- Joined
- Jun 27, 2006
- Messages
- 23,048
- Thread Author
- #1
Original release date: May 21, 2018
Systems Affected
CPU hardware implementations
Overview
On May 21, 2018, new variants—known as 3A and 4—of the side-channel central processing unit (CPU) hardware vulnerability were Link Removed. These variants can allow an attacker to obtain access to sensitive information on affected systems.
Description
CPU hardware implementations—known as Link Removed—are vulnerable to side-channel attacks. Meltdown is a bug that "melts" the security boundaries normally enforced by the hardware, affecting desktops, laptops, and cloud computers. Spectre is a flaw that an attacker can exploit to force a CPU to reveal its data.
Variant 3a is a vulnerability that may allow an attacker with local access to speculatively read system parameters via side-channel analysis and obtain sensitive information.
Variant 4 is a vulnerability that exploits “speculative bypass.” When exploited, Variant 4 could allow an attacker to read older memory values in a CPU’s stack or other memory locations. While implementation is complex, this side-channel vulnerability could allow less privileged code to
Corresponding CVEs for Side-Channel Variants 1, 2, 3, 3a, and 4 are found below:
Side-Channel Vulnerability Variants 3a and 4 may allow an attacker to obtain access to sensitive information on affected systems.
Mitigation
NCCIC recommends users and administrators
The following table contains links to advisories and patches published in response to the vulnerabilities. This table will be updated as information becomes available.
Link to Vendor InformationDate Added
This product is provided subject to this Link Removed and this Link Removed policy.
Systems Affected
Overview
Description
- Read arbitrary privileged data; and
- Run older commands speculatively, resulting in cache allocations that could be used to exfiltrate data by standard side-channel methods.
- Variant 1: Bounds Check Bypass – CVE-2017-5753
- Variant 2: Branch Target Injection – CVE-2017-5715
- Variant 3: Rogue Data Cache Load – CVE-2017-5754
- Variant 3a: Rogue System Register Read – CVE-2018-3640
- Variant 4: Speculative Store Bypass – CVE-2018-3639
Mitigation
- Refer to their hardware and software vendors for patches or microcode,
- Use a test environment to verify each patch before implementing, and
- Ensure that performance is monitored for critical applications and services.
- Consult with vendors and service providers to mitigate any degradation effects, if possible.
- Consult with Cloud Service Providers to mitigate and resolve any impacts resulting from host operating system patching and mandatory rebooting, if applicable.
- Google Project Zero Blog
- Bounds Check Bypass – CVE-2017-5753
- Branch Target Injection – CVE-2017-5715
- Rogue Data Cache Load – CVE-2017-5754
- Rogue System Register Read – CVE-2018-3640
- Speculative Store Bypass – CVE-2018-3639
- Link Removed
- May 21, 2018: Initial version
