Top 5 Solutions to Fix WiFi Disconnections on Windows 11
WiFi disconnections can be incredibly frustrating, especially when you rely on a stable internet connection for work or entertainment. This issue is particularly common among Windows 11 users, prompting many to seek solutions for maintaining reliable connectivity. This article outlines five effective fixes that can help resolve the disconnection problems you're experiencing with WiFi on Windows 11.
Man thoughtfully working on a laptop in a modern office setting.
Background: The WiFi Disconnect Problem​
WiFi connectivity issues have been a long-standing concern among users of various operating systems, and Windows 11 is no exception. Many factors can contribute to these issues, including outdated drivers, power-saving features, and even problems with your router or network settings. Understanding the potential causes allows users to tackle the problem from multiple angles.
1. Update Network Adapter Drivers​
Outdated or corrupted network adapter drivers are often at the core of many WiFi connectivity issues. Regularly updating these drivers is essential for ensuring that your hardware communicates effectively with the operating system. This can resolve a significant number of problems related to WiFi disconnections.
How to Update Your Network Adapter Drivers:​
  • Open Device Manager: Press the Windows key + X and select "Device Manager" from the menu.
  • Expand Network Adapters: Locate and expand the "Network adapters" category.
  • Update Drivers: Right-click on your WiFi adapter and choose "Update driver." Select "Search automatically for drivers" and allow Windows to look for the latest version. For a more comprehensive solution, consider using driver update software like PC HelpSoft Driver Updater. This tool can automatically detect and update all outdated drivers, ensuring the optimal performance of both your WiFi and other hardware components.
Features of PC HelpSoft Driver Updater:​
  • Automatic scanning and identification of outdated drivers
  • Access to a vast database of the latest manufacturer-approved drivers
  • Ability to update multiple drivers simultaneously, saving time and effort
  • Creation of restore points before updates for easy rollback if needed
2. Disable Power Saving for WiFi Adapter​
Windows 11 has a power-saving feature that may occasionally cause WiFi to disconnect unexpectedly to save battery. Disabling this setting can help maintain a stable connection.
Steps to Disable Power Saving:​
[*Open Device Manager*: Access the Device Manager as outlined in the previous section. [Locate WiFi Adapter: Expand the "Network adapters" and right-click on your WiFi adapter. [*Go to Properties*: Select "Properties," then navigate to the "Power Management" tab. [Uncheck Power Saving: Uncheck the box that says "Allow the computer to turn off this device to save power" and click "OK" to save your changes.
3. Reset Network Settings​
If you continue to experience disconnections, it might be time to reset your network settings. This can resolve complex connectivity issues by removing existing network configurations and starting fresh.
How to Reset Network Settings:​
[*Open Settings*: Press the Windows key + I to open the Settings app. [Navigate to Network Settings**: Go to "Network & Internet," then find "Advanced network settings." [*Initiate Network Reset: Scroll to "More settings," select "Network reset," and confirm the action by clicking “Reset now.” Note: This will remove all network adapters and reset their settings to default, so you will need to reconfigure your WiFi connection afterward.
4. Check for Windows Updates​
Ensuring your Windows 11 system is up-to-date can resolve many WiFi issues, as updates frequently include fixes for known connectivity problems.
Steps to Check for Updates:​
[*Open Settings*: Press the Windows key + I. [Go to Windows Update: Click on "Windows Update" in the sidebar. [*Check for Updates*: Click the "Check for updates" button. If any updates are available, download and install them. [Restart Your Computer: After updates are installed, restart your PC to apply the changes.
5. Modify Router Settings​
Sometimes, the root of the WiFi disconnects is your router rather than your Windows 11 device. Modifying specific settings on your router can greatly improve connection stability.
Suggested Router Modifications:​
[*Access the Router's Admin Panel*: Usually, you can do this by typing 192.168.0.1 or 192.168.1.1 in your browser's address bar. [Adjust Channel Settings**: Look for settings related to channel width or frequency. Switching from a wider channel (like 40MHz) to a narrower one (like 20MHz) may help minimize interference. [*Change Frequency Band: If your router supports it, switching from the 2.4GHz band to the 5GHz band, or vice versa, can also make a difference.
  • Save Changes: After making adjustments, remember to save your changes and restart your router.
Additional Considerations​
Should the suggested fixes not resolve your WiFi issues, consider checking the following:
  • Physical Environment: Ensure there are minimal physical obstructions between your WiFi router and device. Walls and large objects can weaken your signal.
  • Network Congestion: Too many devices connected to the same network can cause congestion. Disconnect devices not in use.
  • Interference from Other Devices: Devices such as microwaves and cordless phones can interfere with WiFi signals. Keeping them away from your router may help.
Why does WiFi keep disconnecting on Windows 11? This is a question many users grapple with, but armed with the right knowledge and methods, you can resolve these issues effectively. From updating drivers to checking router settings, the solutions outlined provide a comprehensive approach to ensuring a stable and reliable WiFi connection. If you implement these strategies and continue to experience issues, it may be time to consult with your Internet Service Provider for further assistance. What worked for you? Share your experience in the comments below. By exchanging tips and solutions, we can help each other enhance our Windows 11 experience and make connectivity issues a thing of the past. Source: MSPoweruser WiFi Keeps Disconnecting on Windows 11 [5 Easy Fixes]
