- Thread Author
- #1
Hi, I have an issue where the sound stops whenever my monitor goes to sleep or back.
For example, I'm listening to music via MediaMokey, the screen goes to sleep, and the sound stops for 1- 2 seconds, then comes back. When I move my mouse or press a key on my keyboard to wake up the monitor, the same thing happens. (The sound problem happen no matter what what program is running)
I've tried other monitors, and other cables (HDMI / DP) All with no luck.
I don't think it's related to the monitor itself, but to windows as the PC is playing sound through the soundcard (the mini jacks on the back) and not using monitor speakers.
The PC is a fairly newly install, and when I first installed it, it didn't do this weird thing. The PC just began doin it after a few weeks.
I have never encounted this problem before, and I'm curious as to why it does this. (And of course how I fix it. Preferably without just sorting to just turning off sleep mode for the monitor.
Specs:
Windows 10 Home
RAM: 16 GB
CPU: I5-9400F 2,9Ghz
GPU: Nvidia GeForce GTX 1650
HDD: 250 GB SSD
Have anyone had this problem before? If yes, how did you solve it? Besides from turning off sleep mode.
Specs:
Windows 10 Home
RAM: 16 GB
HDD: 250 GB SSD
