Windows 7 Single card quad monitor support for Dell XPS 8000 + WHP/64
mthomas
I need to add single-card quad monitor support to my Studio XPS 8000 Under 64 bit Home Premium.
I don't need screamingly fast video, the most video intensive app I run is a single instance of Photoshop, 2D only.
I do need minimum aggravation.
To date the only quad head board I've found with Win 7/64 drivers is the ATI FirePro 2450.
Any experience with this card, or any other suggestions?
Thanks..
[FONT=&quot]
[/FONT]
To add quad monitor support to your Studio XPS 8000 running Windows 7 64-bit Home Premium without requiring high-speed video performance, the ATI FirePro 2450 is a viable option. This card is designed for professional environment use and should be more than sufficient for running a single instance of Photoshop with 2D applications. Here are some considerations and suggestions regarding the ATI FirePro 2450 and other possible alternatives:
ATI FirePro 2450 Overview:​
  • Quad Monitor Support: The ATI FirePro 2450 supports up to four monitors, making it suitable for your quad monitor setup.
  • Driver Support: It provides Windows 7 64-bit drivers, ensuring compatibility with your operating system.
  • Performance:...
  • Performance: While not geared for high-speed video or gaming applications, it is more than capable of handling 2D applications like Photoshop.
  • Reliability: ATI FirePro cards are known for their stability and reliability, which can minimize potential issues.
Other Suggestions:​
If you are open to exploring alternatives to the ATI FirePro 2450, here are a few other suggestions:
  • NVIDIA Quadro NVS Series: NVIDIA's NVS series also offers quad monitor support with reliable performance.
  • AMD Radeon Pro WX Series: AMD's Radeon Pro WX series can be another suitable option for professional-grade applications.
  • Matrox Graphics Cards: Matrox specializes in multi-display graphics cards and offers various models that might meet your needs.
Compatibility Check:​
Before making a final decision, ensure the following:
  • Compatibility: Check if the chosen graphics card fits within the power and physical constraints of your Studio XPS 8000.
  • Driver Availability: Confirm that the card has Windows 7 64-bit drivers available for download.
If you have any specific requirements or constraints in mind, feel free to share more details for tailored recommendations. Ultimately, the ATI FirePro 2450 seems like a solid choice for your setup based on its features and driver support for Windows 7 64-bit. Should you need further assistance or have more questions, don't hesitate to ask!
