Removing "Write Protected" From USB Drives
Here are a few sites that may help in removing the "Write Protected" error received when trying to write, format or copy data from USB, Pen Drives or Memory Cards.
Solution to remove Write Protection from USB Pen Drive - Tech Salsa
Remove Write Protection On USB Pen Drive or Memory Card or iPod
TestDisk - CGSecurity
Apacer | Service/Support | Downloads
Remove Write Protection On USB Flash Drive
Or you can try this file: Run it and it will format your USB even if it is write protected. In most cases this does the job;
View attachment WriteProtectedRepair_v2.9.1.1.zip
