In my experience it averages 2 pages of posts to fix most BSOD issues - with some taking even longer. Please be patient as not all info shows up in the dump files every time.
In this case we come to find out that there's several different errors that showed up in the latest memory dumps(common with low-level driver issues and hardware issues)
First is that the Daemon Tools driver - sptd.sys - was still present in one of the memory dumps. Since it's not present in the most recent, we'll have to assume that it's been uninstalled (but keep an eye out for it just in case).
Next, AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Link Removed - Invalid URL (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: Link Removed
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
Next, your Razer Lycosa drivers date from 2008 and are known to cause BSOD's on Win7 systems. Please update the drivers to the latest available, Win7 compatible drivers from the Razer website.
Next, there's a copy protection program on your system that dates from 2009. Most likely it came from installing the viewer for a DVD movie - but that's not 100% certain. If you can't locate the program to uinstall, post back for detailed instructions on removing it (we'll do this if all else fails).
Also, I noted PeerBlock on your system. While there's no direct evidence of problems with this program, I have to suspect it because of previous issues. Please un-install it. Feel free to reinstall it once the BSOD's have stopped
I've also seen issues with Advanced System Care conflicting with other security programs - please un-install it also
Please update your NEC Electronics USB 3.0 Host Controller Drivers - they date from 2010 and have had previous issues w/BSOD's.
Finally, one of the memory dumps blames your video drivers. Please follow the suggestions at this topic for troubleshooting that:
STOP 0x116: VIDEO_TDR_ERROR troubleshooting - Windows 7 Forums
Here's some links for the drivers that need updating:
Lycosa.sys Fri Jan 18 03:51:42 2008 (4790689E)
Razer Tarantula Keyboard Driver
lirsgt.sys Sun May 17 09:06:57 2009 (4A100BF1)
part of a Copy Protection platform developed by Tages SA
atksgt.sys Sun May 17 09:36:34 2009 (4A1012E2)
nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
NEC Electronics USB 3.0 Host Controller Driver (previous issues w/BSOD's)
nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
pbfilter.sys Sat Nov 6 22:23:54 2010 (4CD60DBA)
Peerblock
AODDriver2.sys Tue Mar 6 04:55:00 2012 (4F55DEF4)
AMD Overdrive; also in EasyTune6 for Gigabyte motherboard
Analysis:
[FONT=lucida console]**************************Wed Oct 10 09:35:52.500 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101012-34959-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (3 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:20:45.952[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa8007e9b028, b669c000, 175}[/B]
Probably caused by :[B]AuthenticAMD[/B]
BugCheck Info: [B]WHEA_UNCORRECTABLE_ERROR (124)[/B]
BUGCHECK_STR: 0x124_AuthenticAMD
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: [B]TrustedInstall[/B]
FAILURE_BUCKET_ID: [B]X64_0x124_AuthenticAMD_PROCESSOR_CACHE[/B]
BIOS Version 3029
BIOS Release Date 07/05/2012
Manufacturer System manufacturer
Product Name System Product Name
**************************Wed Oct 10 01:59:24.670 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101012-27128-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
System Uptime:[B]6 days 20:03:35.841[/B]
BugCheck Code: [B]BugCheck 116, {fffffa8012422380, fffff8800430726c, 0, 2}[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]atikmpag.sys ( atikmpag+926c )[/B]
BugCheck Info: [B]VIDEO_TDR_FAILURE (116)[/B]
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
BUGCHECK_STR: 0x116
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x116_IMAGE_atikmpag.sys[/B]
BIOS Version 1902
BIOS Release Date 02/17/2011
[/FONT]
3rd Party Drivers:
[B]Lycosa.sys Fri Jan 18 03:51:42 2008 (4790689E)[/B]
[B]lirsgt.sys Sun May 17 09:06:57 2009 (4A100BF1)[/B]
[B]atksgt.sys Sun May 17 09:36:34 2009 (4A1012E2)[/B]
AsUpIO.sys Sun Jul 5 22:21:38 2009 (4A515FB2)
ASACPI.sys Wed Jul 15 23:31:29 2009 (4A5E9F11)
jraid.sys Mon Jan 11 06:28:18 2010 (4B4B0B52)
amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
AtiPcie64.sys Wed Mar 10 09:33:45 2010 (4B97ADC9)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsIO.sys Thu Apr 22 07:18:03 2010 (4BD0306B)
[B]nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
[/B]RTKVHD64.sys Wed Apr 6 03:30:01 2011 (4D9C1679)
Rt64win7.sys Fri Jun 10 02:33:15 2011 (4DF1BAAB)
SASKUTIL64.SYS Tue Jul 12 17:00:01 2011 (4E1CB5D1)
SASDIFSV64.SYS Thu Jul 21 19:03:00 2011 (4E28B024)
regfilter.sys Fri Sep 16 05:12:03 2011 (4E7312E3)
[B]AODDriver2.sys Tue Mar 6 04:55:00 2012 (4F55DEF4)[/B]
GEARAspiWDM.sys Thu May 3 15:56:17 2012 (4FA2E2E1)
AtihdW76.sys Fri May 11 04:25:40 2012 (4FACCD04)
atikmpag.sys Fri Jul 27 21:14:47 2012 (50133D07)
atikmdag.sys Fri Jul 27 21:48:09 2012 (501344D9)
mbam.sys Mon Aug 20 12:49:41 2012 (50326AA5)
MpFilter.sys Thu Aug 23 19:03:14 2012 (5036B6B2)
SmartDefragDriver.sys Fri Nov 26 04:29:40 2010 (4CEF7E04)
speedfan.sys Fri Mar 18 12:08:46 2011 (4D83838E)
UrlFilter.sys Fri Sep 16 03:46:34 2011 (4E72FEDA)
agi83i4s.SYS Tue Dec 27 17:30:45 2011 (4EFA4715)
[B]sptd.sys Tue Jan 3 19:01:58 2012 (4F0396F6)[/B]
FileMonitor.sys Thu Jan 5 05:03:38 2012 (4F05757A)
[/FONT]
agi83i4s.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. This is a Daemon Tools dynamically assigned driver.
