Windows 11 Time left on battery and other issues
hcooper
Ok, so I am totally unimpressed with Windows 11 and the work they have done in making things streamline but now they are utterly awful and not nearly as quick or user friendly. Not only that but it seems like other softwares modified too and now they are garbage??
I will keep it to one thing right now and hopefully it will bring other ways to revert back or just get things back to where they were better.
The battery always shows percent but never an estimated timeframe for it to drain, how do I fix this?
ok, two things, This stupid right click menu to "show more options", how do I just go back to the old menu where it was all "show more options"?
Neemobeer
Cloud Security Engineer
Location
Colorado
For the menu there is a bit of a hack you can do to get the old menu back.
If you open cmd, powershell or windows terminal and run the following command
reg.exe add "HKCU\Software\Classes\CLSID\{86ca1aa0-34aa-4e8b-a509-50c905bae2a2}\InprocServer32" /f /ve
That should revert the menu back to the original.
Top Bottom
