Shader Model 6.9 and DXR 1.2: Real-Time Ray Tracing and In Shader AI
Microsoft has pushed the next practical evolution of Direct3D and HLSL with the public rollout plan for Shader Model 6.9 and a bundle of targeted Direct3D 12 improvements aimed at making real‑time ray tracing, complex transparency, and shader‑heavy AI/ML workloads both faster and easier to ship — a collection of features Microsoft expects to push into retail availability in Q1 2026.
Blue holographic diagrams float above a GPU chip, illustrating shader tech and DXR.Background / Overview​
DirectX and Direct3D have evolved from a graphics‑only API into a cross‑stack graphics and compute platform that increasingly blurs the line between rendering and on‑GPU AI/ML. The announcements surfaced through Microsoft’s DirectX developer channels and their GDC State of the Union updates, and they bundle several closely related feature sets: improvements to ray‑tracing primitives, new shader execution controls, expanded vector and tensor primitives, and supporting compiler/toolchain updates. Together these changes are intended to reduce GPU workloads, improve coherency of shading work, and unlock higher‑efficiency ML-style computations inside shaders.
This is not a one‑off spec bump. Rather, Microsoft is aligning three vectors at once: (1) DXR 1.2 / ray‑tracing primitives (notably Opacity Micromaps and Shader Execution Reordering), (2) shader model extensions in SM 6.9 (Native/Long vectors, 16‑bit float special support), and (3) broader compute/AI capabilities under the cooperative‑vector/ML story. The rollout timeline places most SM 6.9 features in Q1 2026 while identifying a path for larger cooperative vector work to follow.
What’s new in Shader Model 6.9 — the feature list​
Microsoft’s developer blog and GDC materials highlight a compact set of headline features for SM 6.9. Each item is targeted at a real problem developers face today: shader divergence in ray tracing, expensive alpha/opacity handling, and expensive small‑matrix math for ML workloads. The core items are:
  • Opacity Micromaps (OMM) — compact, GPU‑friendly micromap representations for opacity/alpha geometry that reduce expensive shading work on fully transparent texels.
  • Shader Execution Reordering (SER) — runtime/driver guidance that allows the GPU/driver to reorder shader work to improve coherency, reduce thread divergence, and increase execution efficiency for workloads like ray tracing.
  • Native and Long Vectors — native vector types and long vector support inside HLSL to better express wide data paths and reduce scalarization overhead in shader code.
  • 16‑bit float special support — explicit, hardware‑aware support for half‑precision math with nuanced semantics useful in ML/graphics blends.
  • Cooperative Vector roadmap — Microsoft is evolving “Cooperative Vector” ideas toward expanded matrix‑matrix facilities for shader‑side ML. The unified matrix work is planned for a later Shader Model release, with Cooperative Vector remaining experimental while the team consolidates design feedback.
These items are not abstract: they map directly to concrete developer pain points. OMM reduces wasted ray‑tracing shading on fully transparent pixels, SER makes divergent tracing workloads run far more efficiently on modern GPU schedulers, and the vector/half‑precision items make shader‑side ML and tensor work less kludgy.
Opacity Micromaps (OMM): what they solve — and why they matter​
Opacity Micromaps allow fine‑grained, GPU‑resident representations of per‑primitive opacity (for example, foliage textures, chain‑link fences, decals) so ray traversal and shading can skip work on totally transparent microtexels. That saves both memory bandwidth and shader invocations — the two things that dominate ray‑tracing cost in complex scenes.
  • Benefits:
  • Dramatic reduction in wasted shading for thin or alpha‑masked geometry.
  • Smaller GPU memory use than naïve per‑texel alpha representations at ray‑tracing time.
  • Direct win for scenes with lots of foliage, cards, and layered alpha content.
Microsoft and industry previews show material performance improvements for ray tracing when OMM and related DXR 1.2 features are enabled; developers targeting heavy DXR scenes should treat OMM as a first‑order optimization.
Shader Execution Reordering (SER): reducing divergence and improving throughput​
SER offers a way for drivers and runtime to reorder shading tasks to increase instruction and memory coherency. In practice, that means grouping similar ray hits or similar shading work together so the GPU executes more like a vector machine and less like many tiny scalar programs.
  • Why it helps:
  • Reduces thread divergence and execution stalls.
  • Improves cache locality and instruction reuse.
  • Makes complicated shading workloads (physically based materials, layered materials, neural shading) more predictable in performance.
For modern GPUs that manage many parallel warps/wavefronts, even moderate improvements to coherence can yield meaningful FPS and power gains in ray‑traced scenes. SER is part of the DXR 1.2 story and pairs naturally with OMM.
Native/Long vectors and 16‑bit float support: building blocks for shader ML​
SM 6.9 introduces more robust vector types and explicit half‑precision semantics. These are small API changes that compound into big developer productivity and performance wins for shader code that wants to act like a tiny ML kernel.
  • Native vectors reduce manual packing/unpacking and help compilers produce wider, more efficient code.
  • Long vectors and 16‑bit float special support make it trivial to express small matrix/tensor operations with correct precision/perf tradeoffs.
Microsoft is also evolving the broader Cooperative Vector design toward true matrix‑matrix operations — the kind of thing ML inference and neural texture/color transforms want — but that larger work is being staged for a subsequent Shader Model update. For now, SM 6.9’s vector and half‑float provisions are a pragmatic step that benefits both graphics and on‑shader compute.
Direct3D 12 improvements beyond SM 6.9: DXR 1.2 and the GDC roadmap​
GDC and Microsoft’s DirectX updates were explicit that Shader Model changes come paired with Direct3D/DXR upgrades. DXR 1.2 brings the aforementioned OMM and SER into the ray‑tracing primitive domain, and Microsoft framed these changes as making real‑time ray tracing “practical and accessible” for a wider range of games and scenes. DXR 1.2 also touches driver/ABI delivery through the DirectX Agility mechanisms, enabling preview binaries and earlier experimentation.
This is more than incremental: the DXR primitives directly lower the shading cost in scenes where ray‑traced effects are otherwise expensive, and when paired with SM 6.9 shader features they create a feedback loop that reduces total GPU time spent per pixel.
Tooling and compiler support — the production story​
A spec without compiler and tooling support is academic. Microsoft’s DirectX Shader Compiler (DXC) and associated tooling are being updated to enable SM 6.9 codegen and to smooth interoperability with other graphics ecosystems like Vulkan via SPIR‑V. Recent compiler releases explicitly call out production support for SM 6.9 and include SPIR‑V backend improvements to make HLSL/DXIL → Vulkan workflows more correct and usable. That reduces friction for engine teams doing cross‑API builds and for driver vendors validating new shader features.
Practical implications for developers:
  • Use the latest DXC builds to compile SM 6.9 code.
  • Expect incremental SDK updates (DirectX Agility SDK) and driver updates from vendors for preview and retail support.
  • Test shader fallbacks: where SM 6.9 features aren’t available, provide balanced fallbacks to earlier SM versions or alternate shader paths.
Hardware and driver expectations: who will support SM 6.9 and DXR 1.2?​
Microsoft’s announcements are platform‑agnostic in goal, but hardware vendor commitments are the gating factor for broad adoption. Early signals from industry reporting indicate major vendors (NVIDIA, AMD, Intel) are planning or already implementing support for DXR 1.2 primitives and SM 6.9‑adjacent features in drivers and hardware microcode. However, the exact timing of complete support will vary by GPU family and driver cadence. Developers must plan for staggered rollout and driver QA cycles.
A sensible checklist for studios and engine teams:
  • Confirm driver releases that advertise SM 6.9 / DXR 1.2 support for target platforms.
  • Run regression suites across vendor drivers; early driver support can carry edge bugs that are corrected in later updates.
  • Consider feature toggles: enable OMM and SER only when the runtime/driver reports stable support.
How big is the expected performance win?​
There is no single number that fits every scene, but the design goals are specific: reduce unnecessary shader invocations and increase execution coherence. Early reporting and Microsoft demos suggest:
  • OMM & SER together can meaningfully reduce ray‑tracing shading cost in foliage/alpha heavy scenes — in some previews that showed multi‑times speedups on the shading stage alone.
  • Cooperative vector work (when it arrives) aims to accelerate shader‑resident ML kernels — the Delta here is workload specific and depends on vector widths and matrix sizes.
Caveats:
  • Gains are scene and material dependent. OMM helps when alpha coverage is high; gains approach zero for opaque geometry.
  • Driver maturity will affect realized results; early adopters should expect tuning and bug fixes over multiple driver revisions.
Risks, tradeoffs, and unanswered questions​
No major platform push is without risk. Teams should weigh the following realistically.
  • Driver and hardware fragmentation — GPU families enable features at different times; conditional code paths and robust fallbacks will be necessary. Early adopters will shoulder testing and bug triage.
  • Complexity in pipelines — OMMs and SER add new artifacts to asset and runtime pipelines (micromap generation, precompilation steps, and reordering effects). Build pipelines must add validation and deterministic debug paths.
  • Toolchain maturity — while DXC updates target SM 6.9, other toolchain pieces (profilers, debuggers, third‑party compilers) will need updates. Expect incremental improvements; pin specific tool versions for reproducible builds.
  • Security & correctness — any new shader primitive or reordering mechanism must be validated for correctness; SER changes execution ordering semantics in ways that require careful testing against undefined behavior or shader assumptions.
  • Unverified timelines — Microsoft’s stated plan targets Q1 2026 for retail release of many SM 6.9 features, but vendor support and production adoption may lag or arrive in waves. Treat Q1 2026 as a shipping target for the platform, not a guarantee for all GPUs and drivers.
Practical guidance for developers and studios — a migration playbook​
If your team ships a DX12 title or is building a next‑gen renderer, here are practical steps to prepare and adopt SM 6.9/DXR 1.2 safely.
  • Update your toolchain:
  • Install the latest DXC/DXIL toolchain releases that reference SM 6.9 support.
  • Pin toolchain versions in CI to ensure reproducibility.
  • Build robust feature detection:
  • Query the runtime/driver for DXR 1.2 and SM 6.9 capabilities at startup.
  • Gate OMM and SER usage behind capability checks and provide deterministic fallbacks.
  • Integrate micromap generation in your content pipeline:
  • Authoring tools must have steps to generate, compress, and validate micromaps for target LODs.
  • Validate visual parity between micromap and fallback paths to avoid sudden visual shifts.
  • Profile early and often:
  • Use hardware/perf counters to validate coherence improvements from SER.
  • Measure shader invocation counts pre/post OMM integration to quantify wins.
  • Staged QA on vendor drivers:
  • Test on multiple vendor driver versions and GPU families.
  • Keep a matrix of driver versions you officially support and document known issues and workarounds.
  • Educate artists and technical artists:
  • Document when to use alpha‑masked cards vs. geometry, and when micromaps should be generated or avoided.
Applying these steps will reduce release risk and make the most of the new Direct3D primitives.
Engines and middleware: who needs to change?​
Major engines (both in‑house and third‑party) are the natural place to absorb SM 6.9/DXR 1.2 complexity. Engine teams should:
  • Add OMM generation and ingestion at asset import/export layers.
  • Expose SER controls and instrumentation for engine teams and developers to toggle and profile behavior.
  • Provide shader authoring templates and example kernels that demonstrate best practices for vectorized/half‑precision math and fallbacks.
We expect the big engines to add formal support quickly; independent studios and middleware vendors will need to decide whether to adopt engine patches or implement custom integrations. Microsoft’s tooling updates and the DirectX Agility SDK will make the process easier, but it still requires developer time and testing.
The AI/ML angle: shader‑side neural inference and “cooperative vectors”​
A major subtext of Microsoft’s roadmap is enabling more ML-style workloads inside shaders — from neural denoisers to neural texture transforms and small‑model inference. The Cooperative Vector program and the longer roadmap toward matrix‑matrix primitives in HLSL suggest Microsoft wants to make these workflows efficient without moving data off the GPU into separate compute pipelines.
  • Immediate benefits:
  • Faster, shader‑resident neural denoisers and post‑processors without expensive CPU ↔ GPU synchronization.
  • Compact neural texture encodings and on‑the‑fly decompression or enhancement.
  • Longer‑term vision:
  • Larger matrix primitives and “tensor” friendly features in shaders so that LLM‑style compute or larger inference tasks are feasible on game GPUs.
Microsoft has said Cooperative Vector’s expanded matrix features are being planned for a later Shader Model release while maintaining the experimental Cooperative Vector API in the meantime. That staged approach lets developers experiment while giving Microsoft time to consolidate a robust, unified design.
Industry context and third‑party reporting​
Independent reports and industry coverage place Microsoft’s moves in a broader industry momentum: vendors are actively shipping driver updates that support the new DXR primitives and compiler updates are shipping with improved SPIR‑V and Vulkan interop. Coverage by hardware and open‑source focused outlets confirms the tooling and driver work is underway, which reduces the odds that SM 6.9 will remain a niche experiment. Still, vendor testing and driver regression rates are the gating factor for rapid adoption.
Conclusion — what this means in practice​
Shader Model 6.9 and the related Direct3D 12 enhancements are pragmatic and targeted: they fix real bottlenecks in ray tracing, reduce wasted shader work from opacity semantics, and lay the groundwork for on‑shader ML workloads that many studios already want. For engine teams and studios, the takeaway is clear:
  • Start experimenting now with preview compilers and driver builds.
  • Build pipeline support for micromaps and provide deterministic fallbacks.
  • Expect a phased roll‑out driven by GPU vendor driver updates; design code paths accordingly.
  • Anticipate future shader models to complete the cooperative vector/matrix story and plan for a second migration wave when those features arrive.
The technical changes in SM 6.9 and DXR 1.2 are the kind of incremental, practical advances that, when combined, make formerly expensive effects usable in shipping titles. The immediate winners will be titles with heavy alpha/foliage and ambitious ray‑tracing budgets, and teams looking to fold lightweight ML into their render pipelines without the overhead of separate compute ecosystems. As always, careful testing across drivers and hardware — and readiness to fallback gracefully — will determine who benefits most in the first 12–18 months after shipping support.
Source: TechPowerUp Microsoft Intros DirectX 12 Shader Model 6.9 and New Direct3D 12 Improvements | TechPowerUp}
