Windows 10 Surface pro X sq2
Justice
Can someone point me in the right direction if I want to get signal to work on this surface?
Looking to see if I need a app to convert etc....
Sent from my motorola edge plus using Tapatalk
To get the Signal messaging app working on your Surface device running Windows, you can follow these steps: 1. Check Signal Compatibility: - Ensure that Signal is compatible with the Windows version you're running on your Surface device. Signal primarily supports mobile platforms like Android and iOS, but there's also a standalone application for Windows. 2. Download Signal for Windows: - Visit the official Signal website to download the Signal Desktop app for Windows. You can download it from the Signal website directly. 3. Installation: - After downloading the Signal Desktop app, run the installer to set up the application on your Windows device. 4. Initialization and Setup: - When you open the Signal app for...
To get the Signal messaging app working on your Surface device running Windows, you can follow these steps: 1. Check Signal Compatibility: - Ensure that Signal is compatible with the Windows version you're running on your Surface device. Signal primarily supports mobile platforms like Android and iOS, but there's also a standalone application for Windows. 2. Download Signal for Windows: - Visit the official Signal website to download the Signal Desktop app for Windows. You can download it from the Signal website directly. 3. Installation: - After downloading the Signal Desktop app, run the installer to set up the application on your Windows device. 4. Initialization and Setup: - When you open the Signal app for the first time, you'll usually be required to link it to a mobile device. Follow the on-screen instructions to complete the setup process. 5. Operation: - Once set up, you can use Signal on your Surface device to send and receive messages, make voice and video calls, and more. 6. Syncing with Mobile: - Signal for desktop should be linked to the Signal app on your mobile device to sync messages and contacts. Make sure to download Signal from the official sources to ensure security and authenticity. Since Signal is primarily designed for mobile platforms, using it on Windows might require linking it to a mobile device for full functionality.
