In the rapidly evolving world of industrial security, the integrity of access control and building management systems stands as a linchpin to the broader safety of critical infrastructure. Among the keystone solutions in this arena, Siemens SiPass—a comprehensive access control system widely adopted across manufacturing, industrial, and enterprise domains—has drawn fresh scrutiny following the disclosure of a severe cryptographic flaw. With industrial automation standing as a frequent target for sophisticated cyberattacks, a clear and accurate understanding of these vulnerabilities is not only prudent but essential for any organization relying on such systems.
A row of digital security and control panels mounted on a futuristic blue circuit-themed wall.Understanding the Siemens SiPass Ecosystem​
Siemens SiPass integrated is designed to manage access rights and building security for organizations of all sizes. Its versatility covers large critical manufacturing plants and complex enterprise environments, supported by devices like the AC5102 (known as ACC-G2) and the ACC-AP. These hardware controllers coordinate with servers to handle credential checks, door monitoring, alarm management, and integration with building automation networks.
This central role, paired with worldwide deployments and Siemens’ status as a global leader headquartered in Germany, places SiPass installations in the heart of sectors like Critical Manufacturing and beyond. However, sophisticated attacks against industrial control systems (ICS) are not hypothetical—they are well-documented, growing in frequency, and increasingly targeting supply chain and firmware-level weaknesses.
The Vulnerability: Improper Verification of Cryptographic Signature​
In a critical security advisory (SSA-367714), Siemens, in coordination with the U.S. Cybersecurity and Infrastructure Security Agency (CISA), has confirmed that all versions of the SiPass integrated AC5102 and ACC-AP devices are affected by a vulnerability tracked as CVE-2022-31807. This flaw is grounded in improper verification of cryptographic signatures—a class of weakness denoted under CWE-347.
At its core, the vulnerability means that affected devices do not properly verify the integrity of received firmware updates. Without robust cryptographic checking, it becomes feasible for a motivated attacker to upload and install modified, potentially malicious firmware to the device. Not only does this contravene best practices for industrial device security, but it also raises the specter of deep, almost invisible compromise—a worst-case scenario for any organization managing sensitive access points or critical infrastructure.
Key Technical Details​
  • CVE-2022-31807 is the unique identifier assigned to this flaw, with a calculated CVSS v4 base score of 8.2—placing it squarely in the "high severity" category. The CVSS 3.1 score is slightly lower at 6.2, but both scores highlight that exploitation complexity is low and that attacks can be performed remotely under the right circumstances.
  • Attack scenarios: There are principally two. In the first, a local attacker with network or physical access to the SiPass hardware can directly upload malicious firmware. In the second, a remote attacker capable of conducting a "man-in-the-middle" (MitM) attack can modify legitimate firmware updates as they are in transit from server to device, injecting their code without ever physically touching the hardware.
  • Exploitation potential: While no known public exploitation has been reported as of this writing, the simplicity and impact of the flaw make it an attractive target—especially as attackers increasingly automate discovery and targeting of exposed ICS and access systems.
Risk Evaluation and Sector Impact​
Successful exploitation grants an attacker persistent, low-level access to building management and security infrastructure. In sectors such as Critical Manufacturing, where SiPass is widely deployed, this opens the door to a range of attacks:
  • Manipulation of Access Rights: Malicious firmware could covertly alter, grant, or revoke access permissions—enabling data theft, physical theft, or even targeted sabotage.
  • Disruption of Alarm and Monitoring Systems: Attackers could disable alarm systems, create false alerts to distract responders, or otherwise interfere with incident response.
  • Pivoting into Broader IT/OT Networks: With compromised firmware, SiPass controllers could serve as a launching point for wider attacks, bridging segmented operational networks and exposing sensitive data or critical automation systems.
Critical infrastructure—including manufacturing, energy, utilities, and transport—relies on trust at every system layer. The compromise of a foundational element like SiPass endangers not just physical security but cyber resilience.
Mitigation Guidance and Practical Steps​
Despite the gravity of CVE-2022-31807, Siemens has not yet released a permanent fix for any affected SiPass hardware. Instead, the vendor emphasizes a series of defensive measures designed to reduce, but not fully eliminate, the risk of exploitation:
Siemens-Recommended Mitigations​
  • Enable TLS for Firmware Transfers: By encrypting communication between servers and affected devices, organizations can mitigate the risk of on-path (MitM) attackers intercepting and modifying firmware. However, this does not guard against attackers with direct device access.
  • Network Segmentation and Access Controls: Siemens advises hardening devices using their operational guidelines for industrial security—restricting exposure via strong firewalls, isolating control networks from business or internet-facing systems, and managing access controls tightly. Further details are available on Siemens’ official industrial security webpage.
  • Monitoring and Logging: Ongoing review of access logs and system activity can help detect anomalous behavior indicative of firmware tampering, though by the nature of such attacks, detection may be very challenging once a device is compromised.
CISA-Recommended Defensive Measures​
The U.S. Cybersecurity and Infrastructure Security Agency builds on Siemens’ recommendations with a series of best practices for industrial environments:
  • Minimize Device Exposure: Ensure that control systems and their management interfaces are never directly accessible from the internet.
  • Physical and Logical Segregation: Place critical devices and network segments behind robust firewalls and ensure they are logically isolated from general business networks or external-facing assets.
  • Secure Remote Access: When remote connectivity is required, employ up-to-date VPN solutions with strong authentication and ensure that connecting devices adhere to strict security standards. Recognize that VPNs themselves can carry vulnerabilities and must be maintained vigilantly.
  • Social Engineering and Phishing Defense: Stay alert to threats originating from phishing or targeted social engineering attacks—users and administrators should receive training in how to recognize and respond to suspicious emails or links.
  • Incident Reporting and Coordination: Should suspicious or malicious activity be detected, organizations are advised to follow their internal incident response plans and report findings to CISA for tracking, correlation, and broader industry awareness.
Taken together, these controls provide defense-in-depth—but the lack of a vendor-supplied firmware verification fix leaves a persistent risk that only mitigation, not true remediation, is achievable at present.
Critical Analysis: Weighing Strengths Against Risks​
Notable Strengths​
  • Transparency and Timely Disclosure: Siemens has proactively reported this vulnerability to CISA and promptly published detailed guidance. Such disclosure supports trust and enables organizations to act swiftly—a model approach that many IoT and ICS vendors still balk at providing.
  • Alignment with Security Best Practices: Both Siemens and CISA guidelines reinforce industry standards for ICS security. Strong defense-in-depth, proper segmentation, and encryption for OTA firmware updates are all best practices well-known among security practitioners.
  • Widespread Awareness Efforts: By leveraging federal and global channels—CISA in the U.S., Siemens ProductCERT worldwide—this flaw and its mitigations have received rapid, broad dissemination across impacted sectors.
Significant Risks and Weaknesses​
  • No Permanent Fix Available: As of this writing, Siemens acknowledges there is still no software or firmware update for the affected SiPass devices to address the underlying cryptographic vulnerability. This is a considerable gap, especially for systems on long hardware lifecycles or those installed in environments where physical security cannot be constantly guaranteed.
  • Attack Surface Remains: The guidance to enable TLS, while valuable, only addresses MitM attacks during firmware transmission. It does not impede attackers with local access, and may create a false sense of security for operators unaware of this limitation.
  • Legacy and Embedded Device Risks: The challenge of updating or replacing vulnerable industrial devices often involves significant engineering, regulatory, or budgetary hurdles. Legacy devices—many of which may never see an update—amplify the long-term impact of the flaw, serving as persistent risk nodes within critical environments.
  • Potential Long-Term Exploitation: Because device firmware vulnerabilities often remain unpatched for years, these flaws can become the silent entry points for attackers able to bide their time, quietly compromising access controls beneath the radar of enterprise security software.
The Supply Chain Challenge: Verifying Device Integrity​
The SiPass flaw exemplifies a larger, increasingly ubiquitous challenge in the ICS and IoT world: ensuring the integrity of vendor-supplied, field-installed firmware. As organizations push for both connectivity and automation, gaps in the mechanisms that verify code authenticity and prevent unauthorized modification present a growing risk.
Successful supply chain and firmware-level intrusions can cascade across the broader infrastructure, with attackers subverting trusted processes to install backdoors, siphon sensitive data, or facilitate lateral movement within tightly controlled networks.
This underscores the imperative, not only for vendors to enforce robust cryptographic verification at every stage of device operation, but also for asset owners to demand verifiable security guarantees and to continuously monitor for signs of malicious activity at the firmware and controller level.
Forward-Looking Recommendations for Asset Owners​
In light of the SiPass vulnerability, organizations managing ICS or building automation assets should consider the following:
Immediate Steps​
  • Verify Device Inventory: Identify all Siemens SiPass integrated AC5102 and ACC-AP devices within your environment, and document where and how firmware updates are performed.
  • Enable and Enforce TLS: Where possible, configure all supported devices to utilize TLS encryption for server communications, especially during firmware transfer operations.
  • Harden Physical and Network Access: Reduce the device attack surface by restricting all forms of access—both physical and logical. Implement stringent access controls and regular audits.
  • Review and Update Incident Response Plans: Ensure that response measures account for the possibility of device-level firmware compromise, including plans for device isolation, forensic examination, and coordinated reporting to Siemens and CISA.
Mid-to-Long-Term Strategies​
  • Request Vendor Roadmap for Updates: Engage Siemens representatives to obtain clarity on forthcoming patches or device upgrade paths. Organizations should not settle for indefinite mitigation-only scenarios.
  • Evaluate Device Replacement Cycles: For high-risk or highly exposed infrastructure, consider the feasibility of accelerating device replacement strategies. Modern ICS solutions increasingly offer secure boot, signed firmware, and more granular audit capabilities.
  • Implement “Zero Trust” Approaches in ICS: Build environments where trust is never implicit—even for internal communications or device updates. Scrutinize all code, all connections, and all operational actions.
Community Engagement​
  • Collaborate on Threat Intelligence Sharing: Participate in sector-specific information sharing groups and leverage CISA’s public advisories for insight into evolving threats.
  • Report Anomalies Promptly: Any unusual device behavior, unexplained access changes, or suspected firmware manipulation should be escalated rapidly—both for internal investigation and for sector-wide awareness.
Conclusion: Navigating the Realities of Industrial Device Security​
The disclosure of CVE-2022-31807 in Siemens SiPass integrated controllers shines a harsh light on the pressing reality of industrial device vulnerabilities in the modern era. While Siemens and CISA provide actionable guidance, the absence of a software or firmware update means organizations must balance operational continuity against elevated risk.
Security teams supporting critical infrastructure must remain vigilant, combining layered technical controls with proactive risk management and a clear-eyed understanding of their asset landscape. As the threat landscape evolves and attackers steadily shift their sights to firmware and supply chain targets, the SiPass incident stands as a cautionary tale—a reminder that security-by-design, verifiable cryptographic protections, and continuous monitoring are essential foundations for any trusted digital infrastructure.
For the many organizations relying on SiPass, this is not a call for panic but for urgent, strategic action: tighten controls, press for vendor accountability, and prepare for a world where device trust can never be assumed but must be continuously earned and verified.
Further Technical and Mitigation Resources:
Organizations are encouraged to review these resources and maintain active dialogue with both Siemens and sector-specific security communities as the situation evolves.
Source: CISA Siemens SiPass | CISA
