- Thread Author
- #1
Hello everyone,
I have joined here to ask about Window 7's new taskbar, to be more specific the right click (alt click).
In all the past windows versions I have used (Including Vista) I used to be able to right click and press close, all within very little to no mouse movement, in 7 it's miles out of the way and is extremely annoying.
I noticed if I hold shift and then right click it gives the old menu which I prefer, is there any way to set this as default without holding shift?
It's enough to make me want to go back to Vista to be honest (sorry!) but I hope it can be fixed easily, I just can't see an option anywhere!
Thanks,
Laurence
Thanks,
Laurence
