Windows 10 How to identify which process accesses the optical drive?
xio
Well-Known Member
After inserting a Blu-ray data disc (BD-R), an unknown background process accesses the disc even when I am doing nothing. It even happens when deactivating the real-time protection feature of Windows Defender.
Existing tools such as the task manager and the third-party tool "Process Hacker" are unable to display I/O transfer rate on optical discs.
How can a process constantly accessing the optical drive be identified?
More detailed observations:
On two Windows 10 computers I have tested, after inserting a recordable Blu-ray disc with UDF 2.60 live file system and a few thousand files, the disc can be browsed inside Windows Explorer about a quarter minute after inserting the disc, as normal. However, the moment the disc is opened in Windows Explorer (File Explorer), something in the background starts reading data from the disc and keeps reading for several minutes. The drive keeps spinning during that time and its I/O indicator LED keeps blinking. After that time, it stops reading from the disc in the background and data can be read and written again without interference. The duration of this mysterious background process appears to correlate with the number of files on the disc, taking longer on discs with a higher number of files.
This makes it hardly possible to read data from the disc or write data to it, since this mysterious process interferes. It also causes Windows Explorer to stop responding, showing "(not responding)" in the title and the white mist that fades in and covers the window. When trying to read or write data, the drive's laser lens has has to alternate between both the location the user is trying to read from or write to and the location this mysterious parasitic process is reading, which makes both extremely slow; under 100 KB/s. In other words, both processes "fight" for the laser lens like wild boars. It's detrimental to both participants, creating a lose-lose situation.
The task manager does not show which process it is, since it can not show the I/O usage on optical media.
I have temporarily deactivated Windows Defender's "real-time protection", which I thought might cause this, yet it still happens. I tried taskkilling explorer.exe to see if it stops, but it didn't.
Does anyone have an idea what the source of this problem might be? Could it be some equivalent to Android's media scanner? In the early 2010s, bugs in the media scanner sometimes caused significant battery drain on Android devices. Does Windows have such a thing as well? And most importantly, how can it be prevented?
The closest guess would be that it loads the file tree in memory for search indexing, but that still does not explain why it takes several minutes for a few thousand files, which is similarly as slow as the directory listing of Media Transfer Protocol (MTP), except it also does so unsolicitedly.
To identify and address the unknown background process accessing the optical drive when a Blu-ray data disc is inserted, you can follow these steps:
Identifying the Unknown Process​
  • Resource Monitor:
  • Use the built-in Resource Monitor in Windows to monitor disk activity and identify the process causing the high I/O on the optical drive.
  • Launch Resource Monitor by searching for it in the Start menu or Task Manager, go to the Disk tab, and look for the process with high disk activity.
  • Process Explorer:
  • Download and run Process Explorer from Microsoft Sysinternals.
  • In Process Explorer, go to Options > Difference highlight duration and set it to "infinite" to maintain changes...
  • Resource Monitor:
  • Process Explorer:
  • Monitor the process tree in real-time to identify any newly spawned processes when the disk activity spikes.
  • Windows Task Manager:
  • While Task Manager may not directly show I/O usage on optical media, it can still provide insights.
  • Review the Task Manager's Processes and Details tabs for any unfamiliar or consuming processes.
    Resolving the Issue​
  • Task Scheduler:
  • Check Task Scheduler for any scheduled tasks that might coincide with the Blu-ray disc insertion. Disable or modify any tasks related to disk scanning/indexing.
  • Windows Indexing Options:
  • Adjust Windows Indexing Options to exclude the optical drive or the specific data location causing the slowdown.
  • Third-Party Apps:
  • Review any third-party applications like antivirus, disk utilities, or media players that might access the optical drive. Temporarily disable these to check for improvement.
  • Event Viewer:
  • Use Event Viewer to pinpoint any error or warning messages that might indicate the problematic process.
    Prevention Strategies​
  • Adjust Search Indexing Settings to exclude optical drives or specific disk locations.
  • Check Startup Programs, disable unnecessary ones in Task Manager.
  • Investigate and remove any Malware or unwanted applications. By following these steps to identify the mysterious background process accessing the disc and taking appropriate preventive measures, you can mitigate the interference and improve the performance of reading/writing data from the Blu-ray disc.
