Windows 10 Screen issue when running IE
GPC2012
All of a sudden when I use IE my screen will start to shrink down to about the size of a cell phone screen and then bounce up and down in size. I haven't changed anything on the computer, downloaded any programs or apps. it is a Dell it is an a4 6210 with 4 g of ram
My bad that reply was meant for another thread, so sorry!
Was that an upgrade to Windows 10? If yes by all means do what I said just download and install Windows 10 chipset driver and Video driver as well.
You need to go to www.dell.com. support and drivers and download all the drivers for Windows 7 starting with the chipset driver.
That is one of the issues using the recovery from Windows 10.
I'm running widows 10 and don't plan on changing it. So not sure that would help
