This is a carry on from this thread as I was told I should come here.
To put it simply, I started having regular BSODs since I installed my GTX 780, I was pretty confident that it was just a driver issue, and decided I would be sending it back as I didn't want the hassle (tried lots of things).
Today I got a BSOD with my hd 6790's, which is making me think maybe it wasn't a problem with my 780. All my BSODs relate to ntoskrnl.exe.
Attached the necessary files.
note: only the 010614-5734-01 dump file related to my current gpus. The other dump is from when I had my 780. If you goto the other thread I linked at the top there are other dump files available.
Please tell me if I need to add or edit something, thanks 🙂
Quick note:
I have a few hours (tops) to contact the seller of the 780 and cancel the return, if this problem isn't infact related to the nvidia card afterall, I would rather keep it.
Quick note:
