Windows 7 Standard VGA graphics adapter
Clint Garcia
hello there, i have some problem, i don't know what graphics driver should i install. please somebody help me, its a normal Nvidia video card 8-bit, direct draw,direct 3d acceleration is notavailable... os: windows 7.
main driver: vga
Version: 6.1.7600.16385
thanks, i just forced my computer to be a windows 7, btw, what is the lowest video card could i buy for my computer to have direct 3d acceleration?
It's better if you just get a new computer. Intel Pentium 4 is a really old processor, and most people have at least 4GB RAM installed - you don't even have 1GB. If you buy a 660 Ti, 7850 or something like that, you'll just bottleneck your system - the processor and RAM won't be able to cope with the graphics card, and you'll pretty much be paying $500 to use $30 or $40 of the card.
Even if you wanted to upgrade your computer, your motherboard may or may not support the RAM, socket for the CPU etc. In fact, I don't think your computer even has PCIe slots to put the cards in.
OJI SAPUTRA
This , because the laptop does not get the sound continued , and when it was insala reltecknya ?​
  • DxDiag.txt
    DxDiag.txt
