Sushat
Hi guys,
I recently updated my Windows 10 to the November update( ver 1511,10586),and I found that the "Pin to Start menu" and "Resize" tabs are not working.When I right click on any app,I only found the "More" tab only to be functional.
When I went into Settings,I found this(picture attached to the post).Now how do I overcome this problem.
Somebody please help!!!!
if your running an Anti Virus application try uninstalling it and just use the default Defender.
Try running these scans:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Try this troubleshooter from Microsoft:
Run the troubleshooter for Windows apps - Windows Help -
Bkgreenva
Member
Hi guys,
i would finish updating you have a few more to go since you stopped at November, then see what happens with your issue
Sushat
I updated to the latest version.Still the options are not available nor am i able to download anything from the Windows store
File scans
sfc /scannow
Sushat
I
File scans
sfc /scannow
I tried everything,uninstalled the antivirus,ran the commands in the Command Prompt as admin and ran the troubleshooter....but still the problem persists.
An image from 'Start Menu problem'. Windows Personalization Start settings screen showing options to show suggestions, most used, and recently added apps.
