DMRazerMouse
Hi All, I have the latest build in W11 fully up to date. However when I change the windows theme to 'light' the date/time and sound/network in the task bar when I hover over just turns to white boxes and when I search for something windows + S I can't see the text I am typing and lastly not all tiles show text when say I try to change something in settings.
Dark mode is fine, can see all text etc.
Any help much appreciated.
Seems that you had display driver problem. So i suggest you to download and install display driver from the manufacturer website. If you have already installed the drivers then open device manager locate your display driver and click uninstall. After uninstall system prompt you to restart so restart your machine. windows automatically reinstall the display drivers and hopefully your problem will be solved.
