1,dsfFLACDecoder.dll,
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,11.06.0000.51125
ATI MPEG Video Decoder,0x005fffff,1,2,atimpenc64.dll,11.06.0000.51125
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
LogMeIn Video Decoder,0x00800000,1,1,racodec.ax,4.01.0000.2504
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
Screen Capture filter,0x00200000,0,1,ZuneSrcWrp.dll,4.08.2345.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Disk Record Queue,0x00200000,1,1,wmedque.dll,10.00.0000.3809
Xiph.Org Theora Encoder,0x00200000,1,1,dsfTheoraEncoder.dll,
Xiph.Org Vorbis Encoder,0x00200000,1,1,dsfVorbisEncoder.dll,
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Color Converter,0x00200000,1,1,declrds.ax,10.00.0000.3809
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,11.06.0000.51125
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Xiph.Org Native FLAC Decoder,0x00600000,0,1,dsfNativeFLACSource.dll,
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Xiph.Org Speex Encoder,0x00200000,1,1,dsfSpeexEncoder.dll,
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc64.dll,11.06.0000.51125
Xiph.Org Speex Decoder,0x00600000,1,1,dsfSpeexDecoder.dll,
Xiph.Org FLAC Encoder,0x00200000,1,1,dsfFLACEncoder.dll,
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,11.06.0000.51125
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
ATI Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,11.06.0000.51125
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,10.00.0000.3809
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
Xiph.Org Ogg Demuxer,0x00600000,1,1,dsfOggDemux2.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Video Source,0x00200000,0,1,wmprevu.dll,10.00.0000.3809
ATI Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,11.06.0000.51125
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Microsoft Zune H.264 Video Decoder,0x005fffff,1,1,ZuneH264Dec.dll,11.05.7600.6740
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
WebM Muxer Filter,0x00200000,2,1,webmmux.dll,0.09.0012.0000
WebM VP8 Decoder Filter,0x00600000,1,1,vp8decoder.dll,0.09.0012.0000
WebM VP8 Encoder Filter,0x00200000,1,1,vp8encoder.dll,0.09.0012.0000
WebM Splitter Filter,0x00600000,1,1,webmsplit.dll,0.09.0012.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (VIA High Definition,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (Avnex Virtual Audio,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (Screaming Bee Audio,0x00200000,0,0,qcap.dll,6.06.7601.17514
Stereo Mix (VIA High Definition,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
VIA HD Audio Input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Screaming Bee Wave,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Avnex Virtual Audio Device,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HD Audio digital out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio HDMI out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
VIA HD Audio Output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (VIA High Definition A,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: HD Audio HDMI out (VIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: SPDIF Interface (TX1) (VIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Avnex Virtual Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (VIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
HD Audio HDMI out (VIA High Def,0x00200000,1,0,quartz.dll,6.06.7601.17713
SPDIF Interface (TX1) (VIA High,0x00200000,1,0,quartz.dll,6.06.7601.17713
Speakers (Avnex Virtual Audio D,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
EDIT:
EDIT2:
